- Will stock injectors work.....
- Question???
- Plugs ...
- stand alone install ?s
- Thermostat/fan settings for spray
- 100 shot and timing ??
- Need input on this nitrous kit pronto before i buy
- my solenoids big enough for a 200hit?
- Update...Nitrous Outlet
- Building a Daily driver 347 with occasional spray, what pistons?!
- FS: N.O. C5 90 mm plate system complete w/ extras
- LS1 Victor Jr...Which 4150 plate
- need help on a nitrous kit
- Window switch RPM signal E38 PCM
- anyone running the hsw 92 plate kit?
- Bottle Valve ?s
- 04 c5 zo6 C/E nitrous next wich kit?
- Upgrades Needed for 150 shot?
- NOs bottle high flow valve--cant open it
- HSW kit - Need Diagrams
- MicroEdge question - separate stages for fuel / nitrous + progressive
- Moving difficulties
- timing retard, window switch, 2-step all in one?
- "old nitrous"?
- Experience nitrous and HSW users and experts please open...need help
- Cons of nitrous
- thinking of selling my lsx parts???
- Tuning for higher elevations-C6Z06 ?
- new to nitrous
- Anyone use the Brisk Racing Plug GR12S
- What pistons and rings are you running?
- Shopping list
- Cold Weather Special!!
- 1/28/11
- E85 nitrous jetting
- best spark plugs?
- Stock ls1 needs a good n20 cam!
- How much NOS can my car take?
- 10.46@133
- Proper pression?
- only using 1lb if nitrous per run..
- High Mileage H/C Car
- installing a spray bar in a 4500 to 4150 adapter?
- need advice on the safest way to administer the N2O
- Carter01 goes 9.97 @ 133.26 today!!!!!
- Need a reputable Shop in Dallas TX for 632 fulton carb'd, fogger?
- TSP 440ci LSX + Nitrous Outlet Lumina SS Dyno
- Need help in fixing my N2O system
- looking for advice for my setup.
- Nitrous Outlet!!!!!!
- Cool 4150 plate I designed...
- Direct port im working on...
- Best FBody Headers for Plug Access (inspection on juice)?
- Harris Speed Works Microedge?????
- Rings for stock LQ9 pistons?
- Hidden Setup on a 6 speed
- Quick question
- So today...
- Are these the right plugs for me?
- what else do i need with my kit? fuel pump? wat kind??
- Into the 10s Finally
- IAT Connectors/Extension
- New issue
- anybody use this weiand air gap, better than ls6 intake?
- Nitrous Outlet= THE FLU
- New lq9 build nitrous advice please
- 1" Nitrous Plate?
- 4150 n2o plate questions
- Timing question?
- NX Gemini Twin plate install pics
- Window Switch
- stand alone question
- F Jo controller or nitrous outlet
- 8.50s or better with a 250 shot?
- anyone running nitrous on a 98 block?
- SDPC Short Block Limitations?
- Any dry fogger guys??
- Is it time to say goodbye to nitrous?
- N.O.S. Single Stage Fogger what jets are needed
- Switching to PatG nitrous cam worth it???
- nitrous motor
- new to non carbureted no2
- So close!!! 10.00 at 133.41
- Separate fuel cell photos
- How hot is too hot?
- I figured out how to hide my nitrous...
- Another N2O outlet Bad Ass Job!!!
- Help me rebuild for N2O
- Need advice for 2 bottles w/ heaters?
- Nitrous After Cam Install!
- Stand alone fuel or off the rail?
- LT1 Problem
- dyno tune nitrous kit
- car for sale!!!! great deal!!!
- March 2011 issue of Gm High Tech Performance
- high compression with nitrous. what plugs?
- Asking for trouble to run Nitrous on top of my current setup?
- What rods and pistions
- Would you buy this for your bolt on LS1???
- I think i made a boo boo....tell me what you think
- head gaskets?
- Zex wet kit parts
- Tunerpro Timing table
- nitrous controlers
- Happy New Yr's
- Cold Fusion----anyone ?
- best location for activation button and purge switch
- What are you guys running with a Cam only car and 100-150 shots?
- SlowTruck
- Video of the 7.86 @ 177mph pass ....
- nano port
- Br7ef or br6ef
- auto trans guys come in
- Nitrous disc
- finished up my nitrous outlet nitrous install...pics, UPDATED 2/26
- Best way to hook up multiple grounds
- Nitrous problems..cutting out!!
- New Times on 7 cylinders
- 100 wet shot
- used 12 bolt rear axle kit & gears purchase guidance
- Dry shot tuning on 2002 Camaro
- HSW have any new years specials?
- what cam should i buy help
- TNT F2 kit with NX jets, what sizes to use?
- Track times for my carb'd SBC 4th gen
- Gain from larger headers?
- big thanks to nitrous outlet for a badass job
- Need to wire my nitrous kit
- Using N20 to roadrace?
