Aster Bracket - Page 2 - LS1TECH
Group Purchase Requests Please post your GP requests here for the sponsors to consider them.
Aster Bracket
Thread Tools Search this Thread
Old 07-11-2012, 06:56 AM   #21
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Quote:
Originally Posted by 2002gt View Post
Pm me I want in.
I just sent you a pm. Thanks. Bob
Bob@BruteSpeed is online now   Reply With Quote
Old 07-11-2012, 06:57 AM   #22
LS1Tech Sponsor
Quote:
Originally Posted by js2fst View Post
Need one too
Aster Bracket Group Purchase
Here you go, thanks. I just sent you a pm. Bob
Old 07-11-2012, 07:01 AM   #23
LS1Tech Sponsor
Quote:
Originally Posted by speedfreak2685 View Post
Im one of the ones that needs one
Old 07-11-2012, 07:03 AM   #24
LS1Tech Sponsor
Quote:
Originally Posted by airforcemanss View Post
In depending on discount
Old 07-11-2012, 07:05 AM   #25
LS1Tech Sponsor
Quote:
Originally Posted by yellowrider View Post
i need one as well...
I just sent you a pm too. Thanks. Bob
Old 07-11-2012, 08:02 AM   #26
ss4chad's Avatar
Hi Bob!
My 427 is naturally aspirated, so if I am reading the description of the bracket correctly (I didnt know what it was) it is just for Supercharged motors. Did I read that right?
Chad
ss4chad is offline   Reply With Quote
Old 07-11-2012, 08:34 AM   #27
LS1Tech Sponsor
Quote:
Originally Posted by ss4chad View Post
Hi Bob!
Chad
Yes you are indeed correct, that makes sense to me now. I wasn't sure earlier, I thought maybe I didn't understand what you said because I wasn't running on all eight cylinders yet. Bob
Old 07-11-2012, 09:04 AM   #28
ss4chad's Avatar
No worries Bob!
Chad
Old 07-11-2012, 04:46 PM   #29
I8UR4RD's Avatar
I pm'd every person that said they needed one just in case they dont make it back to the GP section. i am going to check and see right now if FI section has it there, and if not make sure all those guys are aware as well.
I8UR4RD is offline   Reply With Quote
Old 07-11-2012, 04:52 PM   #30
LS1Tech Sponsor
Quote:
Thanks, I appreciate it! Bob
Old 07-17-2012, 06:46 AM   #31
LS1Tech Sponsor
We had a lot of interest in a group purchase on the Aster Bracket and so far only two guys have paid for them. Please step up and help get this group purchase moving, thanks! Bob
Old 07-19-2012, 12:43 PM   #32
ZexGX's Avatar
I never got a PM. Also, the 5% (3/4 tank of gas) discount is decent, but not a huge incentive. I'll see what I can scrape together.
ZexGX is offline   Reply With Quote
Old 07-19-2012, 05:55 PM   #33
LS1Tech Sponsor
Quote:
I am sorry about that, somehow you got missed. 5% to us seems like all the money in the world, as the profit margin on these brackets is very slim.
Thanks. Bob
Old 08-07-2012, 08:53 PM   #34
I8UR4RD's Avatar
this bracket will go nicely with the f1-a. thanks bob.
Old 04-21-2013, 02:06 PM   #35
Why should I have to buy an after market part to make the setup that ProCharger recommend work properly??? I was told the 8-rib setup would not slip and it does.
Does ProCharger offer any solutions to what seems to be an epidemic? If I'm replacing their parts with something else do you think I can return their parts for a refund?
I feel disappointed that a brand new, professionally installed system doesn't work properly. Am I the only one?
South is offline   Reply With Quote
Old 04-22-2013, 10:30 PM   #36
I8UR4RD's Avatar
They have always slipped. You do not have to buy the bracket. They offer cog setups for extreme applications. Ours would probably fall into the category for street cars, but they do not offer anything like this and fortunately we have Chris out there to save the day and make the seutp efficient. Procharger has got the setup down other than the bracket and the placement of the head unit.
Old 04-23-2013, 07:43 AM   #37
LS1Tech Sponsor
At how much boost? The stick ProCharger J Bracket doesn't give problems at 8 to 12 psi, but you do have to keep the blower belt much tighter than you do with other belts. A new belt will stretch, and after an hr of use, you need to retighten a new belt. Bob
Old 04-25-2013, 09:24 AM   #38
Quote:
I’m only running 11 pounds of boost with a 3.85 pulley and a 400 belt - and it's VERY tight.
Here's some more background for you:
I e-mailed ProCharger many days ago, and got no response, so a called two days ago to discuss the slippage and was told I should have bought a “cog drive.” I was then put on hold and when the gentleman came back on the line I was told an alternative solution would be to have some custom bracing made the attached to one end of the “J” bracket and something that pivots with the engine, “like the strut tower brace.” I asked about the Aster bracket and was then put on hold again so the person I was speaking with could ask around about the Aster bracket and to see if there were any other solutions.
Apparently no one at ProCharger had heard of an Aster bracket, but they were going to call me back later the same day to offer additional solutions, but no one called back.
I called again yesterday to ask the same question (i.e., what is the solution for belt slippage for my setup?) and was told that all I needed to do was send my pulley to Carbiniteracing.com for coating.
On top of this people are telling me that I shouldn’t have to do anything if I’m only running 11 lbs. of boost and others are telling me I need the Aster bracket.
I wish there was some consensus as to what needs to be done and that ProCharer was much more knowledgeable and responsive.
Do you still think I should just drive the car for a bit and retighten? Do you sell the Aster bracket?
Thanks!
Jason
Old 04-25-2013, 09:34 AM   #39
Thanks!
Jason
...I should also add that I have an 8-rib setup.
Old 04-25-2013, 09:39 AM   #40
LS1Tech Sponsor
Thanks!
Jason
The Aster bracket is something we offer, so I can see why whoever you talked to at ProCharger may not know what you were referring to. ProCharger doesn't offer a cog drive for the 98-02 F Body, it wasn't an option that you could of gone with anyway when you bought your system. The belt needs to be as tight as a guitar string, and if you are using the stock ProCharger supplied air filter, that may be part or all of your problem. It is possible at 11 psi for the filter to be too restrictive, and I have seen it cause belt slippage. To see if the filter is part of the problem, try making several runs with it off in a clean area. Watch your boost gauge if you have one, as you may end up making several more psi of boost, which could lean it out. I sell a larger air filter that will fit in place of the stock filter. Here is a link to it. http://shop.brutespeed.com/ATI-AF056...AF056I-009.htm
Here is the link to the Aster bracket. http://shop.brutespeed.com/Aster-Aut...er-Bracket.htm
Thanks. Bob
Related Topics
Thread Thread Starter Forum Replies Last Post
aster auto spring tensioner bracket Dangerous SS Forced Induction 3 09-05-2014 04:26 PM
Aster Bracket Group Purchase Bob@BruteSpeed Sponsor Group Purchases 46 05-02-2014 07:35 AM
Procharger Allen bolts josepy121380 Forced Induction 5 07-14-2013 08:01 PM
Can the aster bracket be used with the meziere waterpump stngtamr29 Forced Induction 1 04-08-2012 09:38 PM
Procharger D1SC 8psi Question , Aster Bracket? Patsy57 Forced Induction 1 03-13-2012 10:21 AM
Tags
400, aster, ati, bracket, brackets, brackey, camaro, install, ls1, ls1tech, pontiac, procharger, sale, tech, users
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
