LY6 Throttle Body
Old 09-08-2008, 04:58 PM
ddcarter's Avatar
Default LY6 Throttle Body
Does anyone know if the LY6 throttle body can be used on a LS2 intake manifold in a C5
Old 09-08-2008, 05:10 PM
N4cer's Avatar
Is it a bigger bore than stock?
Old 09-08-2008, 05:22 PM
ddcarter's Avatar
It is 90mm. It looks to me to be more of a compact design than the ls2.
Old 09-08-2008, 06:10 PM
quikrnmost's Avatar
You can use it.
It is measured at 87mm, thought some call it a 90mm. So it is slighly smaller than a LS2 TB. It does use the same connector as the LS2, so it should be a direct swap.
Old 09-08-2008, 06:27 PM
ddcarter's Avatar
Hey thanks that is what I needed to hear!
Old 09-24-2008, 08:30 PM
ddcarter's Avatar
Will there be hood clearance problems?
Quick Reply: LY6 Throttle Body