- Merry Christmas!
- will a nozzle stop flowing after 150 shot?
- plugs for new engine
- 4.125 stroke and nitrous
- want to go to 100 wet shot
- best kit for 2005 GTO
- how much for a good nitrous kit?
- lt1 nos kit?
- direct port nitrous on LS1 question/?!?!
- Direct port on a Vic Jr?
- NX Christmas Sale!
- 98 ls1/t56 nitrous
- Is it safe to spray with notched pistons????
- Problem installing nitrous outlet LT1 plate!
- how much have you got in your nitrous system?
- dynotune nitrous systems
- spraying through shifts
- How reliable is a timing controller?
- This months GM Hightech
- blow down tube..re routed
- Opinions on this setup please.
- christmas sales...
- Got some new lines made!
- Will these solenoids work for N2O?
- Spraying in 5th .. BOOOOM ??? ..
- Help! Nitrous leak.
- Anyone have any experience with the 860 performance intake elbows?
- How can I run my purge out the vents on my Firehawk hood?
- stock 346 new motor
- Carbon fiber nitrous bottle anyone?
- Have dark spot on plug, opposite ground strap
- L92 heads
- Anyone know the overall height of a nitrous outlet 15 lb bottle?
- New PB 10.10 at 131 with 1.37 60ft
- Found pics of a 15lb bottle in GTO...how does bottle angle look?
- Post pics up your burnt up stuff!
- Ordered a Bullet Racing Cam
- 200-250 shot on 11.5:1 stock bottom end?
- anybody running the nos launcher?
- Nitrous Bottle Recertification
- Leaky NANO Valve?
- what mph gain 150 shot
- Max spray with 243/247 116 lsa cam
- Does any sponsor on here have a LNC-002 controller?
- Nano and other ?s
- Christmas Sale
- Nitrous advice ls2
- 3800 L36 firebird nos?
- which cyl is most important when reading plugs
- stock LT1 and nitrous
- effects of cam selection with nitrous cars
- NANO Check Valve Question
- Some M6 Launching on nitrous questions
- Help with a plug reading please.
- nitrous ? for LT1
- BONE Stock 2000 Z28+Nitrous
- MSD Timing Twister
- what should i go with
- Nitrous specialist installer needed in the NY, NJ area
- Fuel Octane VS Shot Size?
- What kinda base timing should I run?
- Which HSW kit for L76 intake?
- Out with the TH400, In with the T56..
- how much do you think I can spray
- Purge in CAMAR"O" plate (and some install pics)
- cyber monday sales?
- New PB and 60'
- NX pills in NOS plate question
- HSW Microedge 6-Speed Settings??
- N2RacingLS1's Survives 260'+ Bumper Drag on Dry Nitrous
- What's my limit opinions?
- Looking to get in the Nitrous game
- pics of battery post connection
- anyone spraying with a ms4
- Nano nitrous black friday sale!!
- Dynotune 100HP wet shot jets
- Tuning my new set-up for spray.
- tap into the tps for activation?
- wet or dry
- Painting Nitrous Bottle
- Black Friday Sale
- Nitrous + Fast Toys Timing Tuner
- Different types of relays?
- **LMR Episode #6**
- Any shops doing the Black Friday Sales Again?
- new system keep my cold fusion or use mt nos noids
- 1 gallon fuel cell as stand alone...how long would fuel last?
- How much HP will i leave on the table?
- what is the standard pressure for running a low pressurr stand alone
- Which plugs for a 150 dry shot
- Running dead rich on the bottle after cam swap
- Dyno tune nitrous plate
- Buying some acc., what else do I need?
- Nitrous build, 388Lt1
- Convert 04 Cobra wet plate kit for LSx
- changes needed for a 50 shot?
- Nitrous Outlet Big Show Purge Kits
- nos or nx
- N20 freezing water/methanol mix?
- n2o?
- N20 / afr?
- New PB 10.51 @130
- Looking for "how to" for nitrous activation & timing pull led light
- fogger or direct port
- Mounting a wet nozzle
- Tony Sheppard= Owns LT1 N2O Record
- Suggestions for a new shortblock
- TNT nitrous solenoid locks up after 1000 psi
- Can I do the relay trick?
- NOS bottle heater relay
- i think my nitrous outlet solonoid is locked up
- Will this 45 degree fitting hurt flow?
- Ok need to know if this fuel setup will work?
- Are all AN fittings good enough for nitrous?
- Nitrous Outlet Direct Port: Art with an Attitude
- My take at a DIY stand alone low pressure fuel system
- Spray 75, 150 or 175? Cam only ls1
- AES FAST LSX-R fogger
- Why is fuel jetting for a plate richer than the jetting for a nozzle?
- How am I gonna hide this? Added a few more pics 12/19
- need help? Plumbing my own nitrous distribution block.
