View Full Version : Nitrous Oxide
  1. Routing Nitrous Feed Line
  2. Safety Disk question.
  3. Best Manifold/TB
  4. How much NOS and still be reliable?
  5. Blow Out Garage sale at Nitrous Outlet!
  6. LSX Shootout 2009 275 class?????????
  7. Mallory Hyfire 685 starting issues
  8. wet plate kit
  9. Pictures--- Cary @ Performance Inductions Intake Vs. Victor Jr.
  10. what do i need to change??? ZEX kit v6-v8
  11. i love this stuff
  12. MSD RPM window switch question
  13. Will 75 wet shot be fine!
  14. Setup?
  15. can you guys tell me if this plug looks good
  16. DD with nos?
  17. Injectors for c5 z06 150 dry shot
  18. Input on new setup
  19. fuel pressure switch
  20. So i pulled the plugs after my 2nd n20 pass
  21. Plugs died on a pass
  22. Bottle Dementions
  23. Victor Jr users inside please HELP!!!
  24. HSW Plate kit with Nano at the track video
  25. Installed dynotune dry kit
  26. Planning for this upcoming season. Need some opinions on how much to spray
  27. Using a 2 step w/ a T400 5OOO STALL.
  28. MSD Window Switch......
  29. Be careful with your injector duty cycle.
  30. Final Question About What Kit/Parts To Go With.
  31. check my setup ok for a 200shot?
  32. Problems with Microedge, a few Q's from first times experience spraying
  33. How to fool microedge?
  34. 100% Stock Ls1 .. 100 shot ?
  35. Trick performance V-Gauge. Any one have any experiance with it?
  36. Pushing the limits of stock injectors/pump?
  37. New set up
  38. can someone tell me how to wire the nitrous works pressure switch pic inside
  39. Alcohol w/ Nitrous??
  40. Is my stock pump enough for a 125 shot?
  41. Nitrous gauge Question?!!?
  42. stuck solenoid? HSW kit
  43. Another Newbie Asking Questions.
  44. F.S MSD Digital Window Switch
  45. hsw jets with nitrous outlet plate?
  46. Timing for 150 wet shot
  47. Plate System vs Nozzle System
  48. truck nitrous system on car
  49. Alright Now what?
  50. Dry Nitrous ?
  51. bottle heater
  52. Holy Crap!!!!!!!!!!
  53. microedge sensor connections
  54. Nitrous controller?
  55. dry system for c5 a4 vette
  56. Need Hints And Tips On Nitrous Install.
  57. Venom VCN-1000
  58. Do you have to purge a DRY system?
  59. 1/2" or larger head studs? Materials? O-ring?
  60. MS4 , LS6 heads , cometic gaskets
  61. I am back!!!
  62. going to be spraying a 300 in three stages need some advice
  63. Keeping the heads down on a BIG hit
  64. People with NANO Pictures *Please Enter*
  65. LT1 (wet) nozzle location??
  66. Looking for a sponsor who can wire my nitrous
  67. sprayed a 100 shot!!!
  68. HSW Nitrous Jetting Sizes... No clue which ones to pick. Need help!!!
  69. Please help with wiring!
  70. questions about spraying 400 and above set ups !
  71. Help with power ring!!
  72. Think about doing a wet kit couple questions...
  73. FJO TPS and RPM on C5 z06
  74. Hsw interface?
  75. Need help fast about TB!!
  76. Lunati Pro Mod Rods
  77. nos/head gasket question
  78. Nitrous Help!!!
  79. best complete afr kit to buy?
  80. How good/well will this Zex kit work for me???
  81. Nitrous Pressure gauge sensor location?
  82. New to N2O.. Need Line size Suggestions.
  83. FS heater & Opener
  84. is HSW dry basic kit similar to dynotune 4-6cyl dry basic kit?
  85. Big Nitrous Purge Question
  86. Ordered my HSW Plate Kit!!!!!!!!!
  87. two bottles vs. nano....
  88. timing retard on demand??
  89. classic nitrous install
  90. Anyone ever use a Top Shot? **Carb guys only**
  91. What CR would you go?
  92. No2 for medium grip car....
  93. Nitrous Outlet was at it again (Direct port Pics Inside)
  94. Safety question for nitrous
  95. Radiator Question
  96. how many spray thru shift?
  97. pls help Ls2 plate
  98. quick NOS Kit question
  99. Zex nitrous
  100. Bottle warmer decision
  101. Made a bottle bracket for the ds hump...
  102. HSW air/fuel interface question
  103. Cant find a plate kit for 08 silverado
  104. Time for new nitrous solenoids? Rebuild? Pics inside
  105. MAF Plate Kit's
  106. for you nitrous guys
  107. direct port, fogger nozzle placement
  108. HSW MicroEDGE controller mounting in 2000 Camaro SS cabin...
  109. HSW Vs Dyno Tune Nitrous kits
  110. Guys need help here with N20! PLEASE!!!
  111. Need answers to questions about dry nitrous system...
  112. brands of jets compatible with hsw and 3 to 5 wire maf queston
  113. What an awesome Christmas!
  114. window switch question nitrous newb
  115. MICROEDGE AND INTERFACE together
  116. will this work
  117. 2 stage
  118. NOS Window switch
  119. Bottle heater fuse size
  120. MS3 + N20..need help
  121. 100 shot without pulling timing on camed ls1?
