79 formula 4.8 4l80e turbo project
Old 06-20-2014, 01:22 AM
79transformula's Avatar
Default 79 formula 4.8 4l80e turbo project
Hello. Another ls swap. Front mount set up ebay turbo . Street /strip car any suggestions? I read the ls big bang theory. i wanna crush some fords and imports
Truck headers
T76 76 mm turboh
Ls6 cam
Working on bottom end arp the heads and rods and file the rings. 300$ long block off craigslist
Ls1 intake or truck intake ?
85mm summit tb.
Old 06-20-2014, 06:49 AM
Exeodus's Avatar
The truck intake will be better as it will build more torque, which is needed as a second gen car is heavy.
Old 06-20-2014, 10:17 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Sounds like an awesome project in the making!
Old 06-20-2014, 11:10 AM
She sure is a heavy pig, i just love the history of these cars and the style .
ITruck intakes flow pretty good just have to run a cowl hood or cut a hole out
79 firebird formula rts 403 auto ac car 80000 miles
Stock 10 bolt 2.41 gears replaced with 3.42gears
C clip eliminator installed
Original rear Disk brakes replaced with 4th gen disk conversion
Poly hardened bushings all the way around
Summit rear leaf springs 2" drop same in front 2" drop coil spring trying them out
Sub frame connectors bars
New fuel lines summit stainless steel braided
Kyb shocks
Factory ls1 98 harness n ecm
Hp tunner
Still in progress
Street strip car
4.8 is a 03, what size injectors should i run?
What at stall torque converter ? Best fuel pump.?
Any advise
Got a 6.0 but that's a maybe
I just love hearing that small block rev to 7000 rmps all day 4.8
Was gonna put it in my 95 formula t56 car but i already broke 2 rear ends .i have other plans for it later lq4 t56 swap
Old 06-20-2014, 03:45 PM
Thanks for the reply
Just trying to keep up.
Old 06-20-2014, 03:50 PM
Exeodus's Avatar
Stock injectors will be fine if you are going to stick with a stock or mild cam upgrade. Any basic electric fuel pump will do, unless you are going to go turbo, then I would check the Forced Induction forum for advice on what to go with. What trans will you be running?
Quick Reply: 79 formula 4.8 4l80e turbo project
