- Nitrous Outlet Parts for sale
- FS: 43.5 lb Delphi Injectors
- Solenoid question?
- new to n2o
- Stock injestors?
- Newbie Wet Kit installed, first details inside
- Bogg right at activation????????????????????
- Nitrous and E85
- NX Piranha nozzle question
- LT1 Guys...
- Track Time Estimate
- Justin's 97 GTS Viper Nitrous Install
- Pics of my Dual Nitrous bottle setup
- Who's sprayin 200+ on stock bottoms with a direct port setup??
- Nitrous Outlet Nitrous Powered Golf Cart!
- 78 mm plate problems
- Direct Port braided lines?
- guestimates on whp ! 347+ juice
- Need help with transbrake wiring on Edelbrock 71900 controller (I searched)
- To spray or not to spray???
- Troubleshooting a possible restriction
- Nitrous and spool
- guys with big shots do you chassis dyno???
- Whats the deal with the zex kit?
- help me pick my kit!!
- timing with a 250-300 shot?
- Intake gain?
- i need help
- My dual intank pumps for LT1
- Complete nitrous kits?
- dynotune lean cut off
- ideal NX shark nozzle location in a LT1 ws6..?
- 700-800rwhp Nitrous folks: Ever run your car on the street?
- Octane Booster
- She's back!!!!
- Stock Fuel Pump?
- NitroDaves / Trick WS wiring question....
- NANO pressure
- Jet sizes for 125 shot, help
- Need some Timing Tuner help
- Nitrous Outlet PLate Kit and nos mini controller ?
- can i spray a 150shot?
- cam help
- Launcher confusion???
- Making some progress on my Nitro Dave's LT1 plate install
- fuel pressure sending unit and heat
- Nitrious plate size ?
- Nos cross plate jet size/ conversion from low fuel PSI to high
- TPS Voltage?
- Possible bad nitrous fill?
- Nitrous Gage reading yellow......
- Rods/Pistons for 200-250 shot?
- Hesitation on Shot.
- Jet Question.....PLEASE HELP!!
- How To Take Apart Bottle??
- refill station for sale
- P0300 on dry
- MSD Digital Window Switch woes....
- Full bottle pressure
- Nitrous Express LS1 MAF kit installed on
- is 3000 rpm too low to spray a 125 dry shot
- From a spark plugs point of view
- vic jr. nitrous set ups
- dual stage question
- What N20 cars at the LSX Shoot out!
- i need a conversion chart from jet size to hp
- My Dynotune Nitrous install
- Why a FPSS alone will not help!!!! FREE LEAN SHUTDOWN SWITCH!!!!
- can anyone give word for word directions for setting up the timing tuner?
- How to set up my a/f shutoff?
- Another Nitrous Install! Pics!
- Zex kit ?
- fogger a/f prob
- Nitrous with 230/226 cam?
- HELP! Huge nitrous issue...
- heads or headers with big shot
- How many people are using Nitrous with over 100,000 miles on their car?
- wet kit single nozzle N2O h/c results
- Attn, Any Moderator>>>>>>>
- nitro dave's bottle ?
- Who has the best progressive timer????
- I will be out of the office.....
- best place to buy bottle brackets that bolt to cage???
- Dry System Jetting
- Nitrous on 2002 trans am
- can i install Nitrous with my setup
- tested my system
- Nitrous Fill Station
- Congrats Pete (sprydncamd ta) on making GM High Tech
- Homemade blowdown tube
- Anyone have a blowdown tube nearby?
- VGauge Problems? Help!!!!
- HOW TO: Stand alone nitrous fuel system
- Connector on feed line broke...
- interface addes fuel when not at wot?
- Cig lighter
- what ring set to go with?????????
- How do I read the exp date on my NX bottle
- is a window switch needed with a standard?
- What is the highest MAF frequency anyone has logged?
- Is it a must for a tune??
- big ups to NitroDaves & staff
- Shop for Tuning/Installation in Ventura County, CA
- How much spray on a dry shot
- NOS Nozzle system??
- Nitrous newbie in need of guidenece.
- opinions on best NOS kit
- How many miles is too many to spray?
- Number 6 plug melted?
- How does this look?
- nitrous outlet digital dual window switch?
- Guys with plate kits, how'd you mount your WOT switch?
- xfi and zex DPK wiring
- When a Chair taps out
- nitrous wet kit f/s, full kit for cheap. need money quick for prob.
- Diagram Question
- warmer plug or more timing?
- HSW StandAlone kit, Problems Help!.
- BUILDING Another 370 Had a cam spec.out
- Need some advice on a good nitrous kit.. goal = 500whp
- Anyone have any NOSZLE funnel jets laying around?
