View Full Version : Nitrous Oxide
  1. miles on your N2O motor?
  2. What plugs and advice?
  3. LS fest 7 sec stock suspenion pass vid!!!
  4. Another win for Nitrous Outlet! LTX Shootout
  5. Nitrous newbie needing recommendations on a few things...
  6. LTX Shootout pics
  7. Looking for some pep on your GM Truck?
  8. New Personal Best at the LTX Shootout
  9. I have a couple of N2O questions. Zex kit, Nitrous outlet plate......
  10. Best way to hook up all the IGN on power inputs?
  11. n20 controller sugggestions...which one ?
  12. Pictures of Nitrous Dave N20 and Stand Alone and NANO install......
  13. Solenoid grounds
  14. Were backkkkk.... new times
  15. Thinking about a 100/125 dry shot....
  16. new nitrous system
  17. Affordable bottle brackets..????
  18. Low fuel pressure cutoff
  19. Anyone Running a wet kit on E85?
  20. What happens if you take out too much
  21. Ngk # ??
  22. Nano 3000
  23. Damaged nitrous rail.
  24. Soft Plume or Annular Discharge?
  25. NOS Jetting for correct fuel pressure?
  26. New nitrous record!!!!
  27. dry 50-75 shot ?'s
  28. Our newest Vehicle Specific Plate System
  29. Tool for direct port system
  30. Some racing related nitrous questions
  31. 100 shot= how may 10ths
  32. Done and done!
  33. NGK spark plug ?
  34. 3 questions for a friend?????
  35. We need your install pics---Round 1
  36. Manual + 2-step = how are you triggering a nitrous controller?
  37. 175 shot ignition issue
  38. zex blackout kit? what you think...
  39. Nitrous Tune ???
  40. help please!!!
  41. Questions on nitrous build?
  42. Tunnel Rams & N2O?
  43. 200 shot actual jetting???
  44. 2 stg plate kit for a 102mm intake
  45. New to nitrous / looking for a company and kit to buy
  46. rpm cutoff
  47. Pics of Nitro Dave's mounting brackets installed? Post em!
  48. 8.96 @ 154 ..... N/a !
  49. My nitrous is pissing me off
  50. Nitrous Shift Points
  51. thinking about running nitrous
  52. What size inlet on Nitrous Outlet plate???
  53. Vengeance Racing | Nitrous Powered C5 Z06
  54. Short Beck with Dual Stage DP
  55. Want to hide my kit
  56. Need N20 gauge with NANO?
  57. Are progressive controllers hard on solenoids?
  58. Mostly stock ls1. Wet or Dry kit?
  59. How much timing should I pull with my IAT resistor trick
  60. building your own standalone fuel system? or adding extra pump?
  61. Extending MicroEdge wiring harness
  62. Timing retard, ECU pin
  63. quick question , wire gauge
  64. Marcella intake/nitrous for the VA Speed 440
  65. nozzle angle?
  66. So who will be at LTX Shootout?
  67. Difference in mph, 100 hit to 300 hit.
  68. Posible for car to run better NA with N2o
  69. Hey N.O., C5 standalone fitment?
  70. wiring diagram, hsw is this what i need?
  71. N20 outlet solenoid bracket
  72. NX Remote opener help needed
  73. Spraying on the brake
  74. My homemade standalone pic ! !
  75. nano question
  76. Nitrous wire gauge size, please help!!!
  77. My bottle is leaking
  78. drilling and tapping for nozzles
  79. Ordered a N/O LT1 plate kit but have no instructions. HELP!
  80. What the heck is this
  81. Wire Heater to N2O Arm switch
  82. nozzle placement
  83. StandAlone Return Line Restrictor?
  84. zex nitrous kit help
  85. my dyno sheet- help choosing nitrous converter
  86. need some help with new setup
  87. ok everyone. please say hello to our newest mod!!
  88. My NX Fogger pictures........
  89. bigger injectors for my kit?
  90. correct jets for NOS 100 shot?
  91. 92mm Nitrous Outlet Plate on a 90mm FAST intake?
  92. Nitrous Instead of Cam and Bolt Ons.
  93. Need the Nitrous Sections help in what tracks you attend!
  94. Zex dry kit?
  95. Plug readers, tell me if im right.
  96. what gap and what plug?
  97. Which Plug ?
  98. anyone looking to trade direct port kit for plate kit?
  99. FJO Nitrous controller install question
  100. Nitrous tune?
  101. single plane nitrous question
  102. timing tuner help
  103. plate conversion
  104. Nitrous Express Bottle Orientation?
  105. Dry plate and NANO question
  106. Nitrous kit
  107. Thought I'd share some pics from the recent install
  108. Snows methanol question
  109. Nitrous line leak issue!
  110. Pics of HSW plates w/ solenoids
  111. stand alone fuel cell
  112. How do you remove an NX Lightning Bottle Valve
  113. New nitrous times in my 07 NNBS 4.8 silverado
  114. new f body stock internal record??
  115. Nitrous issues....
  116. Quick nano question
  117. ZEX Add A Stage Kit
  118. help please. where to hook up window switch to rpms?
  119. Do you have to respect the "IN" and "OUT" of a solenoid, or can they be inverted?
  120. Re-pinning Interface harness
  121. quick question...
