Greetings Program's - 2001 FireBird V6 (Its mostly a Sub enclosur I drive to work :))
Greetings Program -
Currently a 2001 FireBird V6 Owner. I found a Gem of a car as it was in a climate controlled shed for 9 Years. In the 3 Years I have owned it, I have only seen the common cooling headaches.
First Year leaking Radiator
3 months later Water Pump
Month Later O-Rings on Heater Hoses.
I am so lucky to have benefited from all your great posts.
I joined so I could Thank you all. Maybe I can give back in the Car Audio section.
I also had a 1979 Firebird which could have benefited from this community's help. Hehe I had to put her down like a zombie on THE WALKING DEAD.
https://ls1tech.com/forums/images/sm...ch/gr_hail.gif
https://ls1tech.com/forums/images/sm...ithoutpics.gif
I also Have a perfectly mint condition set of Monsoon speakers and Amp.
I pulled them out the first day I brought my bird home.
I did cut off the amps Wire harness but I saved it just in case I run into someone who needs it.
