Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation IV Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-02-2008, 10:42 PM   #1
Trader Rating: 0
Default 500whp NA stock bottom LS2 GTO....
can this be done? i was thinking L92/LS7 heads with ported LS3 intake and a 23X/23X or 24X/24X. with kooks 1 7/8 non catted exhaust of course. and im not one of those nancys that "doesnt want to loose my low end even though i could get 50whp top end people."
give it to me straight, can this be done? and feel free to modify my "suggested" setup, thank you.
it will get driven a lot in the summer so i want some streetability of course but willing to sacrifice to make hp.
02GTP is offline   Reply With Quote
Old 09-02-2008, 10:46 PM   #2
05JUDGE's Avatar
Trader Rating: 16
I'm definately not saying it can't be done, but it would sure take a perfect combination of parts. If you are running an M6 it will be much eaier. An A4 will be a huge challenge. I'm running a 427 stroker and making 502rwhp. But as anyone will tell you. The dyno numbers don't win races. The track speaks it all.
__________________
2005 GTO Midnight Blue A4 1 of 368
New Setup coming soon!!!
Old Setup:My GTO, Open Headers At Idle, The Dyno, First 1/4 mile with 427, Idle & Rev - Magnaflow, 60-140mph Acceleration
05JUDGE is online now   Reply With Quote
Old 09-02-2008, 10:57 PM   #3
Trader Rating: 0
it will be an M6. im looking to get a 123-125trap speed with 200lb of weight reduction. and i think 500whp will get me there.
Old 09-02-2008, 11:02 PM   #4
04gtoBMXracer's Avatar
Trader Rating: 23
Send a message via AIM to 04gtoBMXracer Send a message via Yahoo to 04gtoBMXracer
theres a couple 500+hp heads/cam LS1's should be possible with an LS2
__________________
04gtoBMXracer is offline   Reply With Quote
Old 09-02-2008, 11:05 PM   #5
05JUDGE's Avatar
Trader Rating: 16
Quote:
Where are you located? If you are near sea level and have a good track and good air, it might happen. The only problem I see is that to date, I know of only 2 GTO's that have trapped that high N/A and a stock bottom end. Both of which were built by Cartek. Like I said before, it would have to be a perfect match of components. You might also have to invest in a set of 3.91's in the rear end.
__________________
Old 09-03-2008, 06:48 AM   #6
Trader Rating: 0
I run 535rwhp in my GTO everyday on a stock bottom-end. Mine is supercharged (13psi boost) w/meth and a very rich tune. I run it hard shifting at 6850rpm and it's holding up very well. Keep the tune rich and you shouldn't have any problems. I have a friend that has 700+ rwhp (APS twin turbo) GTO and didn't have problems (stock bottom) until he lost fuel pressure, went lean and broke the #7 piston ring land. When it was disassembled, everything was in perfect condition. No crank twisting, damaged rods or any damage at all. This doesn't mean there will not be problems at some point with our pistons/rods. If you want to be really safe, you can get a Compstar rotating assembly for ~ $2000. They're excellent parts for the money, come fully balanced and ready to assembly. You would just need to have the block machined and you're ready to assembly/go.
Jontall is offline   Reply With Quote
Old 09-03-2008, 08:24 AM   #7
WKMCD's Avatar
Trader Rating: 1
You can't run LS7 heads on your stock block nor will an LS3 intake manifold work on LS7 heads. There are plenty of good threads here already. Do a little searching and reading.
__________________
521/480 (Honest Numbers) N/A LS2 403, WCCH L92 heads, Custom little BRE Justin Timberlake Cam, AR 1 7/8 Lt's w/ cats, Ti's, RAM DD clutch, RPM 3.90's
WKMCD is online now   Reply With Quote
Old 09-03-2008, 09:47 AM   #8
05JUDGE's Avatar
Trader Rating: 16
Quote:
The OP is asking about making 500whp N/A though.
__________________
Old 09-03-2008, 10:00 AM   #9
Phantom_LS2's Avatar
Trader Rating: 1
AFR or ETP heads, huge cam, ported fast 92, full exhaust, upd, and an electric water pump with an M6 and you'll be right at it. Gonna be expensive though. It'd be cheaper to just slap a procharger on it. Make more power too.
__________________
Phantom_LS2 is offline   Reply With Quote
Old 09-03-2008, 10:08 AM   #10
05JUDGE's Avatar
Trader Rating: 16
Quote:
That's exactly the thoughs i'm having about this. That's why I just built a stroker. I spent more money, but I also made alot back from selling my old stuff and stock motor and ended up offsetting the cost greatly. I think added up, If I subtract out what I sold that went toward my stroker, I spent less than $6500 total. That includes kooks headers, and my stall converter.
__________________
Old 09-03-2008, 10:24 AM   #11
hymey's Avatar
Trader Rating: 0
GMmotorsports are running high 10s 128mph on 6L stock L92 heads, 237 242 112(Turbo Killer) cam.(it fits)
A few other guys are getting 119mph with 224 228 cams.
