Chevelle owner who has aquired LS1
Old 03-02-2008, 05:42 PM
thunderstruck507's Avatar
Default Chevelle owner who has aquired LS1
I just found a nice deal on a 98 LS1/4l60e combo with under 50k original miles that was missing only coil packs and the harness/computer
Looking to get this thing dropped into my Chevelle by summer. Sooner the better...
I am not very knowledgeable about these engines yet, so I'm going to need some help.
Plans are to cam/spring the engine before it ever goes in. If porting can help the heads I can do that, but there's no way I can afford heads.
I'm working on a list of parts and with the help of ebay and some local connections it looks like $1600 might be enough cash to put this thing in.
I can't wait
The car has before been geared to be a classic/vintage/retro look with hidden modern touches such as suspension work that has it handling pretty decent, but the future will be modern SS badges and 17"s.
Old 03-02-2008, 05:45 PM
djfury05's Avatar
how much you end up paying for the combo?? there's a lot of guys on here who can lead you in the right direction, and save you money too
Old 03-02-2008, 05:53 PM
raven_450's Avatar
https://ls1tech.com/forums/conversions-swaps-28/
That will be your new home for awhile
Lots of info in there and alot of knowledge to leech off others who have done these swaps.
Old 03-02-2008, 06:15 PM
stainless40cal's Avatar
Nice chevelle i have one just like it just diffrent wheels and such
Old 03-02-2008, 06:44 PM
I got the motor and trans for $2k, seemed like a decent deal.
I plan to sell my 700r4 which has a fresh rebuild and transgo stage 2 kit installed to help offset the cost.
Old 03-03-2008, 02:58 PM
69chvelle's Avatar
Glad to see you migrated over to this board. You will probably spend more time here than the other board. Most of those guys seem to be stuck in the carb world. Alot of them don't know much about the LS1 and the power potential it holds. As for your install, the hybrid/conversion forum is packed with swap info. This is one of my favorites that I have subscribed to: 71 LS1/T-56 Swap https://ls1tech.com/forums/conversions-swaps/510709-71-chevelle-ls1-t56-progress.html
Old 03-03-2008, 03:38 PM
TX Tahoe Z71's Avatar
Good to have you! Sounds like you will end up with a pretty sweet build. Wish you the best.
Old 03-03-2008, 05:46 PM
Originally Posted by 69chvelle
Glad to see you migrated over to this board. You will probably spend more time here than the other board. Most of those guys seem to be stuck in the carb world. Alot of them don't know much about the LS1 and the power potential it holds. As for your install, the hybrid/conversion forum is packed with swap info. This is one of my favorites that I have subscribed to: 71 LS1/T-56 Swap https://ls1tech.com/forums/showthread.php?t=510709
do u have pics of your car?
Old 03-05-2008, 09:59 AM
69chvelle's Avatar
Don't have any on the PC. It's a black primer 69 with bullet hole cragars. Its been parked for about a year since the ole' 350 went south. I am going to start a build thread on here when I start the swap.
