How high could I safely rev my 402?
I understand that on a stock LS1 the rod bolts limit you, unless you are very brave, to under 7000 rpm. So what limits how high you can rev a fully built engine?
My 402 has a Callies Dragonslayer crank, Callies Compstar rods, Diamond -18cc pistons, ARP main studs, ARP rod bolts, ARP head studs, AFR 225 62cc heads, LS2 timming chain, hardened pushrods, stock rockers. I'm not sure what valve springs are in the heads but they are AFR dual springs that are supposed to be able to handle the cam I have. If I remember right the cam specs are 237/248 .650/.657 114 LSA
I should be done with everything withen the next couple weeks and it will be off to the dyno. I had planned on starting out at 6500 and bumping it up from there depending on how the hp curve looked. The goal is to hit 850rwhp with pump gas and meth injection with the F1A. I was just wondering where I should call it quits if the HP curve is still holding strong. Does piston/rod speed limit this setup with the 4" stroke?
Yea, the stock rockers will work just fine. I do have to say though, that I highly recommend getting them modded by Harland Sharp, I always fear the needle bearings falling out, so I had my LS7 rockers modded, and they're working out great. FWIW, I'm running a 4" stroke in my 427, and spin it to 7,000 rpms. I don't think you'll have a problem hitting that number with your setup. Just watch out for any signs of valve float.
Actually I made a mistake. I just went over the information again. They are actually -28cc pistons. Not that it matters but I figured someone would eventually catch the mistake.
You are right about the valvetrain. After speaking with a couple of the sponsors it seems that the lift on this cam is way to high and would most likely cause valve float issues when combined with boost. I'll be swapping the cam out for one with lower lift
