- Nitrous wont fire?
- Anyone with MS4 on the kit, come in
- Experts tell me about my plugs. 1st 200 shot.
- MSD DIS4, two step, and SLP line lock: 6 speed cars
- What can i spray safely?
- What makes one wideband better than another?
- Maf
- FJO vs NX Maximizer 3
- marshal pressure gage
- Nitrous "hiccup"??
- Dry setup
- Nitrous Outlet dual stage plate wiring
- So confused now about tuning nitrous. Help please.
- best tune
- Just curious will 2 step colder plugs make you lose power na?
- Should i get nitrous?
- Looking to add a little nitrous off the line
- 408 N20 Fogger Question
- 02 Sensor Question
- question about my guage
- HSW switch question.
- Nitrous, retard timing by torque increase?
- Using Teflon tape or paste on fittings
- What PSI should i expect form a 200 shot?
- first time with nitrous. m6 car
- Do you need to Purge?
- Nitrous Refills here at Speed Inc!!!!!!
- Nitrous Outlet fogger dyno results
- Stand alone fuel pressure setting????
- Dynotune install easy?
- 383 guys..
- nitrous on stock lq4 block. whats safe
- timing tuner or hsw interface which do you prefer
- Custom Diamond Nitrous Pistons arrive and you wont believe this!
- bottle opener?
- LT1 with direct port
- nitrous on a stock stall?
- Need some advise
- Looking for this fitting
- tnt pill sizes
- LS4 N2O Quick Questions.
- ltx intake with fogger
- AN Fittings
- New Best N/A and Nitrous Dyno Numbers
- how cool is this!!!!!!!
- Nitrous Wiring Question (Diagram Included)
- NITrous problem? need help
- Breaking in motor question
- Jet question.
- standalone fuel pump?
- Newbie nitrous questions
- stock pistons and a 200 shot?
- direct or MAF kit on Fast 90/90?
- N20 and lsx?
- direct port on standard manifold
- Gapping rings for nitrous? Why not for expected torque amount?
- Nitrous backfire ?'s
- Direct or Plate on FAST 92??
- best way to setup n2o on m6 car?
- Finally dyno'd w/150 shot. good or bad?
- HSW solinoid issue I think.
- Leaking out the purge
- Nitorus Outlet Progressive Controller
- 617HP all boost 4.8L..now running 75 dry shot
- hows this for a nitrous cam?
- Running wires through the front of the intake (see photo)
- need ingrediants for a fast cam and spray ls1
- Gears for H/C A4 with 150 shot
- $999 Direct Port Installed
- help with n2o
- High or low pressure for my standalone?
- whats the best kit for my setup??
- bet place to mount fuel pump??
- Thinking of upping the ante
- 383 h/c/i and over a 200 shot
- Removing NANO system, retune?
- A Time for Change, Nitrous Outlet No longer offers NX products.
- Corn and timing
- Question about low pressure fuel systems
- MicroEdge users come in side
- Resistor Mod (Yeah I know again)
- N/O Progesssive contoler wiring ??
- Mechanical gauge install and fitment sucks!
- okay whats a good all around plug foor my set up
- E85 and n20? Anybody here?
- Steps for spraying auto???
- nitrous out let ! i need your help
- nitrous rich WTF help
- rear mount or spray
- Little help here. Wet or dry? I'm new to this stuff.
- When tuning at the track, when is it better to spray the first 1/8 or the last 1/8
- Could I have gotten a bad batch/bottle?
- Lookin to upgrade to direct port
- MicroEdge & LC1 question/opinions
- New motor. How long before you can spray it.
- 150 shot real world jetting?
- finally i installed my N2O 2nd stage
- safest nitrous kit?
- If you know how to hook up a STAND ALONE COME IN HERE PLEASE
- Quick question about wiring (using Timing Tuner & Trick Performance V gauge)
- Nitrous for Dummys, got the purge kit mounted, now what?
- Pics of where you guys mounted your bottles!
- Speed pro-Hypereutectic aluminum pistons?
- check out my plugs 250 shot...
- Quick question
- It has begun!!!!!!!!!!!!!!
- how much can i spray
- Tuning based off plugs.....
- What caused my plug to look like this?
- Ls3 Camaro Plate System
- How about 150 shot and done?
- Fast intake burst panels
- fjo question
- Lean spike when spray hits
- TNT F2 plate kit, what are your opinions?
- ml 2000 efi kit work on lt1
- Small video of my purge kit!
- Nano leaking
- Have NX Dual Nozzle Kit, want to go to a Plate. Help! Pics inside
- Can a ls based nitrous motor go over 140 in the 1/8?
- Trick Performance "trick box" window switch. NEED HELP ASAP!!!
- Nitrous??? need details please
- aftermarket fuel pump after what size fuel jet??