- Thinking about spraying, need opinions
- My Custom Nitrous Bottle- What Ya Think?
- Will this suffice?
- Nitrous shop in Orlando
- deleted somethings and spraying
- LS1 Carburetor Nitrous help Needed ?
- Meth injection
- Dry Shot- What size Nozzle/jet
- Who fills their own bottles?
- what am i looking at?..
- cryO2
- N2O motor build, callies compstar or Eagle rods?
- Nitrous Outlet Summer Time Specials!
- Thankx Beer!!
- started on my nitrous setup
- Kit Choice
- NX Gemini kit surging issues. HELP!
- TR7 Gapping info
- What Dry Nozzel for small stage?
- plug gap?
- n20 question
- guys who wired their os5..
- AF lean cut off
- Bottle heater pressure switch location
- Easy timing tuner question help me out please...
- Head Studs And Main Studs.
- Wet kit timing?
- Help wire up 860 bottle heater. Relay related.
- Custom nitrous tune on pcm?
- What nitrous controllers are you guys using ?
- getting closer....
- How much power...
- N2O doesnt work anymore!!! help pls!
- 860 spare tire mount doesn't fit
- nitrous refill station
- COOLING your Nitrous Bottles
- Got a question
- Nitrous Dave's single stage window switch F/S
- Should I Buy This Kit?
- solenoids sound like a sprinkler system
- MS4 + nitrous?
- Dry Shot Questions: Mass Air Flow...
- LS1 nitrous solenoid help
- Dry to wet question
- NOS brand 05151 TPI Wet kit to LS1 setup?
- NX Propower Plate Pluss Solenoids 4 Sale
- n2o tune at TTP coming..
- First experience with Nitrous
- mandatory items for a 300+ hit or more
- Dry kit....to wet kit...help
- Who has the highest mileage nitrous motor?
- Best N20 rings
- N2O setup ??????
- After 6 months the nitrous is in! (pics and vid inside)
- New Dyno tune from N/A to nitrous?
- New window switch?
- Hit the Limiter A Couple of Times. What To Look For?
- Anyone know what caused this backfire?
- "The Perfect (Dry) Hit"
- Custom LSX NX Direct Port
- Finally finished hooking up the Nitrous
- Another Nitro Daves Nitrous Outlet thread
- Nitro Dave and Staff
- nitrous on stock motor
- Nitrous/NHRA legality help needed
- pink plugs
- What happens when the window switch fails?
- What happens when solenoids go bad/weak????
- Multi stages, when are they needed?
- direct port question?? Can anyone help
- N20 Matinence
- Post some vids, nitrous compilations
- Where can i get flat dpdt switch to fit in my ash panel
- Multi stage engine bays
- C5 nitrous numbers
- nitorus
- Help, nitrous window swithchs
- injector duty pretty high...what to do?
- dry zex help
- Lt1 Nitrous PICS!!!
- help bank 1 lean
- Nitrous Pistons/Rods Suggestions...
- Hidden Nitrous Setup?
- New best 10.23
- TR7 spark plugs
- Tr6 or Tr7 on N20
- n2o rmp window switch guestion
- Who is running the NX PRO NXL direct port system??
- I Can't leave well enough alone.
- New Best!
- my next great idea
- how much timing to pull threw hsw interface
- What type of switch for nx opener?
- 408 nitrous
- install pics, Blacked out C5
- Home Nitrous Install
- Let's talk air fuel ratio.
- How do you adjust min rpm on timing tuner?
- any tips on fixing a heater? the element?
- Have a few Nitrous goodies some of you might want!
- what to do (Nitrous) stock motor
- Should I run my STS kit or nitrous???
- need injector advice
- New NOS power relay?
- need help spray on ms4 cam
- Dyno Tune N20 Gauge/ Sending Unit ?
- mixing fuels
- low pressure single nozzle?
- Nitrous Help Needed
- Still selling my tranny!!
- Gemini Plate w/ Standalone Installation pics.
- N2O VS FI discussion
- Stock A4 + 100shot questions
- plate jetting
- Anyone running a front and/or mid plate?
- Maybe someone here can help, LS2 TB Problems on nitrous car
- a Few pics of the new install!!
- Spare tire mounting bracket
- A/f question????
- How many of you run race gas when you're going to use the nitrous?
- Timing Tuner install question
- Nitrous Daves LT1 plate, any 200 shots?
- Urgent help needed with blow-down tube
- putting together a kit...anything im missing?
- Not Gettin enought fuel with plate kit.
- Blown Head Gasket 150 wet shot
- Install pics needed.
- Nitrous Tuning with Efilive
- Spark plugs
