Gen V with 4l80e
Aren't LS9 and LSA's 8bolts? LSA are part of GMs Connect and cruise package. Are the flexplates interchangeable?
LS1Tech Sponsor
http://shop.brutespeed.com/searchqui...eywords=915737
ATI makes an 8 bolt flexplate, shown here. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
In my case I am trying to mate up a ATI T400/Treemaster converter. John At ATI had a kit 915737 that would work. TCI had one flex plate for a 8 hold application. I dont know if they have the kit. I would call ATI. The other way I was thinking LSA flex plate with the puck for the conversion. Several things to think about and some companies to call. A 4L80E will have two miss matched holes TCI did not have a problem with that. The only other way for all the bolts to line up is a 4L75E with the removable bell housing designed for a gen 5 motor
Use this part number then. The Gen Vs don't have provisions for a 4l80/85 trans to work with it in the catalog. But I do know the Gen Vs has the same flex plate as an LSA. I used a built 4l65E with the Gen V Bell housing on my swap.
19125597
8-Bolt Crankshaft Adapter Kit – LSA/LSX454
• Use with LSA, LSX454 and LSX454R crate engines with
8-bolt crankshaft flange
• Includes flexplate, adapter hub and hardware
• Provides the correct converter pilot support for production
4L80/85 style torque converters
• Conventional 6-bolt flexplates do not bolt up to LSA and
LSX454 engine
19125597
LSX454 engine
. Use this part number then. The Gen Vs don't have provisions for a 4l80/85 trans to work with it in the catalog. But I do know the Gen Vs has the same flex plate as an LSA. I used a built 4l65E with the Gen V Bell housing on my swap. 19125597 8-Bolt Crankshaft Adapter Kit LSA/LSX454 Use with LSA, LSX454 and LSX454R crate engines with 8-bolt crankshaft flange Includes flexplate, adapter hub and hardware Provides the correct converter pilot support for production 4L80/85 style torque converters Conventional 6-bolt flexplates do not bolt up to LSA and LSX454 engine
Bump to show latest post....
edit- it worked!
edit- it worked!
The following 2 users liked this post by CapriceLS:
Brialgon (05-26-2023), Smokin92z4 (03-04-2020)
I’m interested in the flexplate and snout 250$ please email me
