Trick Flow 235/245 vs LS7 heads on 427?
Old 05-21-2008, 09:50 AM
Blue Meanie's Avatar
Default Trick Flow 235/245 vs LS7 heads on 427?
Hey everyone I ran search after search and can find very little info on anyone that has run Trick Flow 235 or 245 heads, just one dyno graph. I am putting together my LS7 right now and was going to go with PRC LS7 heads. Since my Trick Flows made such awesome power on the 346 I thought I would give them a fair shake. I like the idea of a complete LS7 motor, but if the trick flows will give me 20+rwhp/tq across the board over PRC LS7's that is something I can't pass up. If I missed another set of heads to consider please let me know.
Its going to be a daily driver and cammed so it can be driven by the wifey. Which means lopey but easy launches and little surge.
BM
Old 05-21-2008, 10:10 AM
LS1Tech Sponsor
TrickFlowTech's Avatar
Default Check this out
https://ls1tech.com/forums/showthrea...ght=flow+trick
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 05-21-2008, 10:13 AM
That is the one that I have seen. i just want to hear from people that have them.
Old 05-21-2008, 10:18 AM
MPM IV's Avatar
What do you want to know? If you look at post I've made you will see my dyno sheet also.
Old 05-21-2008, 02:28 PM
Thanks man, I finally found a whole slew of posts about both heads (not much on the PRC's). Power wise it seems to be a wash, more under the curve on the cathdral heads but lower revs from the choked FAST. All I see are monster cam setups though, and I can't have that again, my wife hated it. Its pretty much the whole reason I am doing this all over again so soon. Your cam's street manners sound EXACTLY like the car is now.
I am more confused than ever.
My love for the Trick Flows I have now pulls at me. They were so sick on the 346, what'll they do on a 427....
Old 05-21-2008, 02:40 PM
Ron@Vengeance's Avatar
FWIW,
We built a customers 440 with s 262/270 duration camshaft and it made 609/556... Customer got tired of driving the big cam around... We installed a new stick in the 24x/25x range and the car drove 10x better and actually made an ADDITIONAL 60 ftlbs UNDER the curve and only lost 6rwhp peak...
TFS any day of the week!!!!!!!!!
Old 05-21-2008, 02:53 PM
Your doing a good job of convincing me. You're gonna port my intake this time though, those tiny files I have took way too long. I'll be calling as soon as the bottom end is together.
Old 05-21-2008, 03:36 PM
LS1TECH Sponsor
Vengeance Racing's Avatar
235's IS the only way to go for your setup.
Old 05-21-2008, 04:06 PM
2000_SS's Avatar
i'd like to see the 245's compared to a ported LS7 myself....
Old 05-21-2008, 04:34 PM
RayZ06's Avatar
Here is a link to my buddys 03 Z06 converted to automatic and a Scoggy Dickens 427 with 235 Trick Flows and a custom Vengeance cam.This is a Daily Driver!.Video in first Post.
Ray T
http://www.fastlsx.com/forums/showthread.php?t=17587
Old 05-21-2008, 05:30 PM
tcr98taws6's Avatar
LSX 454 with Trickflow 235's in my setup. It was designed to be a daily driver (reality is it's a weekend cruiser, but it has great street manners). Started off with a big cam (266 duration) and it was to radical for street driving....hated anything under 2,800 rpm with the 6 speed. So we changed the cam to 253 259 on a 114 and it runs great now. Still doesn't like 2,200 and below, but I don't drive there anyway.
Power remains right at 600 RWHP and 575 RWTQ. I cannot put the power to the ground without slicks in 1st or 2nd gear and I run 315 Nittos out back. Power is instant at any throttle position all the way to 7,200 RPM. In 1st gear when launching on the street I spend less than 2 seconds in 1st gear and the shift light comes on. 100 MPH is very fast. You will not be disappointed.
Old 05-21-2008, 05:59 PM
Bill00Formula's Avatar
tcr98taws6 - have you had it to the track? Sounds like an awesome setup. Just wondered what the trap speeds are.
Thanks
Old 05-21-2008, 11:12 PM
It looks like I will once again put my faith in Trick Flow. Guess the bonus is i only need the Shortblock and Heads, everything else is ready but the fuel pump and I need a set of 1 7/8 headers.
Old 05-21-2008, 11:19 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm a large fan of cathedral port heads. A lot of the newer stuff out now can't compete when it comes to throwing down real dyno / track numbers. They'll catch up eventually, but for now the cathedral heads still reign supreme.
Old 05-22-2008, 10:17 AM
Greg Fell's Avatar
another very satisfied TFS customer. I had an LS7 setup on a 422, and now a TFS 235 on a 440...so its not apples to apples, but its night and day more tq and peak power. Get the TFS!
Old 05-22-2008, 10:24 AM
gold87TBI's Avatar
235's tfs also on my 454lsx hopefully ill make some huge power also
also run 235's on my brothers 408 making 500+ threw a 4l80e tranny on a truck on motor
Old 05-23-2008, 09:16 AM
LS1Tech Sponsor
It is GREAT to see so many satisfied customers!!!
We hope to see alot of you guys out at the LSX shootout this year!!!
Thanks
Trick Flow Tech
__________________
Old 05-23-2008, 09:46 AM
John02SS's Avatar
I do a bunch of TFS heads at my shop and they perform EVERY time. My 347 with TFS 215's made 500 rwhp thru a 12 bolt on slicks. I should have my 427 with TFS 235's on the rollers in the next few weeks when we slow down at the shop. Call the guys at TEA, Brian and Mike are great to deal with!
Old 05-23-2008, 10:52 AM
Brian Tooley Racing's Avatar
Ray T
WOW, nice combination. What bore and stroke engine? What are the cam specs? and what torque convertor? Much thanks.
Old 05-23-2008, 11:05 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
TFS hats off you guys have done a great job of introducing new head offerings and supporting your customers. I might be putting together a few LS7's so I will for sure keep your heads in mind.
ADMIN
Quick Reply: Trick Flow 235/245 vs LS7 heads on 427?
