View Full Version : Nitrous Oxide
- Anyone running a TNT 150 shot with the stock fuel pump only?
- How much does your torque spike when your kit hits?
- Rich with TNT 150 shot?????
- Upgrade to bigger shot?
- Building a NOS motor: What would you do?
- New LT1 TNT Wet Kit w/ Electronics for sale
- What is the AN size for this line and fitting???
- Where's the MPH?
- Just want to THANK Mike @ Ramchargers!!
- WTB: T-N-T Nozzles
- Fuel Leak.
- Who has this combination??
- NOS do I need relay
- H/C with 150 wet shot, anyone with stock bottom end?
- WIRING DIAGRAM FOR NOS HEATER INSIDE!
- Need Help ASAP!!!!!!!!
- If you could design any nitrous setup......
- NX Jets
- N2O dry kit (lower price , now with extras)
- Will the 4AN line flow enough nitrous for a 250-300shot?
- nos and maf
- What size resister to retard timing?
- White whire on window swith goes to tach lead, where is it on a 98ls1T/a.
- Opinion on suggested setup (few questions)
- How to check if nitrous is flowing?
- Cam and Nitrous problem.
- those of you with heads and cam and spraying i have ?
- WOW-converted nos 5177 to wet kit
- Jet Pattern NOS #8177
- Direct port on stock bottom end, questions??
- Seperate fuel supply for Direct port
- what jet for 100hp on 5177 dry?
- Fuel press switch
- Still friggin pinging at 5k rpms....HELP!!??
- Leaks, I have leaks everywhere!!
- NOSzle Q's
- Fuel Pressure gauge flutters... incosistent.
- New nitrous setup, what do ya think?
- converted dry to wet kit
- question on window switch with dual stage setup safety
- Dropped 7tenths with TNT 75 wet shot!!! New worst N/A
- How to tell if I got big or small TNT noids???
- dry nitrous sucks
- Heads/Cam Auto and nitrous?
- Nitrous raffle
- NX Tech Support
- NX Switch Panel
- Will going from dry to wet fix my surging issues?
- TR 230/224-111 LSA
- Can you mix the jets in a TNT nitrous kit?
- Bought a used kit and need help on what jets to run
- NX Help on 01 Chevy truck 4.8L
- Nitrous Express LS1 Gemini Twin MAF?
- Racetronix fuel pump
- im clueless on no2...but think I want it ..???
- nx kit still for sale
- What kit should i run
- NX Valve replacement
- 15 pound TNT bottle placement
- RPM-based Progressive Controller?
- dry nitrous
- How to convert TNT F1 to F2?
- MSD window switch question
- My 3rd NX TPS switch just went south.
- How much are the parts for a Direct Port kit?
- need some wiring help
- another quick Q for anybody using the harlan window switch quick question
- tnt installation diagram
- Fuel Pump for TNT 150+ shot
- What RPM should you shift a nitrous fed LS1?
- New Dyno with N20
- N2O on a stroker
- Biggest Dry shot
- Need help choosing Heads + Cam + safety equip to go with TNT 150 shot
- I need inst.'s on how to wire up my NX heater
- Colder plug than a TR6?
- Which plugs and gap?
- Looking for advice on a remote bottle opener
- Some Wiring Confirmation
- Granatelli MAF with N20?
- Size of lines & fittings?!?!?!?!?
- Venom VCN 1000 rocks
- Why descreen MAFS w/nitrous?
- Never buy part from Excessive Motorsports
- Dyno Video Heads Cam/150 shot TNT!
- Wiring some components?
- H/C guy,thinking of N2O,need some N2O education
- n.o.s
- Can i run Nitrous?
- Here's the verdict of the Lean spike for now
- Heat + Solenoid = Bad?
- How many amps do they NX solenoid draw???
- Dual purge setup?
- Need Help ... Which/What Bells & Whistles
- Fitting and Hose Sizing
- plugs
- NOS sportsman fogger on ls1
- 4.56's and a 150 shot with 29 1/2 tall tire
- timing retard and tuning
- NOS NOSzle Direct Port E.F.I. Nitrous Systems
- NOS 5177 spray nozzle question
- Videos of my 02 Z28 with 100HP NOS 5177 kit
- Whats needed: converting TNT dry kit to WET
- Wet vs Dry
- What Mass-Air is best for N20
- N2O lines have to be outside car???
- What other nitrous plugs are there besides
- WTB: NX 10LB BOTTLE
- Nitrous install help ASAP
- Horsepower TV: NOS install made easy?
- How much of a wet shot can I use on my heads/cam car w/ stock 2001 bottom end??
- help new to the NOS thing
- Backfiring on N2O?
- Gapped TR6 @ .045
- NX Bottle Opener Instructions!!!!
- What tranny for TNT 150 shot??
- Blower with nitrous
- NX wet kit with my mods?
- Spraying with a PT-4400?
- installing N.O.S kit 5177 in my 98 Z
- killing knock sensors on a sprayed motor.......
