Need help deciding what cube engine to build
Im trying to decide what cubic inch engine to build. From the start i will say that i know i still have alot of reading and research to do but i would like a push in the right direction.
I want an engine that will lay down ~550hp. I want it NA and I want it reliable. I really dont know what ci engine can accompany what im looking for... 402, 408, 418 etc.
Once again i know i need to do some research but im looking for a push in the right direction and maybe some engine builders i could look into.
I was going with a 408 but now i cheaped out for a 370 iron block using stock crank and setting it up so it will be easy to adjust for some boost in the future which is what I really want. thinking of a D1 later on.
