nissan owner with a ls2
Old 07-24-2011, 10:19 PM
topdrop04's Avatar
Default nissan owner with a ls2
whats up ppl. my name is ben and i have a 90 nissan 240sx with a 05 gto ls2.
TSP MS4
1 3/4 longtubes to 3" collectors to y to single 4" vibrant 4" race muffler
msd wires
k&n
act 4puck unsprung with superlite flywheel
t56
lingenfelter lnc003
451hp/438ftlbs tuned with hptuners on dynodynamics loadbearing dyno
i love my v8
Old 07-24-2011, 10:34 PM
19mike84's Avatar
looks like a fun ride
Old 07-24-2011, 10:52 PM
thirdgengta350's Avatar
badassery man! I'm jealous to say the least.
Old 07-24-2011, 10:58 PM
SURFINUSA's Avatar
That is the craziest paint job I have seen in a while!!!
Old 07-25-2011, 12:55 AM
The Batman's Avatar
More info on the body mods? Crazy little car
Old 07-25-2011, 12:59 AM
kingd_202's Avatar
Holly hell!! That has to be one of the sickest domestic powered rice rocket I have ever seen!!!!!
Old 07-25-2011, 01:02 AM
green manalishi's Avatar
welcome....love the color!
Old 07-28-2011, 11:58 AM
topdrop04's Avatar
Thanks for the kind compliments. It's actually not paint but vinyl. As for body mods it's a 1990 Nissan 240sx that has the front end from a 1998 Nissan 240sx. It's all aftermarket fiberglass. fiberglass
Old 07-31-2011, 10:43 AM
willied273's Avatar
im jelly, you have exactly what i wanna build lol thats sick though man, did you fab all your motor mounts or did you use one of the kits?
Old 08-01-2011, 09:36 AM
Fbodyjunkie06's Avatar
What kind of camber do you run to allow the tires to do that, that is insane you have to be using some type of aftermarket cv joint on the rack and pinion to allow that kind of angle....
Old 08-01-2011, 11:07 AM
S1dc_Drifter's Avatar
All you need to do is get your knuckles modified pushing the tie rod mounting location out further and you need go extend your inner tie-rod and bam insane angle from a 240sx
Old 08-01-2011, 12:54 PM
Fury_786's Avatar
if only more people would listen...i try to tell all my drifter friends about this and they still seem to be into rb's and sr's even ca swaps. one of my buddies did a vh, but still nothing loike LSx power
good job and welcome man
Old 08-18-2011, 10:22 PM
topdrop04's Avatar
actually you move the outer tie rod point closer to the lower ball joint, on the same plane as the lower ball joint, and you do move it out further but to a calculated point. you adjust bump, Ackerman, and KPI. i could go into alot of detail about all this but if you arent familiar with it, you will get a migraine. trust me i did when i started to teach myself about it lol.
i used an awesome kit from Fueled Performance out of Phoenix AZ
rbs and srs are ok if your on the grassroots level. if you have any intentions on growing past the grassroots level i highly suggest ls. the power per dollar and reliability of a ls is incomparable. vh swaps are ok but again power per dollar is better with an ls. who ever is doing ca swaps you need to smack them. thas like the sohc or japan. that motor is ancient and worthless kinda like an rb20.
actually i run -2 to -3 degrees camber. in that first picture i was running -4.5 degrees camber. to do backwards entries you dont really need alot of negative camber. you need alot or rear grip and a good tire contact patch up front. depending on the course i change my camber up front. say at PBIR i was running alot of camber to do those kind of entries but at Charlotte motor speedway i ran less to get more rear grip. there is a science car set up in drifting. alot more indepth than i ever thought. As for the angle like i said earlier its all in the set up of the front steering knuckle. no special cv joint just a spacer on the end of the steering rack to prevent over centering of the steering rack.
Old 08-18-2011, 10:49 PM
Fury_786's Avatar
lol the friend with the ca...well it promptly blew up
where are you from?
Old 09-01-2011, 10:44 PM
topdrop04's Avatar
Charlotte NC
Old 09-01-2011, 11:04 PM
david068513's Avatar
did I see this car sitting outside road atlanta a few weeks ago?
Old 09-18-2011, 12:57 PM
topdrop04's Avatar
depends on what u mean by a few weeks ago
