More ported L92 head pics
That is some serious porting!
I have a set ported, and mine also opened up the threaded hole for the intake rocker, but not that other hole. Is the other one the threaded hole for the exhaust rocker bolt?
Intake Exhaust (without pipe)
.200/162 126
.300/240 180
.400/302 218
.450/316 225
.500/340 236
.550/353 243
.600/361 250
.650/369 254
.700/377 257
.750/382 263
.800/388 268
.850/395
.900/399
.950/405
1.00/414
Intake Valve was a custom 2.150 valve and the exhaust was a custom 1.60.
This is what mine flowed on a 4.067 bore. My exhaust port flowed very well.
Chris Frank at RayMac in FtWorth, Tx did the port work. Could have gotten better numbers but we wanted more thickness for the springs im using.
Motor made 710 before it foated valves. T&D is fixing the problem and we expect another 25-30 out of it at least.
.200/162 126
.300/240 180
.400/302 218
.450/316 225
.500/340 236
.550/353 243
.600/361 250
.650/369 254
.700/377 257
.750/382 263
.800/388 268
.850/395
.900/399
.950/405
1.00/414
OWN3D BY MY PROF!
From the sounds of custom valves, springs I'm running, and T&D I'm guessing your running a solid roller setup. Can you give us some more details about the whole combo? Such as the engine setup, what intake you are running, etc.. Was that on a engine dyno? It sounds like you're one of the first people to put down what I consider impressive L92 numbers.
Motor is a 414 with 11.75:1 compression. I was going to put it in my 01 WS6 but have decided not to. Instead its going in a 2900 LB 92 Z28
OWN3D BY MY PROF!
Yeah, i have a few other threads on this motor. We had a hard time with the salesman as he would NOT let us talk to Larry Torrez (owner of T&D) We finally did and he said he would get us a new set with OUR measurements. The pushrod cup is in the wrong spot.
.200/162 126
.300/240 180
.400/302 218
.450/316 225
.500/340 236
.550/353 243
.600/361 250
.650/369 254
.700/377 257
.750/382 263
.800/388 268
.850/395
.900/399
.950/405
1.00/414
.200/162 126
.300/240 180
.400/302 218
.450/316 225
.500/340 236
.550/353 243
.600/361 250
.650/369 254
.700/377 257
.750/382 263
.800/388 268
.850/395
.900/399
.950/405
1.00/414
Hate to bring this one back from the dead but I am willing to bet these heads dont flow that well,if they did,youd make a hell of alot more than 710 to the wheels.....
Anyone can fudge flow #'s and I am willing to pay shipping to and from a reputable head porter to show you they dont flow near 300cfm at .400
congratulation
From where I can get these CNC massaged L92 heads...
Thanks...
