Parts FS at LSFest! Post them up!!
#43
I have for sale
-3 gauge pillar pod
-C2 N20 gauge
-LC1 wideband
-C2 oil pressure gauge
-C2 fuel pressure gauge
I also have the C2 gauges wired up to a box that will adjust the light brightness. ***these pics are of the product that I have for sale and aren't of the items itself ()...I will get pics of the stuff that I have these are just to give you an idea of what it is I have.
Now for price $300 gets you everything or $100 for each C2 gauge and $50 for the pillar pod.
-3 gauge pillar pod
-C2 N20 gauge
-LC1 wideband
#45
Make me an offer on anything.. I don't gotta ship.it and I want it outta my way.
20$ and 20$ there adds up
Chances of me taking a half *** decent offer is high!!
Tons of interior panels... from kick panels to a pillars to dash and steering wheeldumStock fuel lines from tank to engine bay with filter block and alldumRear trans am high rise hatch pewter good shapedumDriver doordumDriver fenderdumBoth pewterdum
99-02 style center bolt coil mount brackets
Mount to valve covers and coils mount on them
40$ shipped
Ls1 f body coil packs full set
60$ shipped
Coils+brackets 85$ shipped
Ls6 valley cover
60$ shipped
Ls1 throttle cable mount (close to the front of the intake)
25$ shipped
Hood struts.. left and right.. work perfect
45$ shipped
Rear hood hinges
45$ shipped
Trans am side mirrors.. red.. power.. great condition
60$ shipped
Trans an "T" shifter handle
Good shape
30$ shipped
Wiper assembly parts
(Motor arms etc)
12 bolt backing plates
Pay shipping
Free at fest if u need them
Abs block
60$ shipped
Brake fluid reservoir
Complete
40$ shipped
E brake assembly... handle to lines
50$ shipped
Air bag sensor
25$ shipped
Valley cover stock ls1
25$ shipped
Stock rack ls1 f body..
70$ shipped
upper lower front arms
30$ each 100$ for all
Cruise control
Complete assembly
50$ shipped
Hood latch cable and assembly pull handle and all
50$ shipped
Brake booster hose from back of intake to brake booster.. includes the plastic 90* valve.
25$ shipped
Brake booster
50$ shipped
Will do brake booster and hose for 65$ shipped
Head light assembly
Pewter
Have drive and passenger sides
Ls Vic style edelbrock rails
have a crossover line as well
85$ for rails and hardware
40$ on fuel crossover line
Ttops
mint
Ebony
Includes key
150$
Trans am high rise spoiler glass hatch complete
Good condition
150$
Ls1 OEM map sensor
25$ shipped
40$ shipped
60$ shipped
Ls6 valley cover
60$ shipped
25$ shipped
45$ shipped
Rear hood hinges
45$ shipped
60$ shipped
Good shape
30$ shipped
(Motor arms etc)
Pay shipping
Abs block
60$ shipped
Complete
40$ shipped
50$ shipped
Air bag sensor
25$ shipped
25$ shipped
70$ shipped
Cruise control
Complete assembly
50$ shipped
50$ shipped
25$ shipped
Brake booster
50$ shipped
Head light assembly
Pewter
Ttops
mint
Ebony
Includes key
150$
Good condition
150$
Ls1 OEM map sensor
25$ shipped
#48
Lemons12 yes I sold the rear. Nothing wrong with it, it was really clean inside. By the time I changed the gear, abs, and bought a crossmember I was around what I'm giving for a mwc one. Probably still should have used it but i didn't.
#49
i will have a 6-speed from a 2001 camaro 86000 miles. was in a 68 camaro street car for the last 2500 miles. the guy didnt like shifting all the time while cruising in town. so he went to a automatic. comes with bellhousing, throw out bearing, stock shifter with the boot. he wants 1600.00 obo. also have a new 12 bolt strange 33 spline spool with bearings and a box of 12 bolt bearings and seals. 150.00 should be parked close to the river, will have a 65 chevy II. will also have other misc. parts to.
