Feeding LSx block oil from the rear plug
Old 05-05-2008, 05:49 PM
7 Second Club
Phil99vette's Avatar
Default Feeding LSx block oil from the rear plug
Do you need to do anything special or add any plugs to the LSx block if you intend on feeding your oil through the rear plug on the low driver side?
Old 05-05-2008, 07:58 PM
LS1Tech Sponsor
Robin L's Avatar
No, we did open it up and tap it to 3/8 pipe so we could use a larger feed line.
With the belt drive we had to plug the ol passage at the front of the block because of the required machining to fit the Jesel front plate.
Robin
Attached Thumbnails Feeding LSx block oil from the rear plug-img_1108small.jpg
Old 05-06-2008, 06:50 AM
12 Second Truck Club
supersub's Avatar
WoW Robin! thats some Serious Stuff you got there! Can you hook me up with some of those valve covers??? SWEET
Old 05-06-2008, 07:03 AM
LS1Tech Sponsor
Robin L's Avatar
We got those from GM Racing last year when we were using the C5R heads. Jeff Stealy had to build a 1/2" spacer to get the clearance with the rocker arms.
We now have custom Moroso Valve covers that clear the rockers. I tried to get more valve covers last year but they have been discontinued. I had another set that were needed by another group in GM.
Robin
Old 05-06-2008, 11:05 PM
riggs55$$'s Avatar
Robin Can You Get Your Hands On The Paperwork That Comes With The Lsx Block I Gave Mine To Shop And Never Got Back And They Never Built The Motor So I Dont Want To Assy Without Please Help Thanks Mark. I Have A Fax If Thats Easy Pm Me Thanks Again
Old 05-07-2008, 08:27 AM
LS1Tech Sponsor
Robin L's Avatar
Riggs, PM me your e mail I now have the instructions in PDF. I will e mail them to you.
Phil
This hole
Attached Thumbnails Feeding LSx block oil from the rear plug-phillvetteoilmodded.jpg
Old 05-07-2008, 08:48 AM
7 Second Club
That is the hole we're feeding the oil to the engine. I had a plug in it to prevent dirt from getting into the motor.
Old 05-07-2008, 02:32 PM
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
cool pics
Old 05-07-2008, 08:40 PM
riggs55$$'s Avatar
thanks again robin. what lsx block # do you have?
Quick Reply: Feeding LSx block oil from the rear plug
