New LT1 for 2014 6.2l alum block
#201
LS1Tech Sponsor
"Rob"
The fuel event system will not be tunable in the after market...why are someone people not understanding that the fuel tables concerning this particular engine is completely and totally off limits? The ECM is only tunable from GM servers if and when problems arises as a virtual client ECM.
Sure the someone can develop a standalone ECM to run the engine. But only after research, reversing engineering and then development. Find a supplier of quality electronic components and boards. Then you have to deal with testing and regression analysis. This ECM uses a superior processor. The cost of this is substantial far out weight any performance gains for the consumer. If possible wait until the official outputs on the LT1 VVT are out. If this engine isn't enough in power something on the horizon will tickle your heart.
Stay positive this isn't the end all of performance.
This is for your safety.
Bigg Gunz
Bigg Gunz
Mopar released their own tuning software, which will still require the tuner to have the file uploaded to the Chrysler server to have the file 'signed', so it can be flashed to the ECU without bricking it, yet we are able to get in, read the stock tune, apply our changes, and get out with no problem.
I dont know if you are familiar with the encryption they used, or if it is in any way similar to what you are dealing with here, but I work with a lot of really talented people that have lead me to believe NOTHING is impossible, and they prove it to me time and time again.
You wont ever convince people around here that the car will come with 'enough power'....there is no such thing
As long as people want more, and there are talented people out here working to bring them more, it will happen
#202
Kleeborp the Moderator™
FWIW...until last Tuesday, anyone with a 2011+ Chrysler vehicle with the NGC4a or GPEC2 PCM was stuck in the land of the 'untunable'...until we cracked their encryption after 2+ years of development.
#204
LS1Tech Sponsor
either they'd have to start selling 10X more Vipers then they do, or we'd have to be selling $1500 handheld tuners to be able to justify the engineering costs....its a shame they dont use a common PCM in any of the newer Vipers, like GM does with Vettes/Camaros/Trucks/etc...
#205
#206
Not to nerd this back up but like I mentioned in previous posts there are ways around SSL/TLS
http://www.roe.ch/SSLsplit
SSLsplit is a tool for man-in-the-middle attacks against SSL/TLS encrypted network connections. Connections are transparently intercepted through a network address translation engine and redirected to SSLsplit. SSLsplit terminates SSL/TLS and initiates a new SSL/TLS connection to the original destination address, while logging all data transmitted. SSLsplit is intended to be useful for network forensics and penetration testing.
And to put some of this in context the US government forgot to encrypt videos feeds from predator drones and they had no real budgets...I'm more then will to bet GM and their design team has very limited security exposure.
#207
Ok, I like simple. Wouldn't it be easier to convert the heads back to plain old fashioned EFI then to worry about hacking the new ECU? I mean what would you really have to do? Weld the injector boss shut, convert or design a new intake manifold and get a set of non DI pistons? You could go stand alone or modify the harness on an LS ECU. Maybe AFR or someone could do a retrofit top end kit.
#209
That's MISTER MODERATOR
While these do look like very nice heads, once converted to port injection, I don't think they'll out perform the current crop of LS3 heads as they've matured in the area of development.
One of the "tricks" of the new LT1 DI head is the fact that it's direct injected-which cools the cylinder and allows a higher compression ratio.
Going back to port injection allows you to use the head with an "normal" ECM but you'll lose the main advantage of the design.
#210
To do the conversion, some shop like LPE would need to do the following:
-Purchase a 2014 Corvette.
-Pull the engine, new lower compression pistons, weld the DI ports shut.
-Fabricate a custom intake manifold with port injection.
-Fabricate a fuel system.
-Fabricate a harness for a regular PCM.
-Test and choose a camshaft to work with the lower compression.
Who's gonna do all this? Who's gonna spend that kind of money?
I'll say that the aftermarket for new gen V LT1 is gonna be geared more towards bolt-ons, exhaust and intake manifolds.
#211
Good Morning to all I was asked to come back here by higher authority to answer your questions.
However my personal preference is to ONLY answer questions that hasn't been asked regarding various grey areas.
If you only wish to VENT and carelessly empty your emotions regarding operations of such new implemented changes than please sit in silence. I am not here for such reasons or action.
Warmest Regards,
Bigg Gunz
Warmest Regards,
Bigg Gunz
#212
Bigg Gunz
#213
Cost vs Performance Gains. In short not feasible.
Bigg Gunz
#214
A hand held tuner does NOT have the capability of programming the "ECM92" for the engine in debate.
Bigg Gunz
#216
#217
Ford talked about how encrypted there ecoboost motors are and yet tuners have the wide open now.
#219
To say an ECM can't be cracked and figured out is flat out stupid, where there's a will there's a way. Especially when companies will make money on it.
Edit: To add from reading your prior posts about "Safety" because of fuel pressure. Do you know what duramax diesels run for fuel rail pressure? About 10-15 TIMES more than this motor. We've been tuning duramaxs since 2001.
My biggest tune holds about 22000 PSI rail pressure at wide open throttle.
Also another thing, why would this vehicle be in "contact" with GM? Is that only when its in for service, or all the time the car has a connection to GM? I think that'd be the first thing I'd remove just like the onstar system.