- TNT fuel pump install questions
- Nitros gas sales outlawed!
- Wow! 422 on nitrous!!
- TNT F2 vs TNT Direct port
- Parts questions
- FYI HP TV
- Monitoring with ATAP, and then....
- 150 shot guys/ what's your fuel system? with h/c?
- Fuel system
- Lean Spike w/40RWHP loss when TNT wet kit hits!!
- mti C2 cam ok for tnt 150 shot?
- NOS on Stock
- NOS 5177 open noid dyno results today...
- TNT, What are you jetting?
- Any one have have a problem with the 15lb NOS bottle siphon tube?
- 125 dry shot?
- Damn it, what is the NGK TR6 part #??
- tnt 150 shot need 2 pcm's to run good N/A?
- Progressive controller suggestions
- Paging NITROUS OUTLET
- Please Help !!!!!!!!!
- what nitrous kit is the best to get?
- ? about fuel setup
- differences between tnt f1 and f2 kit.
- Window Switch Setting
- TNT 200 shot, should I try it????
- GM EFI KIT FOR SALE
- Put the 175 shot on this weekend
- How to mount a 20lb NOS bottle in the back....
- What size bottle nut adaptor for 20 lb NOS bottle?
- Need Help with NOS bottle fast
- Bottle Pics
- Nos Bottle Mounting ?
- Nitrous and Cam question
- TNT wet kit jetting question
- Anybody using the Harlan window switch?????
- bottle heater: relay or no relay?
- need help wiring tcs switch as arming switch
- just got a NOS 5177 kit how long will it take to install????????????
- can i run a 100 dry shot on TR55's?
- help set me up...
- 3800 Extreme Vig + 125 TNT F2 Kit....few ?'s
- NX MAF
- nos
- Spraying?
- Will this setup work?
- I need some help with NOS remote opener
- spraying through shifts
- Some questions for a 1st timer
- Which will give more power to the wheels????
- NOS window switch and pill?
- Nitrous Express kits, pictures, and testing
- MMS 218 & Nitrous
- sprayed for the first time today need some advice
- Should I turn off my heater when I make a pass???
- Question about new direct port setup
- Need Nitrous Filter and Window Switch
- TNT Bottle Heaters?
- NITROUS EXPRESS
- nitrous on M6
- NX Bottle
- Where can I get custom cut lengths of fuel line for nitrous kits?
- 85mm MAF + NX=?????
- adverse affects of nitrous
- Nitrous jet question???
- N2O with k&n fipk kit
- bottle heater?
- What I did wrong with connecting my MSD window?
- Any particular reason I couldn't use a NX kit....
- Dealing w/ Nitro Dave's Performance...
- anyone got the wirring diogram for NOS 5177? I need it
- NX heater Install Questions
- Anyone have the new Ramchargers Timing controller yet?
- Need help with nitrous install ASAP...
- Help w/Fuel System
- Selling a complete NX system
- Want to spray 100 shot with heads/cam - keep SY3500 or go with PT4000?
- Newbie Question....
- 175 shot nx ?
- Nitrous Outlet
- Need Cam suggestion for 383 looking to spray
- Fuel line leaking
- Question about a FRED
- WTB: NOS 5177 system polished
- My NX Install....
- Nitrous Experts Inside Please!
- Need Help with wiring diagram ASAP!!!!!!!!!
- 01WS6 w/100 shot Vs. 01 Supercharged GT
- NX switch panel???
- Relay question?
- Fuel pressure
- Nitrous problems
- Fastest internally stock on the juice??
- Window switch help
- NX Switch Panel
- Running Wet System as a Dry one?
- NITROUS ON A 94,000 MILE CAR?
- NX TPS Switch
- Window switch.. safe cut off range?
- Do I have to wait to spray on a new motor?
- For a head/cam 1998 LS1...should it have an upgraded fuel pump to run a 100 wet shot?
- bottle trade
- nos heater
- Wet kit question
- ho much is too much n20
- Best dry N20 Kit
- Custom N2O bottle designs
- HELP HAVING PROBLEMS WITH TNT
- Lets hear about your Nitrous setup
- Can someone post or fax me the TNT wet install..
- Someone Help with this Problem!
- I remove the schrader valve for a wet kit, correct?
- Tried again, but going very lean with 100 shot on my H/C car
- cold fill connection stuff.........
- Info on Nitrous Oxide on a LS1
- Hi compression Q's
- Jet #'s for TNT F1 kit ??
- Newbie Question - - 150 shot ok?
- Pump #7 w/nitrous Yes/No ????
- bought Nitrous finally
- Gettin out of the n2o game
- Need help with Nitrous Install...
- How much is too much?
- Fuel Pressure?
- SECO seals to seal leaking fittings
- NEED HELP WITH SOMETHING FAST
- Anyone with Vig 3200 & 100 shot, what does it flash at?
- ordering tnt wet kit what all needed? purge/heater/msd
- What's a window switch???
