- Upgrade pump and injectors with a 150-175 wet ?
- How reliable is a TR8 plug to drive to the track
- bottle opener for NOS system
- Help with Dynotune Digital Nitrous Gauge
- will this feed my setup?
- Nitrous Oxide Laws
- Wet kit users: What bellow do you use?
- what do u guys think about zex
- TNT power ring and NX nozzle question
- How many runs do you guys get out of a 10lb bottle with a 150RWHP shot?
- Nitrous & Fuel Solenoid
- how should i do my 2 stage setup?
- Nitrous cutting out
- IAT Sensor Info for 4th gen Fbody...Voltage range???
- Can someone review my Wiring Diagram and plan...
- Billet fuel rails for NOS on LS2 Vette??
- the same old question
- Pictures of Nitrous Set-Up
- Pulling Timming ?s
- MSD window switch on an ls1?
- "money maker" question
- Questions OPINIONS
- NANO 3000psi Series on SALE NOW!! Thru 4-30 LOOK!!
- Need your n2o expertise for my DD
- need nos sticker on bottle?
- New Guy
- Need advice on my carb. Cheater set-up!!!
- Reading timing mark w/ race fuel??? Pros ONLY!
- NOS launcher or FJO digital progresive
- Lingenfelter Timing Retard Unit
- Motor is in .... still ALOT to do !! (pics)
- Best way to run dual bottles?
- Looking for Nitrous Outlet (side inlet) 78mm plate
- Nitrous Install Help in NJ
- 12 volt remote wire for nitrous (need help!)
- How did you guys mount yout tanks behind the rear seats?
- average hp pick up
- Happy Easter!!!
- Convince me.. I want to be convinced...
- in-line fuel pump
- Fuel saftey pressure switch for nitrous
- Alright sponsors get my taxes lets see what yall got
- nitrous kit
- PICS!!! Nitrous Supply Fogger & Edelbrock Super Victor w/ Holley 950HP
- Quest for 9s w/ the help from NITROUS OUTLET
- Need advice using N2O with 4400 Vig. Stall, and 4.10s...
- Trying to get the perfect afr.. questions
- Fittings needed to tap into fuel rail
- Perfect afr in begining but way rich by end
- Installing Nitrous from Nitro Daves have two questions
- Nitrous on stock clutch.
- Can any timing tuner be seen in ecu with hp tuners?
- Robert56
- Dynotune nitrous kits
- Installing a 100 Wet Shot
- RPM switch/Shift Light wiring
- What cleaner should I use to clean fittings in my nitrous system?
- 408 LS1 Fogger
- Mount nitrous bottle side ways?
- Would #36lb injectors be enough?
- Bad seal on Bottle
- 550 rwhp 150 shot, TR6 or TR7
- which aluminum intake?
- ? about the harris speed interface...
- Hey guys check this out!!!
- Low Pres Stand Alone
- Haven't sprayed in a while
- Mismatching NANO systems and bottle size?
- Correct Spark Plug Gap?
- Name some issues with dry shot.
- Feed line routing.
- dry nitrous question
- 408 tuned for spray
- Using higher octane on Nitrous Fuel Supply
- Nano mounting options?
- Done deal first nitrous kit on the way!!!!
- stock bottom end
- Opinions needed.....one bottle or two?
- To advance cam, or not?
- What nitrous controller/s for basic progressive wet kit
- 112+4 lsa safe for a 100 shot dry???
- Sizing injectors/Newb questions....
- Pics of NOS Bottle mounted between the rear seats?
- HSW Interface installation
- I wanna run nitrous
- how much can an ls1 handle?
- Do you think you can see nitrous flowing through a transparent intake manifold?
- Trickflow "P" Gauge
- How to test the solenoids?
- What's causing this spark knock on the N20?
- Air fuel gauge
- Can I fill a Dynotune bottle without one of the ports filled?
- Timing Spike at WOT
- Nitrous Express NXL nitrous kit
- 6.0 iron block do's and dont's
- Plug
- Lesson learned
- What should I gap my plugs?
- questions about Trick Performance Volume Gauge
- Reverse split cam and nitrous?
- Safety disk torque??
- c5 z06 results from 75 shot
- Anyone running a N2O Outlet 78mm Wet Plate Kit?
- How much nitrous can my LS2 hold?
- Where to mount fuel pressure gauge?
- What jets can I use for TNT nozzle?
- Fuel gauge - High pressure or low pressure??
- jets for 200RWHP
- How much are we talkin $$$$
- Where to mount FPSS switch, and window switch
- Direct Port Questions
- Need wiring diagram, nitrous outlet complete package, 90mm plate
- if any one can help me figure this out to what to do
- Pressure gauge hook up at solenoid?
- Nitrous - Most Critical Gauge Readings and why?
- 78mm Nitrous Outlet Plate $200 shipped
- lsx454 n20
- HSW good or bad?
