Can i install the Heads and then install the oil pan and covers After - LS1TECH
Thread Tools Search this Thread
Old 05-04-2008, 04:58 PM   #1
BadLtBlu99TA's Avatar
Question Can i install the Heads and then install the oil pan and covers After
My question is can i install the lifters with lifter trays then install the heads before i install the oil pan and covers and oil pickup tube oil pump ect ? or is there a certain way i should go about this ? just wonder..
Will part # 134-3610 work for TSP 402cid engine ? need advice asap , thanks .. i dont have ARP lube , so will oil work ? thanks ..
BadLtBlu99TA is offline   Reply With Quote
Old 05-04-2008, 09:50 PM   #2
Restricted User
socmguy's Avatar
Yes, you can assemble it that way,
don't know if that part will work,
oil will work if you don't have arp lube
socmguy is offline   Reply With Quote
Old 05-04-2008, 10:02 PM   #3
Randy WS6's Avatar
There is a different torque spec with the oil, go to ARP web site to see.
Randy WS6 is offline   Reply With Quote
Old 05-04-2008, 10:12 PM   #4
DrkPhx's Avatar
That is the same head bolt kit I use. Even though you can use motor oil, I seriously recommend using the ARP Moly lube. The bolts torque much smoother and easier. If you do use oil, keep in mind the torque spec is higher.
DrkPhx is offline   Reply With Quote
Old 05-04-2008, 11:23 PM   #5
Default about assembly
thanks all .. appriciated it !!
Old 05-04-2008, 11:31 PM   #6
Question Moly Lube !!!!!! ??
i got my Head bolt kit and it didnt have any ARP Moly Lube in the box , how could i get this ? FAST ??? i need this stuff ASAP !!! like tommorow Afternoon !!
Old 05-05-2008, 09:14 AM   #7
DrkPhx's Avatar
A local speed shop should carry it. Summit Racing (in Ohio) also has it.
Old 05-05-2008, 12:03 PM   #8
Randy WS6's Avatar
I got a bottle of it from Summit for 19.00 but you can get the little packet to alot cheaper
Old 05-05-2008, 02:17 PM   #9
Jegs is in columbus.
czwalga00gt is offline   Reply With Quote
Old 05-05-2008, 02:46 PM   #10
Restricted User
socmguy's Avatar
yep, Jegs/Summit will ship it fast as hell!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
