- Can a NO2 solenoid be used for fuel?
- quick question
- n20 shot?
- stupid wet kit question
- Purge Not Working
- Custom bottle mount installed!! check it out
- Ordered a HSW kit today.
- Took me a while...
- anyone spray an 04 Z06?
- wet kit hook up. using fpr?
- anyone using big shot 4150 plate with high fuel pressure?
- Ngk r5724-8
- Nitrous problem
- HSW The Interface w/ EFI Live
- Getting the Facts.. Part 1
- as if u turned the key off?
- BOOOM!!! 4th of July Nitrous Deals!!!
- New Setup: Daves Plate and HSW Standalone
- Check my setup
- pics of custom tunnel mounts?
- nitrous bottle stuck open?
- power wire locations?
- Best way to mount nozzle post maf??
- Stand alone question?
- stock ls1 + nitrous
- nitrous works lt1 jet question
- N2O outlet fuel cell Please Help!
- Finally, new 2009 Nitrous combo is done.....Pics within
- Dry kit question
- Pre maf or Post maf
- not able to spray, why?
- What brand of nitrous to buy money no option(NOS NX ZEX OR OTHER)
- Tps and rpm wires on pcm
- So many headaches, help!
- Nitrous Question
- HSW single nozzle kit to 4150 plate?
- Lets have some discussion on nitrous tuning with HP Tuners or EFI live
- Wiring Diagram
- FINISHING NITROUS W/HpTUNERS
- New PB thanks guys
- Two stage nitrous guys, ? about pressure drop in the bottle when hitting 2nd stage
- nitrous and intake question
- Excellent New Nitrous Book
- New to Nitrous-dual stage, direct shot...
- Placement of nozzle of dry kit on LT1
- Whats the matter with my Nano?
- please need help about Power relay
- Hesitation with Nitro Daves window switch
- can i make my own nos line my noids are 6-8in away from nos plate
- So im gonna do it
- Nitrous Outlet dual window switch users - Quick rpm settings question!
- Nitrous kit wires
- FJO progressiver mini controller
- Is the heat effecting my electronics(Car acting crazy in heat)???
- Need jetting help...search didn't get me anywhere.
- Quick Switch Panel Question
- Wiring Question
- Help with nitrous not spraying
- Where to hide solenoid, lines, nozzle.
- AR94's or TR6's
- LS6 TPS Signal Wire
- Nozzle Placement
- Making the zex system better?
- NX 85mm MAF kit fitment on F-body
- Harris Speed Works interface controller
- dry NOS nozzle placement
- Need help with TNT F1 kit
- Nitrous Jetting/ Math Question
- Nitrous A/F and weather changes?
- Help with Maximizer II config
- CTS question???
- How about a Vid thread???
- Nitrous problem
- Can I use Constant Instead of Switched 12V+?
- Diagnose Help
- Best dry nozzle to mount post MAF
- Dedicated Fuel System?
- Getting The Facts
- nitrous in iowa?
- Using Jumper Wires for Switch Panel OK?
- air in nitrous.......
- TPS wire
- blow down tube
- Best Bang for the Buck Dry Kit?
- What is everything needed for install?
- Nitrous newbie
- LT1 + Nitrous = ?
- What if we pull timing on our 32 degree tables then unhook our iat?
- 2 stage question
- Switch Panel for 95 m6?
- tr6 plug and colder?(issues)
- converting dry to wet.
- for old hands is my diagram correct ?
- 100 dry shot will i regret it?
- Thinking about nitrous, LOTS of Questions!!!
- Need help added 100hp no et gain.
- microedge help
- Can you hear the fuel pump in your HSW fuel cell?
- pics of your exterior nitrous emblems on your car
- purchased Ashtray Switch plate and want help for installation
- question about fuel HSW solenoid
- Do most peeps run the same fuel through motor/n2o system.
- Are you NANO users happy with it?
- Progressive controller accuracy???
- pics of wot on lt1
- nitrous and turbo combo?
- Is this a big no-no?
- nitrous help/need pics of your installs
- Huge Thanks TSP and N2O Outlet
- FS: Innovate LM-1 Wideband Setup
- why do more prefer wet over dry??
- The best way to adapt my generic ZEX kit for LS1.
- 100-150 dry shot
- N20 nozzles snapped off in cast manifold, how to fix?
- nitrous launch, foot brake car, tips?
- 300+ on L92 heads?
- MSD Window Switch Problem??!! Help
- Nitrous 100shot ls1.
