418 head gaskets - what are my options? - LS1TECH
Thread Tools Search this Thread
Old 06-13-2008, 03:46 PM   #1
Default 418 head gaskets - what are my options?
4.08" bore x 4" stroke (texas speed).
what head gaskets are available other than Cometics?
i'm particularly interested in the different compressed thicknesses of the different gaskets. and for the 4.08" bore of the engine, what's the correct diameter head gasket to use?
quadman is offline   Reply With Quote
Old 06-13-2008, 06:05 PM   #2
bandit79's Avatar
It can really depend on how much compression you want to run. Most people would probably run a 4.085 or 4.090. You can't run too much bigger because of your small distance between the cylinders. I would see what Texas Speed recommends running since they are the ones you have the setup from.
bandit79 is offline   Reply With Quote
Old 06-13-2008, 06:19 PM   #3
LS1Tech Platinum Sponsor
Sales2@Texas-speed's Avatar
Thanks for the plug, Dave!! Long time no see!! I hear you're not working in Brownfield anymore?
To the OP: It is hard to beat Cometic when it comes to being able to build the gasket to your needs. We have all the most common bores and thicknesses in stock and can definitely take care of you on whatever you need!
Sales2@Texas-speed is offline   Reply With Quote
Tags
418, gaskets, head, ls, ls3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
