68 impala/ Lq4 swap
68 impala/ Lq4 swap
I am having the hardest time. I put a 6.0 lq4 into my 68 impala convert. I am having a promblem with my steering/center link and oil pan clearance (i switched to the F-body oil pan already). Most people swapping the Ls into muscle cars are doing it with camaro/nova/chevelle and the center link is in front of the of the k-member my center link is after the k-member. With the engine in place and the center link disconnected i have a 2 inch gaps between the center link bolts and te idler/pitman arms. Just looking for suugestions of some custom fabrication tips or any body that has swapped a ls into a 68/69/70 impala. Thanks for the help!
update... i put a 5.3 from a 02 tahoe (stock pan) in my 69 impala. i used the mounts from car shop inc. mover engine foward a bit but no link clearance issues. used hooker block huggers. had to dend two middle tubes on ds to clear the ps gear box. run a search for 69 impala and find my thread with pics. pm me if ne questions
Village Idiot
Sounds like it's going to be a nice swap when finished..... You think your project is tough try swapping an LS2 into a Lexus SC400 like I am doing....
The electrical integration is insane..!!!!
Thanks for all the replies guys. I ended up using the f-body oilpan and geting it cut by street&performance.com. They do great work and it gave me the clearence I needed. Burntrack I am going to take a look at your photos.