- Nitrous Oxide and tuning?
- New to N02
- weird HSW n20 gauge
- here's a silly question...
- Just sprayed for first time.
- can it be done 10 's with bolt ons and spray
- 2-step with progressive controlled nitrous
- hsw micro edge controller?
- What yea think bout my standalone set up?..
- hey
- Just how uneven is the airflow on the Vic. Jr? pics inside to illustrate
- NOS Plate question
- Blow Down tube?
- Fuel Supply Qs
- nitrous kit help
- Another cool video we made..
- Nitro Dave's Halo results inside
- Damn.. Bottle went empty?
- TNT F2 vs plate systems
- Best way to control difrent functions of a NO2 kit.
- Thinking About Spraying.. Need some help please!
- which nos kit?
- HSW kit soon...is this all I'll need?
- What's best to seal gauge to bottle?
- Can my setup drink 150 - 200 shot of nitrous ?
- Nitro Daves plate compatable with a Zex kit?
- Device to Display Timing Being Pulled??
- Would My System Work On An LT1 Or Other Car?
- Lowering window switch, gain et and mph?
- ideas on Installing nitrous on a Procharged engine
- Hit nitrous, only fuel selenoid kicked on, now car goes lean at wot.
- I might have to switch my kit to a different car lol
- n20 noob, help plz
- Speedtech Nitrous
- Looking for some Nitrous footage
- For the guys looking for the ultimate in nitrous control...
- window switch/ timing retard contoller
- best wet kit a/f?
- HSW MicroEdge+ Does it have a pressure sensor? Any installed pics?
- TNT Nitrous Install
- Will I be safe running 100-150 shot?
- Can I just run a fogger nozzle or is a plate needed?
- Spark plug tuning video
- Join us on Facebook, Receive a Shirt!
- What do you guys think of my setup?
- damn damn DAMN
- seem lean 13.1 A/f
- single noid dual nozzle quesiton
- What size shot would it take to empty out a 10lb bottle in a pass.
- nitrous and altitude
- Nitrous Problem
- Pulling to many volts from the tach wire?
- Nitrous Outlet 78mm plate jetting
- 26 degrees, still pull timing?
- Wideband cutoff switch.
- NX bottle opener/ Nitrous Outlet bottle?
- Plugs and tune HELP
- Solenoid nut missing pic inside..
- does a 15lb bottle take alot longer to heat up than a 10lb
- who can i get to do me a wiring diagram for my set up?
- Tuning methodology questions
- What direct port kit should i go with??
- NOOB Questions???
- another nitrous purge ?
- sponsers step in
- Nitrous purge kit advice?
- hey nitrous express can i order some new stickers for my solenoids
- how many 1/4 runs can you get witha 100 wet shot with a 15 lb bottle
- Anyone tried Zex nitrous plugs?
- At what HP levels do lean rear cylinders start showing up at?
- Can I still get a tune?
- How to tell if a solenoid needs rebuilt?
- Cool video we made.
- nx proton plus or other cheap kit?
- what does nitrous do for you?
- 91 octane vs 50/50
- BR7EF's...ok for a DD?
- question about warping the decks...
- Vertical Bottle?
- window switch in M6 car
- C5 zo6 tach signal wire location
- nitrous switches
- need some help with surging issue
- New Engine build 408 W NITROUS OUTLET D.P
- Re-tune for a 100 shot or not ????
- need a wiring diagram
- Good cam?
- how to destroy a stock bottom end
- Nitro dave 2010 camaro kit.
- calling anyone from HSW, please let me know what you think?
- Rookie standalone ?'s
- timing tuner controller
- Ls powered 69 on the bottle
- How hard is it to change a bottle valve?
- Just had my bottle filled.
- Okay got my n20 going, but now Im loading up on fuel?
- 125 wet shot on a stock a4 torque conerter!
- plate question
- HSW 90mm plate jetting?
- having trouble with my nitrous setup, can anybody help?
- Nitrous Outlet, come here!
- n20 outlet plate question
- Whats a "safe" setup for me?
- Best stand alone system?
- how can i tell if i have a hsw microedge or microedge plus?
- Nitrous Outlet GM Truck Vehicle Specific Plate Kit
- please i need TNT jets
- Second Fuel Pump fo Nitrous Setup
- Backfires after spraying?
- timing
- My DP setup...what you think?
- can a convert this d.p. to fit over my fast??
- Pulled the Motor and found......
- how to connect two stg in one big show purge ?( post pic )
- NX just stopping by
- Dave is the best....First 2010 Camaro in the 5's
- 2 step and nitrous??
- Progressive System for Carb'd Set-up
- how nitrous works
- Some info on N2O plz
- Nitrous tuning question
- microedge ?
- No tune 150 shot
- confused on what plugs to get
- br7ef question
- 200 shot on stock LS1?
