Generation V Internal Engine 2013-20xx LT1
Did they solve the DI issues?
Old 01-21-2015, 04:30 AM
O.N.'s Avatar
Default Did they solve the DI issues?
So did GM solve common direct injection issues?
Like valves coated in oil and carbon build up from not being washed with fuel like regular injection.
Old 01-21-2015, 06:40 PM
O.N.'s Avatar
I guess they didn't solve the issue then....lol
Old 01-22-2015, 03:16 AM
Jimbo1367's Avatar
That shouldn't be a problem UNTIL the warranty ends. Gotta love it when a plan comes together.
lol
Old 01-24-2015, 09:42 AM
O.N.'s Avatar
lol
would be nice to know especially when the crate engine becomes available.
Old 01-24-2015, 11:58 AM
lowerthanyou00's Avatar
Just seafoam it hahaha
Old 02-02-2015, 09:15 PM
MIGHTYMOUSE's Avatar
just like most of these other engines a good catch can goes a long way.
Old 02-02-2015, 09:19 PM
kelobro's Avatar
No problems on my 2012 Impala 3.6DI... yet.
Old 02-12-2015, 09:05 AM
Sssnake's Avatar
Meth FTW!!! We've done it in a couple of DI engines with good results. A 275k mi GTI still running 20+ lbs of boost with solid pulls all the way to redline. It should help with valve buildup on the NA engines as well
Old 02-20-2015, 12:56 PM
Noah Burns's Avatar
meth?
Old 02-20-2015, 02:31 PM
ramairetransam's Avatar
water meth injection or just methanol . Whatever you want to use .
Old 02-20-2015, 02:56 PM
Noah Burns's Avatar
ahh, ok, that's what I suspected you meant but wanted to make sure.
Old 02-22-2015, 03:17 PM
kelobro's Avatar
Read about installing a catch can to get the oil out of the air flow from the pcv. I've read the new LT1s and LV3 v6s do something similar but put the condensed liquid back into the oil system.
Old 08-13-2015, 02:44 AM
LilJayV10's Avatar
I see what you did there.
Old 08-13-2015, 08:30 AM
Jimbo1367's Avatar
I thought the buildup on the intake valves (KIA's DI engines) was from the placement of the DI injector. Anyone know where they have that injrcter? WHat about top contour of the piston?
Old 08-16-2015, 10:19 AM
Exidous's Avatar
No, the buildup is from the PCV system putting all sorts of crap back into the intake without any fuel/injector to clean off the back of the valve.
The Ford ecoboost has it the worst it seems. But that's mostly crap collecting in the intercooler.
Catch cans are good for most engines but should be a requirement on a DI motor. They don't install one though because they don't like the idea of an owner having to empty sludge out of a car under warranty.
Old 08-17-2015, 10:46 AM
Jimbo1367's Avatar
Good to know. I thought GMs newly designed PVC system intergrated into the valve covers were solving the oil problem.
Old 08-17-2015, 11:04 AM
thats what they say every damn time...
check this out tho...
Old 08-18-2015, 08:01 AM
Exidous's Avatar
Aye, they plumb it back to the oil pan. Still, that's a lot of sulfur, moisture and crappy oil mist going back into the system. But they are trying.
Old 08-18-2015, 08:39 AM
actually im not sure of that.
it may be where they drain it on an oil change (I would certainly prefer that)
... still digging for more info.
Old 08-18-2015, 10:23 AM
MyFirstLS1's Avatar
I at least at BMW with there direct injection have seen some pretty good progress compared to the earlier DI motors from 2007. Not sure how this stands with other manufactures.
Quick Reply: Did they solve the DI issues?
