ls1 top end knocking need help
Old 01-07-2015, 08:25 AM
j_bby's Avatar
Default ls1 top end knocking need help
i have a 98' ls1 daily driver. it has roughly 155k miles on it.
a few days ago it started making a really loud noise sorta like a tapping noise.
its def coming from the top of the motor.
i have parked the car since it started making the noise.
oil pressure is good...
the knocking does ease up when i push the gas but does not stop even after motor is warm so i dont think it is a piston slap.
any ideas?
Old 01-07-2015, 09:37 AM
R6cowboy's Avatar
Very possibly a lifter. They can make a loud tapping noise when going bad. All aluminum LS1 motors all of a sudden making a really loud tapping noise is not normal, nor ok.
Edit: I noticed whoever posted before me deleted their very misleading post, which the second sentence of my post was referring to. In case you were wondering why I said that.
Old 01-07-2015, 04:02 PM
j_bby's Avatar
it's def not normal.. and i noticed a decrease in power...
Old 01-07-2015, 06:09 PM
Snake_Skinner's Avatar
My really loud tapping noise noise was a failed lifter, really sucked.
Old 01-08-2015, 08:09 AM
R6cowboy's Avatar
Also could be a broken valve spring perhaps. A couple springs broke in my C5 but the ticking/tapping noise didn't get really loud until higher rpm.
Old 01-08-2015, 10:57 AM
Moderator
jimmyblue's Avatar
The needle bearings in the rockers have a habit of
wandering off to the oil pan. If you find them there
then you know what to do.
Old 01-08-2015, 11:38 AM
SSdreamz's Avatar
pull off the valve covers and look for a puked rocker or broken valve spring(s)
Old 01-09-2015, 02:45 AM
p8ntballkid090's Avatar
I have the same problem, and pulled the valve covers off today. Replace the pushrods and noticed the rocker arms have some side to side play and diagonal play when holding the stud. I don't know how much play is acceptable.
Quick Reply: ls1 top end knocking need help