  122. How much is nitrous kit worth?
  123. Nitro Dave and Crew...NITRO OUTLET
  124. Head Gaskets For NOS
  125. Summit Window Switch HELP!!!!
  126. Does the Nitrous Outlet Have any Holiday Codes??? I need some stuff! lol
  127. Anyone need a Msd rpm activated switch
  128. NANO refill Station??
  129. HSW Nitrous Holiday Hours
  130. Nitrous newb here
  131. Single or Dual Stage
  132. wanna know who builds good bottom ends
  133. NOS Sniper
  134. 383 lt1 on da bottle for 1st time
  135. one question :)
  136. Newb to nitrous, got some ??'s
  137. Setup pics of NANO
  138. People that Know nitrous in here
  139. Do open cutouts affect A/F ratio?
  140. will a LS7 clutch hold up to 150 shot
  141. plugging direct port holes
  142. free nozzle and jets
  143. HSW plate and custom smooth bellow
  144. deedeedee moment the other week... :(
  145. blow down kit question
  146. anyone running nitrous on the stock fuel pump?
  147. nitrous help
  148. Effects of Progressive Controller on solenoids?
  149. FJO writeups?
  150. TNT & mini controler ?????
  151. Boredom Build what do you think is it going to melt lol.
  152. Nitrous Outlet at it again... Dual Stage Perimeter Plate pics inside......
  153. Who is running E85 and Nitrous?
  154. how to work the full throttle
  155. Using nitrous for the first time how big of a shot for a beginner
  156. Any stock bottom end vindatcor cars w/ bottle?
  157. Must See!! Amazing Custom Products!!
  158. is it safe ?
  159. Bottle Pressure Sensor
  160. Big shot N2o engines. How fast are you NA.
  161. Need Inexpensive Progressive Controller
  162. About to purchase from HSW, need help!
  163. What else do I need?
  164. Custom painted Nitrous bottle
  165. HELP: newbie to timing retard for nitrous
  166. new to n20 and going crazy
  167. torquer v.3+100 shot =?
  168. Harris speed works please come in!!!
  169. Solenoid failures?
  170. need help soon
  171. 200 shot on stock lt1 long block?
  172. Do i need nano
  173. Bottle between the seats brackets
  174. Who has sprayed the most with stock cubes?
  175. Harris SpeedWorks Wet Kit in my 2003 Z06
  176. Thought about trying to go 10's with just bolt-ons+spray? Might run e85
  177. Microedge users, in here!
  178. 150 shot with sunoco 104 octane how much timing?
  179. where is your bottle mounted
  180. Forged stroker LS not built for nitrous
  181. New LSx Tunnel Ram Intake Hits the Market-Check this bad boy out
  182. Nano Question
  183. Need help with NOS jets
  184. 150 shot Harris Speedworks system!
  185. bout to use a 150 wet shot for the first time what should i expect
  186. window switch?
  187. props to Nitro Daves
  188. PLEASE HELP!!!! want nitrous but dont know what i need
  189. quick question... HSW and NOS plate
  190. can high mileage engines handle nitrous
  191. 2 valve help
  192. Need some help from the WET guys....
  193. My new switch panel
  194. who is building/tuning your nitrous engines?
  195. Crank and Rods??
  196. Paging 383lq4SS, can't hide no more, lol
  197. I'm Back, and You Thought You Got Ric of Me, lol
  198. what companys wet kit would you recommend?
  199. 125 wet shot ls1 questions ?
  200. Nitrous questions for a different car. (Non F-Body)
  201. nitrous outlet Brand X???
  202. DynoTune Wet kit installed in my car
  203. 200 N.O. Wet Plate what plugs?
  204. C16 and a 200 shot....TIMING?????LOOK
  205. wiring guru's!!!
  206. Using relay to send ground?
  207. What do i need to safely run nitrous on a street car?
  208. Dedicated fuel pressure reg. question
  209. Calling all stock motor people for list
  210. NAno Systems on vacation?
  211. switch panel SHOW YOURS !!!!!
  212. Need Nozzle help with my Nitro Dave Plate (Sizing information needed)
  213. FPSS Question
  214. 6 speed guys with big hits, have a question
  215. Dynotune masterblaster purge vid
  216. How warm is a bottle heater get ?
  217. NANO Poll
  218. does nitrous brand affect performance
  219. opinions on 150 wet shot...
  220. Nitrous Wiring Question
  221. 125 r.w. shot
  222. Jet placement question
  223. Which N20 Plate?
  224. Christmas sales?
  225. What RPM are you guys starting to spray at???
  226. How much nitrous you guys go thru?
  227. dont know anything but nitrous please help me decide a set-up
  228. Where can I get a new O ring for TNT's power ring
  229. Stand Alone/Nano Pics
  230. Do i need to re-tune if i get the bottle??
  231. New to Nitrous, couple of questions regarding a kit
  232. window switch with nx tps activation
  233. how to test solenoids
  234. Harris Speed Works 90mm plate kit
  235. Nano review
  236. Leaky Heater Switch
  237. Wiring question
  238. how many bottles? Size?
  239. How to: HSW Interface on a LT1
  240. Went to the track yesterday...
  241. Anyone have a part # for a non projected tip, tapered seat, NGK #9?
  242. Box full of nitrous stuff all mixed up can you help me sort it out?
  243. new to nos need help hooking up wires ASAP please !
  244. Nitrous Outlet L76 directport
  245. new best first time out on nano
  246. #7 way way lean
  247. cam+spray
  248. Window switch bypass
  249. Small Dry Shot Dyno Results!
  250. On the Super Victor Jr Direct Port N2O bandwagon