#50
99-00 iron headed 6.0 long block. Selling as core may be useable not sure 500.00
I'm an hour North of BG rather not have to pack around
2 sets truck manifold 60.00 ea
C6 manifolds 125
67-72 long tubes. 375
C5 long tubes 225
Fresh 853 heads 200.00
2 truck harnesses 125 ea have to check the colors, gen 3 I believe
C6 manifolds 125
C5 long tubes 225
#51
items up forsale all came off of a low mileage z28 car items are as is and in like new condition willing to ship most items or local pickup can also meet within a reasonable distance. I will be at lsfest in 2 weeks so may be able to arrange pickup there. email call or text 2703074470
Factory rearend nothing wrong with it just pulled to install a ford 9 inch. 373 gears arp extended wheel studs. 250
Factory hood no dings or dents a few small rock chips. 100
slp airlid no issues comes with iat sensor has a small blemish where hood rubbed it. 80
slp smooth bellow has hole in one side where i had nitrous nozzle 20
slp y pipe and loudmouth 2 exhaust with 2 single tips complete 300
slp smooth bellow has hole in side of it for a nitrous nozzle 30
BMR tubular transmission crossmember pn tcc002 fits pg and th350 black hammertone 150
TPU001 - Trak Pak Torque Arm Kit comes with everything to install never raced just installed i had the crossbar welded in and had to cut it out to remove. No issues just no longer needed on my setup. Has driveshaft loop already welded to it. 300
also have other items pictured factory driveshaft lower control arms summit brand 3 way adjustable shocks v6 springs and v8 springs make offer on items if u are interested
35 spline detroit locker for ford 9inch requires aftermarket center sections uses 3.250 bearings 1500 miles on it no issue at all has tone ring on it for 3channel abs but can be removed 350
4.8 40k 799 heads comes with manifolds, flex plate, water pump, ac compressor, harmonic balancer. Very clean posted picture of inside of head. I was told it was a 5.3 but doesn't have afm or Vvt so I belive it to be a 4.8 will sell shortblock for 300 may seperate heads aswell. 700
6l90e with convertor came from a 08 chevrolet 2500 less than 80000 miles came from truck with interior slash engine fire bought for motor dont need trans 600
#53
I've got a 95 model 2wd 4L80e transmission and converter. Traded for it and it come from a 5.7 2500 Silverado. Guy parted truck out. Fluid smells and looks good but I have never pulled the pan. I also have the gm flexplate spacer and bolts. Asking $350 obo. Will be at LS Fest on Saturday.
#55
#57
I will only be there Saturday, this is what I'll have with me if you want it:
Stock LS6 injectors - $50
317 heads - $100
Stock lifters and trays, less than 30k - $50
Stock pushrods, less than 30k - $25
Truck accessory brackets and balancer - $50
Truck exhaust manifolds - $30
Autometer 2 5/8 mechanical water temp guage - $40
Autometer 2 5/8 mechanical oil pressure guage - $40
Autometer 3 hole bracket - $15
Kerry
317 heads - $100
Kerry
#59
Sellin my Lsx block $2000 firm if someone wants it. $2395 brand new from scoggin dickey then you gotta pay for shippin. Its brand new still in the crate in the bag never even taken out. Its a Short deck.
Wtb hp tuners. I hope someone has one to get rid of.
#60
Can bring these parts Saturday if anyone is interested.
98-02 aluminum LS1 auto driveshaft. $100
98-02 LS1 F-body oil pan, windage tray, pickup, and dipstick. $200 obo
2000 Camaro LS1 complete fuel tank. Has evap and all. $125 obo.
Would be interested in trading above parts for LS Foxbody swap parts. Also need a CTS-V oil pan.
Thanks,
Eric.
Thanks,
Eric.
