LS2 timing set and cam retainer questions (Pics)
So I've got a brand new 402 with a Eagle crankshaft and a LS2 timing set that needs to be installed. I've never messed with the crank gear before. Does the stock crank have a key too? I'm guessing I need a key for my new stuff right? Also it turns out that the 2 holes just above the crank is for a chain damper. Is that needed?
Heres a pic of my motor.
Here's the chain damper i'm talking about.
Now about the dots on the gears, I can see the dot on the cam gear, but the damn crank gear doesn't have anything as far as I can see. Is the "dot" where the key goes?
Lastly, I don't have a cam retainer plate or the bolts so I need to order them. It looks like there is a gasket for it too. Does that come with the new plate or is it separate?
The stock crank has a key that engages and aligns the crankshaft timing gear. Order one from the dealer if you don't have one.
The timing chain damper is highly recommended. It's very cheap for the LS2.
There is a dot on the crankshaft timing gear, it's just very small.
The o-ring on the back of the cam retainer plate is made into the plate, it doesn't come off.
Gotta love this site, thanks man!
I searched earlier on the crank key and a question came up about sizes and stuff. Is the crank key is the same for these motors. I'm probably going to call TSP in the morning for all this so they should know. I need a lot of miscellaneous bolts and parts!
Take note, the new cam retainer plate has countersunk holes and requires special GM bolts so don't waste money an ARP's, you won't be able to use them with the new plate. My information is also that the torque reduces from 18 to 11 lb-ft with the new plate as it is the same as the L92.
Read this for more information: Link
Here is information I found on the torque values: Link
Be sure to use thread-lok on the cam bolts. The guy who installed my heads & cam or his helper forgot which trashed my last engine. It bent all the valves, cam-shaft, rollars, rollar guides, timing cover, timing chain, oil pump & more. Spend some money on thread-lok for sure. Just a heads up of what can happen over just a simple step skipped. LOL
I can't answer that, but the new plate with the countersunk screws was introduced to clear something on later motors. Matt at SDPC was very helpful sorting this all out for me when most dealers and parts houses were telling me to use the old bolts, which I knew was wrong. You may want to contact Matt with your question. Report back what you find, this will make a great archive as I think a lot of guys will run into this in the future.
My retainer plate was broken when we swapped my first cam into it. We believed the factory had over tightened the bolts and the plate is weaker due to the countersunk holes. Mine wasn't the only one there has been lots of reports of the same issue in others cars as well.
cheers
cheers
So it looks like GM in their wisdom didn't want 2 different plates floating around so they just decided to use the same plate for all future models. The old plate has now been superceded for all models I believe. So a new plate will probably be another change whilst your at it thing to do when swapping cams.
Good pics here of the dot and crank key etc
https://ls1tech.com/forums/generation-iv-internal-engine/906024-quick-ls2-timing-set-dot-dot-pics.html
The oil pump sprocket in the pic is hiding the dot on the cam gear. The crank key should like up with the bore of cylinder 1, and the dot will be straight up.
