2000 Camaro SS VATS and IBCM bypass...
Old 03-15-2012, 02:22 PM
blackenedss's Avatar
Default 2000 Camaro SS VATS and IBCM bypass...
Hi,
This year has been particularly rough on me because my SS was broken into twice, the ignition and IBCM chopped up, and I had this all fixed recently.
Just when I thought things were back to normal, I think my IBCM is causing me problems again. I have no way of being 100% sure that it is the IBCM but It seems that way.
When I go to start the car, it hesitates for maybe three seconds and the locks flicker and then it starts sometimes when I hold the key in the starter engage position. Then sometimes it starts perfect... until today when it finally died and does not engage at all. Pure silence is all I hear.
Any ideas on how to get around spending $335 on a new IBCM would be helpful.
Old 03-15-2012, 02:24 PM
Thought about tossing the IBCM and buying this...
http://www.3rdbrakeflasher.com/index...roducts_id=183
VATS BYBASS MODULE
Old 03-15-2012, 02:46 PM
Also, I am talking with a mechanic who is an expert in steering column and ignition issues about installing a classic style ignition and ditching the chipped key and wiring it all up like a classic car. Would the above be a solution to this? I want to completely remove the IBCM...
Old 03-15-2012, 02:53 PM
notsue's Avatar
I'm prolly wrong, but even if you changed the column, the PCM will still be looking for the VATs stuff if its not tuned out.
Old 03-15-2012, 04:19 PM
What's with all the SPAM?
Old 03-16-2012, 12:37 AM
35th SS's Avatar
go to search type vats bypass.show you how to bypass the vats sys.
Old 03-16-2012, 02:38 PM
Ok got an update for you guys... Turned out to be the clutch safety switch... Part number 14094368... Cost $15 at the GM dealer... and five minutes and a back ache to install...
Thanks for all the help...
Quick Reply: 2000 Camaro SS VATS and IBCM bypass...