- Spraying on the transbrake? Who does it?
- question for zex
- Stock LS1-75 Shot- Will I regret it?
- 430whp ls1 wants nitrous ;)
- TNT pill sizes
- Need 2 things: Size of jets for what shot(Nitro Dave kit) and Timing tuner
- Trade 90mm wet plate for a 78mm
- HSW Interface Question
- what kind of plugs for a 200shot 383
- lets see cam + nitrous #'s only .
- What block for NOS?
- the man is trying to take my spray away!!!!!
- Where to refill in Waco TX
- Dry directport for sale
- conversion from dry to wet??
- Went to the track this weekend and ...
- Any advantage of plate VS nozzle?
- TNT Nitrous Jets Specs cards
- Still trying to finish the tune. IDLE clip vid.
- New best 5.50 @ 130 mph
- setting up a dry shot
- New best on 1 stage (175 shot)
- question
- nitrous problem
- Rwhp loss.
- Got my intake back today
- Tnt pill?!?!?!?!?!
- First install on lt1 - questions
- Where to run main nitrous line from bottle?
- Looking to play with some spray
- Help me trouble shoot my Microedge and interface setup from HSW
- Timing retard for a 100 or a 200 shot...
- Wooo hoooo
- msd digital window switch and zex...
- Fuel system problem???? Help!
- Zex 82026 Yay or Nay?
- TNT Power ring question
- Where to purchase nos plumbing
- What do i need?
- microedge rpms
- Fuel supply for wet kit CTS-V
- stuck throttle after HSW plate install
- LS3 fogger for sale
- standalone line
- Why is my Direct Port Still Stumbling?
- whats the limit on a nx shark nozzle
- Just got an iroc and want to spray it any suggestions
- Heres whats keeping me bussy right now!!!
- NOS launcher or FJO Digital progressive controller?
- N2O+SLP Maf=?????
- 104 unleaded and Nitrous HP limits?
- Full Throttle Timing Tuner settings...
- stock ls2 handle 200 shot wet?
- So we make the top ten?
- Placement of nozzle in a 94 LT1 system Zex Dry kit
- How much should I spray it?
- Nitrous bottle ?
- Nitro Dave N2o kit need some help.
- HELP!!! installed Timing Tuner now car will not start...
- New best N/A.....
- Does anyone make a multistep nitrous retard?
- Spray and an MS3
- msd 8956 wont work??
- nitrous piston
- plate for lq4
- nx wet kit?????
- How do reverse splits like n20?
- Bottle Pressure in the summer heat
- planning to add 2nd stage
- How much is too much!?
- LT1 TPS/WOT and Tach
- HSW fit for LT1?
- Installation Service
- MSD 8969 WS wiring??
- Progressive set up w/ M6?
- How to set up a/f shutoff?
- nano question
- Solenoids pulsing when armed...(I searched)
- bought me some goodies
- Wet Kit ?'s
- June Nitrous Specials at Nitrous Outlet
- nitrous on fresh motor...how long before?
- Those who use AEM widebands
- Rip out and reinstall
- Nitrous Noob Checking In
- Injectors for my setup
- my buddy finally sprayed and wow afr=10.9????
- zex install quick question.
- Cost increase from wet to DP
- how big of shot can I take
- Zex kit
- Critique My Kit
- NANO Introducing 2x Payment Plan
- question about fitting size upgrade
- First time out for a nitrous newb (C5 Z06)
- Any Vendor Summer Sales???
- question
- pressure switch location question
- Direct Port on Sheet Metal Intake?
- nitrous question
- firewall access
- Timing Control
- Will an NX bottle opener work on a Dynotune bottle?
- F/s lm-1
- Fuse box standalone and AIR
- Who has actually killed an engine with spray?
- nitrous ready?
- jetting for NX MAF kit
- how do u hook up a window switch for nitrous
- Nirtous fitting question
- need info
- Nitrous cutting in and out.
- Nitrous problems...
- New Best at the LTX Shootout
- Stall speed ok for N2O?
- wet plate kit on a budget
- Quality of "brand X"
- HSW relays
- purge line
- n2o Question
- 440 LS7 and some spray!
- burbling and popping...
- nitrous not working?
- Looking into nitrous..
- hsw purge kit
- tr6 spark plug gap?
- Anyone using Nitro Daves bottle nut/nipple
- Post pics of your setup
- lt1 nitrous works plate jets?????
- tnt
- Wont spray??
- NOS Plate kit was working.. and now its not!!?
