LS3 swap....
Old 09-16-2008, 08:29 AM
Redls2gto's Avatar
Default LS3 swap....
I might have a dumb question and then i will need a dumb answer...lol...jk. I was wondering how much total would it be to drop a LS3 crate motor into a f-body? What would i have to do to the tranny as far as upgrades and what not? OR would it be easier to do a 408 stroker, or rebuild the motor of the stock LS1 and forge the internals??? Which one would gain more HP and which one would be cheaper?!? Thanks guys.
Old 09-16-2008, 08:59 AM
99blancoSS's Avatar
Bigger will always make more power. Cost for my siganture series 408 is $4474, the ls3 416 is $5174.
Old 09-16-2008, 09:10 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Shoot me a PM with some details about what you're wanting out of the swap (power goals, driveability, budget, etc) and I can put together a detailed quote for you that fits your needs best!
The extra cubes will make better power, not just at peak but from idle to redline! The downside to the 408 iron motor is ane extra 80-9lbs on the front of your car. Let me know if I can help
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-16-2008, 09:17 AM
99blancoSS's Avatar
Oh ya one more thing. The 408 is a direct swap and wont require a conversion kit where the LS3 will so it increases the final cost of the engine.
We measure the difference at 75#'s between the aluminum and iron blocks. Most body guys don't seem to mind the added weight where most Vette guys prefer to stay lighter.
Old 09-16-2008, 04:47 PM
VGLNTE1's Avatar
overall cost of my LS3 was about 10k when it was all said and done. heads, cam gaskets, tune, fluids, bolts, all the little dime and nickle **** that gets ya
I got the 416 LS3 from scoggin dickey. i think it was abotu 5k for the short block.
Quick Reply: LS3 swap....