- Defective HSW Bottle Pressure gauge?
- what window switch? oh and how??
- 10# 4500 psi NANO Kit For Sale VERY CHEAP!!
- Arming Switch
- LT1 and direct port setups
- Larger purge???
- newb to nitrous
- what clutch should be used if your running nitrous
- can someone from harris speed works help me choose a kit
- Recommend me a good cam for nitrous
- Purge question
- Nitrous Gauge?
- how much nitrous can a ls6 intake flow?
- 15 LB Bottle in Spare Tire Area
- Please help with my leak
- does a wet plate kit offer better results
- nos stainless fogger nozzle
- securing dry nozzle in a filter...
- push-lock blowdown tube
- how to mount a WOT switch
- how much nitrous to drop 3/10 in the 1/8???
- nitrous kit questions
- Now whats the difference....
- DP n2o
- TR7/TR8 what gap?
- Pulled motor out heads off burnt valve
- Are these the right plugs????
- stupid nitrous newbie question.
- Zex nitrous oxide pressure regulator
- my set up, is this ok? need some advices, (pics)
- Help me decide, Nitrous or FI.
- Plate guys question
- Help with TPS and RPM/Tach wires
- How much room for dry on 65lb my injectors
- 125 Shot of juice
- Pressure guage leaking
- HSW 90MM Plate what bellow to use?
- Thanks to Dynotune, Nitro Dave, LME, and Nano DynoCom Results
- 4.125 copper head gaskets. new
- ? On fuel pump upgrade for nitrous on my car
- FS Nitrous Outlet 78mm Plate Conversion
- HSW noid going bad
- hsw jet questions
- race fuel and timing tuner
- Mounting bottle perpendicular to car?
- about plate size
- Bought a HSW Kit used... got royally screwed - Bad Fuel Solenoid
- spark plug ????
- Nitrous Noob, be nice.
- What else would i need?
- Dynotune wet kit... do i need to remove schrader valve?
- Trunk mounted bottle mounting plate
- What else do i need?
- zex 82026 with timing tuner
- how much spray??
- Vette LS2 + 150shot ?'s
- need help with plugs on big nos shot
- Nitrous "will this work???"
- Nitrous + Traction Control
- nitrous question
- need help with buying the safest set up.
- Timing - 100octane
- Should I be running the 90mm plate on my LS6???
- suggestion on spark plugs and gap
- Stand Alone Fuel System Necessary?
- Question before I spray
- Nitrous Express Jets
- Wiring Diagram for Headlight Switch...
- WTT 78 mm nitrous mani for your 90 mm!
- Best timing tuner
- Cure for Sticking N2O Solenoid on Dry Hits, and maybe wet hits too?
- Putting together nitrous motor what pistons/rods?
- The true cost of n2o.....
- Plugs for street driven 500whp motor/200hp n20....
- 150 shot on top of a H/C + Stock bottom end car?
- NANO Ebay Items Listed!!!
- Bottle Exploded
- Anyone have the link to the dual bottle pics or could post some.
- Its done!!
- 2 stage help
- o2 variance under spray?
- 150 shot and gears?
- Wiring window switch
- Lifted a head
- ARP Bolts or Head Studs?
- Why nitrous NOW SUCKS for me...
- Went for more testing tonight, ran out the full 1/4 and got a new best!!!!!
- 2 stage plate system?
- 200 wet shot?
- No nitrous class at the LSX race...
- best place to mount the nozzle
- Nick@HSW
- Spark plug choice.
- hours of a Wet Nitrous install?
- complete noob to nitrous need help with fogger
- first nitrous install, need pics
- fuel line question
- Timing Tuner
- Dry before maf question
- Should I be scared of ramping up nitrous?
- Pics of Nitro Daves standalone system needed
- Help With the Mallory 685
- anyone with nitrous outlet rear hump bracket...
- NOOBIE AND I KNOW!! but somebody PLEASE!lol
- FJO progressive nitrous mini-controller
- plug gap
- ATTN: NANO Users Please come in!!
- FS 860 Bottle heater/bracket $160
- What nitrous i should get.
- Help me connect this solinoid to my system NX related
- RPM/Tach Wire for MicroEdge
- FS Nitrous Express SHARK/PRO-SHARK/SUPER SHARK NOZZLE
- Torquer 3 what LSA on 150?
- blow down tube?
- kit for sale
- Noob question
- Questions before I spray.
- Tire sellection for N2o??
- turbo/nitrous
- NANO Systems For Sale *Cheap*
- nitrous and a 5.3?
- How awful are the NOS wet nozzles?
- Nitrous Parts For Sale.
- Nitrous Preasure Gauge
- whats the best intake?
- Is nitrous illegal?
- microedge issues???
- How will my cam take to nitrous?
- A/F and Timing
- Painting N20 bottles
- Missing something???? PICS
- I'm keeping the 100 shot.
