Newly joined in PHX
Newly joined in PHX
Can't tell you the countless hours I have spent getting valuable info from this great forum! Thanks to all!
Over the years I have had a lot of relevant Chevy's getting info off here:
92 Camaro RS 355/TH350 swap
08 Silverado
08 Tahoe LTZ
11 Yukon Denali
Currently have 11 Escalade and my 99 Z28 is my weekend car. Got it for a steal from one of my customers because it wasn't running at the time. Just needed a set of good old ACDelco plugs. Has 230k on original drivetrain and still runs strong!
Since I've had it I did plugs/wires, radiator, water pump, all belts/hoses pulleys/tensioners, BMI short stick shifter, Strano springs, Bilsteins, Strano sway bars, valve cover gaskets, SLP skip shift eliminator. As soon as I recieve them I'll also be adding full Founders rear setup excluding torque arm. I also want to add some 18's soon. I plan on leaving the paint down and dirty since I can't fit it in my garage with the Cadillac
Evan
08 Silverado
08 Tahoe LTZ
11 Yukon Denali
Evan
