melling 295 oil pump too small?
i have an iron 408 that im building, clevite bearings, tfs heads and all the goodies. my question is will the melling pump be too small? or would i have to bump up to the 296? or what other pump should i look at? thanks guys
do you need a Bigger then Stock LS1 oil pan and different Pickup Tube , if you go to the Melling 20296 oil pump ? or will the stock be ok ? i mean if wouldnt dry sump the oil pan would it ?
There is some sort of pressure by pass in the pump, different springs allow higher pressure with same volume, hell idk. I know you can flow the same volume with different pressures by by changing the outlet size, but I won't pretend I know this is how it works .
Melling lists them different, one as high pressure, the other as high volume/high pressure, so whatever that means.
Dan
Dan