__________________
2008 VE SSV ute M6
6.0L L92 heads, built engine comp xfi cam, 4 into 1 headers, dual 3 inch system. Vortech T trim blown and intercooled.
hymey is offline   Reply With Quote
Old 09-03-2008, 12:32 PM   #12
LS1TECH Sponsor
Ryne @ CMS's Avatar
Trader Rating: 8
Send a message via AIM to Ryne @ CMS
i think with a large camshaft, fully ported fast 92 and nice trickflow/etp, or any other similar head, plus an over the radiator intake, you could make 500 rwhp
__________________
Ryne Cunningham
Cunningham Motorsports
Specializing In Late Model EFI Performance.
Lake Elsinore, CA
Shop: (951)471-2898
Cell: (951)375-2453
Ryne-CMS@Hotmail.com
VP RACE FUEL IN STOCK MS109(Unleaded) & C16
Remote Clutch Speed Bleeders available for F-body, GTO, C5/C6 Corvette
Full Dyno Tuning, 1,2,3 Bar
Dyno Dynamics 450DS Dyno
04 Z06 10.03 @ 137mph
05 GTO 10.1 @ 137mph with a beat ass clutch!
08 Z06 488whp 435wtq intake and tune
Ryne @ CMS is offline   Reply With Quote
Old 09-03-2008, 01:37 PM   #13
05JUDGE's Avatar
Trader Rating: 16
Quote:
Who makes an OTR intake that is available? I have been looking for one for a long time.
__________________
Old 09-03-2008, 05:53 PM   #14
Kingsize's Avatar
Trader Rating: 7
can this be done?
Yes it can... See Sig Below! Stock bottom end 500RWHP N/A spinning to 7000rpm using the (Junk) Dart 225 heads untouched.
That was before the:
Shaft Mounted Rockers
Lightweight Twin Disc Clutch
Prototype OTR Vararam Cold Air Intake
& through the stock air box.
I am also looking at getting an electric water pump & a carbon fiber drive shaft just to get a little more out of it. I feel 515RWHP on stock bottom end shouldn't be too much of a challenge. Good luck!
__________________
Tow Rig:2003 Duramax LB7 w/ Allison Transmission, PPE Boost Valve, 20" Centerline Forged Wilderness Flint Wheels, 38" Toyo Open Country M/T Tires, 8" Fabtech lift, Trailer Brakes, 5th Wheel hitch for the Toys!
GTO 500RWHP N/A Stock bottom end LS2
Idle Clip>>> http://www.youtube.com/watch?v=s2rKmw2DDZY
N/A 500rwhp Dyno Pull>>> http://www.youtube.com/watch?v=z21MepuHe2g
www.fquick.com/Kingsize - http://www.myspace.com/kingsize007
Kingsize is offline   Reply With Quote
Old 09-03-2008, 07:10 PM   #15
Trader Rating: 0
It can be done, but it'll take doing a lot of the small upgrades as they add up. Maybe even port match TB to intake manifold, intake manifold to heads.
__________________
06 BMW M5 & 05 C6 Z51 - LG longtubes/B&B Bullets/LG G6X3 Cam/AFR205 Heads 62cc/LG Carbon Fiber Driveshaft/Rockland Race Tranny/3.90 geared Diff/FAST 92 PORTED/Ported TB/LPE CAI/TUNE/UD Pulley.
Corvette Videos
Seek4home- Real Estate Listings
Nature's GRASP!
Tavarez is offline   Reply With Quote
Old 09-03-2008, 07:11 PM   #16
Zen Master of horsepower
BigBronco's Avatar
Trader Rating: 2
I came in here to make mention of your car and a couple other setups. The combination and tune will be spot on to hit the numbers though.
As for your cam shaft selection, the lower to mid 23X's will not cut the mustard with most lower end L92 based cylinder heads I would imagine.
__________________
I like engines.
www.SAMracing.com
BigBronco is offline   Reply With Quote
Old 09-03-2008, 08:47 PM   #17
Trader Rating: 0
thanks for all the replies. i was told i had to be careful with a huge cam with the L92's and stock bottom because of PTV issues. so ported L92 heads with a ported LS3 intake/tb a big cam with 1 7/8 non catted exhaust with ud pullies and an electric water pump should do it with a good tune? and i dont wanna go forced induction (yet) because of heatsoak issues as well as the best power is all motor power.
Old 09-03-2008, 09:00 PM   #18
Trader Rating: 0
123 to 125 trap speed with 500hp. I have 500hp in a 3,700lbs car and I trap over 128mph. with my new cam I think i'll be around 130mph in the 1/4mi N/A. I also have l92 heads.
mike c. is offline   Reply With Quote
Old 09-03-2008, 09:07 PM   #19
Louis @ LGM
Louis's Avatar
Trader Rating: 5
Quote:
Careful what you say. Bigger is not better like with the cathedral ports.
__________________
Louis@LGMotorsports.com 972-429-1963
Cyber Grey 09 Z06 Stock for now....
01 SS A4
520/520 SAE Dynojet 2 psi, 402 CID LS3|G7x1 cam| 11.0:1 SCR|PT88| 4" down pipe|Stock catback just getting started
www.LGMotorsports.com
www.LGMRacing.com
Louis is offline   Reply With Quote
Old 09-03-2008, 09:27 PM   #20
Trader Rating: 0
what is your exact setup?
Tags
05, 14, 500, 500whp, 500wrhp, cam, complete, corvette, gto, heads, hp, kits, ls2, mile, stroker
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
