Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
L83 L93 Gen V How to Kill a Vacuum Pump
Old 06-23-2016, 10:57 PM
mzrico's Avatar
Default L83 Harness from Current Performance Wiring
Originally Posted by gthmcty1
Any word back from current performance about your harness?
Jared tried very hard to help me trouble shoot the harness over the phone. No luck, so off back to Current Performance my harness and ECM went. Jared told me he will work on it as soon as he gets it. As soon as I get it back I'll report results.
I got good results with my oilpan swap. I'll post my photos soon under a new title :
L83 oilpan swap.
Thank you.
Old 06-23-2016, 11:14 PM
mzrico's Avatar
Got lots of help over the phone from Jared at CPW but no luck. I took the harness off and sent it back for more work. As soon as I get it back I'll post results.
My oilpan swap is going well. I'm starting a new post on oilpan swap soon. Here is a preview :
Attached Thumbnails L83 L93 Gen V  How to Kill a Vacuum Pump-20160623_174857.jpg   L83 L93 Gen V  How to Kill a Vacuum Pump-20160623_175344.jpg
Old 06-24-2016, 11:05 PM
gthmcty1's Avatar
Originally Posted by mzrico
Got lots of help oer the phone from Jared at CPW but no luck. I took the harness off and sent it back for more work. As soon as I get it back I'll post results.
Nice looking pan, I need one of those!!
Old 06-25-2016, 12:01 AM
mzrico's Avatar
GM 12666386 is the part number. It fits nicely.
Old 06-25-2016, 02:14 PM
gthmcty1's Avatar
Thank you wow that pan is expensive lol, but hey what else is new!
Old 06-28-2016, 09:42 AM
mzrico's Avatar
Default L83 oilpan frame clearance.
These photos show the modified frame and frame mounts to lower the L83 to position. Thanks for the positive responses.
Attached Thumbnails L83 L93 Gen V  How to Kill a Vacuum Pump-20160626_183539.jpg   L83 L93 Gen V  How to Kill a Vacuum Pump-20160623_192859.jpg   L83 L93 Gen V  How to Kill a Vacuum Pump-20160626_191012.jpg   L83 L93 Gen V  How to Kill a Vacuum Pump-20160626_190803.jpg
Old 07-03-2016, 01:55 PM
brandon6.0's Avatar
any word on the reworked harness. I need to know how deleting the vaccum pump works for u. I have the same setup ready to swap in a customers c10.
Old 07-03-2016, 02:58 PM
mzrico's Avatar
Finally on Thursday Jared got to my harness. So far it looks like a Computer program issue. As soon as I get back I will post my results. Thanks for checking in.
Old 07-06-2016, 09:27 AM
gthmcty1's Avatar
Sweet man keep us posted, I'm at the stage where I'm about ready to send mine out.
Old 07-09-2016, 08:59 AM
Jimbo1367's Avatar
This looks ALOT better looking than either (truck/vette) FEADS
Old 07-17-2016, 12:48 PM
mzrico's Avatar
Hello. Glad to inform you that my harness came back from Jared at Current Performance Wiring. The problem was simple, the ECM was programed for a Corvette pedal, I have the truck pedal. That was enough to trigger a no start condition. After installing the harness with the correct program, the engine started right away.
Jared change my oil level sensor plug to the Corvette plug (I swapped my oilpan to the Corvette pan). Also I asked him to add 2 extra wires for after market oil and temperature sensors.
Now we have to figure out how to get speed and tach signals from this set up. All suggestions are welcome.
Old 07-18-2016, 07:22 AM
  #32
Deloss's Avatar
Glad to hear everything worked out! I will be ordering my harness soon.
Old 07-26-2016, 12:59 PM
  #33
gthmcty1's Avatar
Glad to hear it was something simple! I will be sending mine out this Friday!
Old 07-28-2016, 11:46 PM
  #34
onetype's Avatar
Doing the same swap in a bagged '65 C10 right now. Going to cut some block off plates on the waterjet.
Old 09-23-2016, 07:01 PM
  #35
1978LT1's Avatar
sweet thread. Any updates yet. I am planning on doing something like this in the near future but i want to use a T56 magnum trans and L83 on a second gen camaro.
mzrico: Does the camaro LT1 pan fit? the corvette pan is pricy
Also, has any one tried the ICT billet motor mounts and the accessories mount kit (especially power steering). They look reasonable.
has the vacuum lines worked?
Anyone with headers?
Old 09-25-2016, 07:56 PM
  #36
1975delta88's Avatar
I used the ICT Billet Motor Mount adapters for my 72 El Camino, the Camaro SS pan worked for my swap, the K member had to be trimmed a little. Dirty Dingo is what I used for the front end accessory drive. I used a Chevy Performance ECM and harness. I went with an Auto 4L65E, so I had to use a separate TCU. With a manual, you don't need to have a TCU. Not sure if the vacuum works on the truck manifold, I went with hydroboost.
Old 09-26-2016, 05:00 PM
  #37
1978LT1's Avatar
Thanks for the info...
What about fuel lines, tank and pressure? I am interested in knowing how the fuel is delivered from the tank to the on motor high pressure pump. According to chevy performance LT1, "A fuel flow rate of 45 gph at 72 psi (500 kPa) is needed". Also in the chevy performance harness kit, Fuel Line Pressure Sensor, Fuel Pump Power Module are provided. So where do these go and in the L83 engine do you have similar mechanisms?
Also from reading, the L83 is short, height wise, and would fit under the hood with no clearance issues.
Anybody using dirty dingo engine mounts and ICT billet accessories? ICT billet seems cheaper than dirty dingo...
Old 09-26-2016, 08:43 PM
  #38
The fuel line pressure sensor is mounted inline with your fuel line from your pump to the fuel rail. The Fuel Pump Power Module is mounted as close to your fuel pump
"The Fuel Pump Power Module should be mounted as close to the fu el pump as practical and the wires powering the fuel pump
must remain twisted. If additional length is needed, maintain a twist of 27 turns per meter or 8 per foot to ensure adequate
protection from Electromagnetic Interference with the rest of the vehicle (i.e. radio and other control modules). The Fuel Pump
Power Module is fully sealed and can be mounted in any orientat ion but best practices should be maintained (i.e. away from heat
sources, maintain adequate clearance to moving parts, maintain adequate ground clearance, connector pointed in a downward
direction to prevent water intrusion etc). look up Corvette mounting for connector orientation)"
I used a Camaro ZL1 fuel pump, same as a Corvette. Restomod tanks (Ricks Tanks) is where I got my El Camino tank. These tanks have a provision to use this pump. They are supposed to come out with a 70-73 F body tank in december 16, but I'm sure there are other tank/pump combos you can use.
My L83 does clear the hood on my El Camino, but since the throttle body points up a little, the shop had to notch the hood a little bit to clear the air intake tube.
Old 09-26-2016, 09:11 PM
  #39
1978LT1's Avatar
Also do you think its better to use the chevy performance LT1 Crate Engine Control System module or go through the a place to mod your wiring harness etc. What's your take? Do you think one is better than other? Did you have any problems with the chevy performance? or was it just plug and play?
Old 09-26-2016, 11:11 PM
  #40
I chose the Chevy PP LT1 Controller versus Speartec because it was less expensive . The kit came with the instructions, where to place the fuel power control module, showed what type of pump to use, etc. They basically made it easier for me in the appiication that I was going to use it in.
Quick Reply: L83 L93 Gen V How to Kill a Vacuum Pump
