stock 6.2 cam only
stock 6.2 cam only
ive been told a few times to throw these shortblocks away and just use a iron lq9 block.
that any decent sized cam would smack the piston?
any insight on using stock block with stock heads and just a cam?
Since you are here in Michigan, can I have it if you want to throw it away? On a serious note, who told you that nonsense. Don't let them give you anymore advice on your build.
Its a 4.060 bore, bot 4.6 just for clarification. All it is in reality is a .060 over LS2. 376 cubes instead of 364. And the PTV would need to checked on any build.
The vary reason I went with Diamond pistons made for the L92 heads so as not to ever worry. While I was at it I installed Scat H-beams. Now I can run a safe 300 shot of nitrous.
