what torque specs on Stock LS2 Rocker Arms ?, and Stock lifter trays
Old 04-06-2008, 02:40 PM
BadLtBlu99TA's Avatar
Question what torque specs on Stock LS2 Rocker Arms ?, and Stock lifter trays
What are the stock rocker torque specs ? is it ok to reuse rocker arm bolts ? are the stock Ls2 rocker arms ok to reused on stage 3 patriot heads with a 231/237, 589/595 on a 114 cam ?
How do i find out the Valve lash when tightening the rocker arms ? WHAT SHOULD IT BE ?
Are the stock Lifter Trays ok to Reuse also with almost 600 lift cam ?
i am reusing the stock lifters , they should be fine shouldnt they ?
Old 04-06-2008, 03:12 PM
KCS
Moderator
KCS's Avatar
The rocker arms bolts should be OK to reuse assuming the threads are intact. Torque to about 22ft-lbs with a good lube like ARP or CMD.
With a hydraulic lifter valvetrain, you usually set a preload, not a lash setting. You tighten the rocker bolt until there is no lash, and then tighten 1/4-1 full turn. If it takes more than 1 turn or less than 1/4 turn, you need a different length pushrod.
Stock trays are usually OK to use, but new ones are cheap and it's kinda like "why not?" Same with reusing lifters. New GM lifters are like $200. If you re use them, inspect them very, very, VERY carefully and disassemble to clean if you can.
Hope that helps.
Old 04-06-2008, 03:46 PM
if you have to tighten it to a certain preload , what is it ? .030 ? then how does the 22ftlb come in then if you only use the 1/4 to 1 turn after its preloaded .. ? im really confused here .. someoine please help
Quick Reply: what torque specs on Stock LS2 Rocker Arms ?, and Stock lifter trays
