Questions on timing chain interchange - LS1TECH
Thread Tools Search this Thread
Old 05-06-2008, 01:19 PM   #1
Default Questions on timing chain interchange
I have a billet gear set for a ls1 and was wondering if I can use it on my ls2?
This is the timing chain. Thanks in advance
merriman44 is offline   Reply With Quote
Old 05-06-2008, 03:11 PM   #2
vettenuts's Avatar
I tried the Katech chain on the JP Performance set rolling the gear in my hands. It didn't seat right in the teeth. I would tread cautiously here, even tough pitch is the same, you could still have issues.
Which timing set?
vettenuts is online now   Reply With Quote
Old 05-07-2008, 09:46 AM   #3
Its a JP performance setup. Its a billet double roller. Basically it was given to me and I'd like to use it if possible since its brand new. If not I'll have to sell but don't know what these go for.
Old 05-07-2008, 02:39 PM   #4
vettenuts's Avatar
The JP is a nice set, but the LS2 and LS1 sets are different. Make sure you have the correct set and you will be fine. I misunderstood your original post, I though you wanted to run the LS2 chain.
Old 05-07-2008, 05:09 PM   #5
you can use the ls1 chain set on an ls2 due to the fact the cam sensor triggers off of the raised part on the ls2 top gear
Shawn @ VA Speed is offline   Reply With Quote
Old 05-07-2008, 06:37 PM   #6
Azrael's Avatar
Like Shawn said, or meant to say, is you can't use a LS1 timing set on a LS2 due to the cam timing sensor on the LS2 using a different trigger (the raised portion of the gear) than the LS1.
So no a LS1 set will not work on a LS2.
Azrael is offline   Reply With Quote
Old 05-07-2008, 06:57 PM   #7
yeah,i meant cant-typo
Tags
cam, chain, cloyes, double, ls2, problem, sensor, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