  122. Timing retard
  123. Dynotune Jets 54/56 FS
  124. New Best
  125. Piston compression height
  126. Need help wiring nos 2 stage mini progressive controler
  127. Another Big Thanks to Nitrous Outlet
  128. Whats your Fuel Pressure when on the Spray?
  129. Clearances good for Shot?
  130. Box of goodness showed up today...
  131. Spark plug help
  132. 75 zex dry kit (making sure I have all my ducks in a row)
  133. 150 shot on single nozzle?
  134. ok, vote for the new mod here!!!
  135. boost + NITOUS!!!!!
  136. ZEX Bottle Opener, Can I still use a pressure gauge?
  137. top end spray problems!!
  138. HSW Interface wiring question
  139. Thank you Nitrous Outlet! 8.97 @ 151.05 mph
  140. how many people using a4 with spray and 12 bolts?
  141. mallory 685, lt1 help
  142. N.O hardlines? Im confused and a bit upset
  143. refill question
  144. Is it just me, or is this confusing?
  145. Problems getting spray to work.
  146. Bad fill?
  147. Plug gap question
  148. Carbo/soot buildup in my intake runners??
  149. Suggestions before the new bullit goes in..
  150. Are my times slow???
  151. Nano Bottle Question
  152. GMHTP Shut Your Face Race
  153. Anyone using Brand X?
  154. Any downsides going wet plate to nozzle?
  155. Problem with my NANO not getting full!
  156. whats next on the list of to do's?
  157. Should I spray?
  158. Who has gone past a 150 on stock shortblock?
  159. What size dry jets? getting mixed info
  160. Whats the best rear end gear for Nitrous
  161. Piston limits
  162. what all do I need
  163. everyone please read this!!!
  164. Look at My $999.99 Plumbed Directport
  165. nitrous jet ?
  166. Wheres a 12v source always on?
  167. trouble shooting....Granatelli window switch
  168. Will i need to retune?
  169. please help nos 15982 2 stage window switch
  170. Ordering N/O LT1 Plate kit, what else do I need to buy?
  171. Is it worth it for me to use e85 with my nitrous?
  172. High Compression Engine..Should i spray it?
  173. ZEX MNU Insides Plus Rewire for MSD Window Switch
  174. Can I run the heater power wire next to wideband/guage wires?
  175. dry setup help. Stock C5
  176. Maybe I am missing something????
  177. Why you need the Nitrous Express Lightning 45 Bottle Valve
  178. how to connect this ????
  179. Nitrous Outlet is giving away a free nitrous system!
  180. Money Maker VS Plate System
  181. trans mount..can you see gage
  182. Link to Nitrous Tech Notes
  183. N.O. remote opener having trouble closing
  184. Stand alone? need to know now,lol
  185. NANO on a featured Corvette
  186. Cam+spray guys, if you were to do it again....
  187. HSW Solenoind Brackets for Fast 92
  188. What makes a cam better for Nitrous?
  189. what fuel jets for my setup?? (HSW 78mm plate,fuel pump etc)
  190. How many pulls do you guys get out of a 150 shot in a 15lb bottle?
  191. couple nitrous questions
  192. Bottle Issues
  193. Final parts needed, questions.
  194. Need info on timing trick
  195. Speed Inc./ Nitrous Outlet 10% off sale!!
  196. C5 Z06 NX 150 Wet kit Install begins.
  197. Gearing question for the solid roller guys
  198. Nitrous wont fire?
  199. Anyone with MS4 on the kit, come in
  200. Experts tell me about my plugs. 1st 200 shot.
  201. MSD DIS4, two step, and SLP line lock: 6 speed cars
  202. What can i spray safely?
  203. What makes one wideband better than another?
  204. Maf
  205. FJO vs NX Maximizer 3
  206. marshal pressure gage
  207. Nitrous "hiccup"??
  208. Dry setup
  209. Nitrous Outlet dual stage plate wiring
  210. So confused now about tuning nitrous. Help please.
  211. best tune
  212. Just curious will 2 step colder plugs make you lose power na?
  213. Should i get nitrous?
  214. Looking to add a little nitrous off the line
  215. 408 N20 Fogger Question
  216. 02 Sensor Question
  217. question about my guage
  218. HSW switch question.
  219. Nitrous, retard timing by torque increase?
  220. Using Teflon tape or paste on fittings
  221. What PSI should i expect form a 200 shot?
  222. first time with nitrous. m6 car
  223. Do you need to Purge?
  224. Nitrous Refills here at Speed Inc!!!!!!
  225. Nitrous Outlet fogger dyno results
  226. Stand alone fuel pressure setting????
  227. Dynotune install easy?
  228. 383 guys..
  229. nitrous on stock lq4 block. whats safe
  230. timing tuner or hsw interface which do you prefer
  231. Custom Diamond Nitrous Pistons arrive and you wont believe this!
  232. bottle opener?
  233. LT1 with direct port
  234. nitrous on a stock stall?
  235. Need some advise
  236. Looking for this fitting
  237. tnt pill sizes
  238. LS4 N2O Quick Questions.
  239. ltx intake with fogger
  240. AN Fittings
  241. New Best N/A and Nitrous Dyno Numbers
  242. how cool is this!!!!!!!
  243. Nitrous Wiring Question (Diagram Included)
  244. NITrous problem? need help
  245. Breaking in motor question
  246. Jet question.
  247. standalone fuel pump?
  248. Newbie nitrous questions
  249. stock pistons and a 200 shot?
  250. direct or MAF kit on Fast 90/90?
