How does my plug look?
Old 05-27-2008, 03:58 PM
Haans249's Avatar
Default How does my plug look?
Hello All,
Been on my new motor for 4K+ miles now, so I pulled the spark plugs , and decided to see what everyone thinks. I'm not an expert at reading plugs, so I'm wondering what the experts do think!
Motor specs are
427ci LS2 11.28:1 SCR
LS7 heads/intake
242/256 .646/.668 113+3 comp cams
Tuned by myself - WOT AFR set at 12.8-13.1 at 28 degrees timing no KR
EFILive COSv5 dual LC1's, Open Loop SD.
TIA,
Adrian
Old 05-27-2008, 04:42 PM
needadvice's Avatar
pretty good.
what RWHP/RWTQ did it make?
Old 05-27-2008, 04:48 PM
Haans249's Avatar
500rwhp/450rwtrq on a mustang dyno with a terrible flowmaster 80 series, which is only good to 500 horse haha. I've done a couple other intake mods, new ARH 1 7/8, noticed higher map KPA's, and higher duty cycles when tuning, so probably closer to 510-515 or so rwhp. Also will be getting tru duals, 3" soon.
anyway, anyone else?
Old 05-27-2008, 05:12 PM
Grimes's Avatar
looks good. im assuming the flash made the plug look whiter than it really is?
Old 05-27-2008, 05:20 PM
Haans249's Avatar
A little, the tip is a little white, so it might be a bit lean.
Old 05-27-2008, 05:43 PM
dlove's Avatar
you need to pull a plug directly after a run (no driving on the return road) and then also get a pic of down the center
Old 05-27-2008, 06:13 PM
needadvice's Avatar
were the heads hand ported or stock? what did they flow?
Old 05-27-2008, 07:48 PM
Haans249's Avatar
Heads are stock LS7 heads with Katech TI retainers and the PSI-LS1511 springs, with stock GM LS7 valves, stock GM rockers. Flow numbers are all over the forums, usually around 360 cfm at .650 lift for stock LS7 heads.
