VR1 Racing oil
Old 10-31-2008, 09:14 AM
  #81
Haans249's Avatar
Originally Posted by LSGunZ28
Got it...
Ok since I have 4 qt of Rotella T in my engine ( I dont wanna waste it) Im gonna add 2 more qt of VR1 and I have some STP additive, its a 15oz bottle, maybe I only put 1/3 of the bottle (it says it contains ZDDP)...and this mixture im gonna let it idle till full temp , then change oil + filter..
Then next time I will use 6qt of VR1... and a full bottle of EOS until 20 miles driven... and repeat... again til 120 miles... EOS is hard to obtain here so I may use STP instead..(if this is okay) - but I heard someone saying red bottle, but mine is a blue bottle...
so is my use of RotellaT terrible? , I will only be idling it the first time...
or is my plan bad and I should just drain that unused Rotella T and just use 6qt VR1 from the start??
also 20w 50?? or something lighter?
because I was using mobil 5w30 before in my LS1, I understand this is a new motor, but the whole life use VR1??
sorry I hope all these make sense...
All of that sounds fine. I would just add the whole bottle in the beginning of the STP additive. Blue bottle is fine, its just a thicker oil (i believe, I can't remember if the red or blue is thicker) but they are the same thing.
Forget the EOS since it is hard to get a hold of, and use the STP bottle instead, it'll do the same thing, and run the VR1 exclusively after you run the rotella and vR1 together.
Pretty scared about using the 28# stock injectors actually, just make sure that you're not going WOT, and or make sure that you have your log file with a wideband sensor going before you drive it, because those things will not come anywhere near fueling your motor. Running too lean with fry your rings on a new motor as well, and do some serious damage.
Old 10-31-2008, 01:14 PM
  #82
LSGunZ28's Avatar
Im not gonna go WOT above 4000rpms, so its fine, I got assurance from 2 respected people, one from this forum..
Old 10-31-2008, 11:54 PM
  #83
Haans249's Avatar
Good deal! Just makin sure you weren't planning on any WOT runs with those injectors!
When is the motor going to get started? It seemed like its been almost 3 months now...
Old 11-01-2008, 06:27 PM
  #84
LSGunZ28's Avatar
installing rockers wrong, using arp studs vs the original bolts I had, having to re order parts, changing shop locations, etc.. all have taken time away from my engine build.. mainly waiting on parts... so Hopefully, since my engine is done... Im just waiting for a t-56 rear seal, I will put the trans and motor back in the car on monday and maybe fire her up monday or tuesday... or sometime next week...
hopefully..
Old 11-03-2008, 08:50 AM
  #85
WADDISME's Avatar
Where do you get the STP oil additive? Is it labled as their "OIL Treatment" in the blue bottle? I will have 500 mi on new LS2 with Rotella 15-40 tomorrow. I have some VR1 20-50 and would like to do the STP if I can find it. Thanks
Old 11-03-2008, 12:08 PM
  #86
Haans249's Avatar
Yes, I believe the "oil treatment" in the blue 15oz? (i can't remember the measure, but its small) bottle is the stuff you're looking for. Read the back, and it should say its heavy in zinc etc...
LSGun, Good luck man, sorry to hear of all the issues!! You should take some pics, and post them up!
Old 11-03-2008, 01:00 PM
  #87
LSGunZ28's Avatar
Thanks I will...
The SPT Blue additive, I think may be called oil treatment...
But yes it is 15 oz and it says ZDDP in small letters in the front, I saw them at autozone and kragen, but even at walmart, so its popular...
Old 11-03-2008, 01:55 PM
  #88
WADDISME's Avatar
Thanks.
Old 11-03-2008, 05:37 PM
  #89
ramairws6's Avatar
So if a guy was to use this VR1 oil what would be the recomended weight? 20-50?? I run the Rotella 15-40 now and it seems to be working well. Traver
Old 11-03-2008, 05:42 PM
  #90
Haans249's Avatar
I personally run 20-50 oil because of the clearances in my motors. Oil weight recommendation would be on a case to case basis.
Old 11-03-2008, 05:43 PM
  #91
Tom@SpeedInc's Avatar
I run 20W50, as I would recommend for anyone with forged crankshaft/ H series bearings.
Something interesting
http://www.valvoline.com/downloads/2008-003a.pdf
Old 11-04-2008, 07:58 AM
  #92
WADDISME's Avatar
That is was a good read. Actually their whole website almost mirrors this thread. Seems like the SynPower provides pretty much what everyone is looking for. Might be a better alternative to the Mobil 1. Thanks for the link.
Old 11-05-2008, 03:13 PM
  #93
WADDISME's Avatar
For my 500 mile oil change, I put the 20W50 in last nite with a bottle of the STP. That should hold it until the 1000 mile oil change. Motor is forged but not sure about bearings. The rods are H beam so I guess the bearings are.
Old 11-05-2008, 04:05 PM
  #94
Haans249's Avatar
Having H beam rods have nothing to do with what bearings you run. The H-series bearings are for crankshafts that have increased fillets on the journals, and the bearings have increased chamfers which increases clearances between the bearing and the over-sized fillets on the crank.
Your oil choice is looking good.
Old 01-28-2009, 11:15 PM
  #95
Jditlfm's Avatar
If anyone cares i called Valvoline tech line today and they recommend changing the VR1 at 3,000 miles. They said it should have no problem lasting that long at all.
Quick Reply: VR1 Racing oil
