- NHRA legal nitrous bottle mounting location question
- TA Nostril Purges...Come On In!
- Wiring Idea help
- Need quick jetting help.
- Nitrous Install Complete
- Wiring
- Injector size for 200-250 shot???
- need a couple msd pills
- 200 Shot N20 = Same 60 as all Motor
- C-5 Purge Pic
- Do you know how to wire 2 HSW interfaces...
- Trick Performance/Nitro Dave window switch help
- burst disk
- Testing with old motor no water pushing.
- n20 v6?
- PLx wideband is gonna be off on my gauge/a/f shutoff
- Having traction issues, anyone care to step inside
- TnT F2 kit installed..
- Mounting the harness and window switch for NOS dry kit
- Who uses the interface w. a car tuned w. efi-Live?
- Pic of my Wet N2O setup
- cam only and 150 shot car needs new maf. help!
- Purge Leak... Should I take it apart?
- is anyone spraying with minor bolt ons??
- 9.37 @ 148
- Safest 100 shot for Z06, wet or dry?
- Bad O2 Sensors
- tr7 plug gap?
- what window switch with hsw interface
- OK its this true?
- Complex wiring question
- Low power - 100 shot only adds 30whp
- best cc relief for a n20 motor
- what plugs should i use
- What's needed to add a second stage?
- Is this kit any good?
- Multi function panel
- could somebody help me out here??
- my first attempt at hardlines..
- NANO and jet sizes
- Will heater hurt my paint from inside?
- My Nitrous Install!! Thanks Vengeance Racing and Nitrous Outlet
- 2 step, N20 and M6
- NGK TR6 vs. NGK BR6
- Debating on what progressive controller to use?
- pistons and N2O
- WTB Dry to wet conversion kit SPONSORS L@@K
- Nitrous Outlet = Free Nitrous System
- NANO KIT (NEW) FS $490 Shipped
- Vic Jr. Where should i put nitrous in?
- Purge is light and feathery
- rpm switch nitrous outlet wiring help
- Hook and Book.....with BMR FAB and NITROUS OUTLET!!!
- Solenoid fitting help.
- timing LT1
- thermocouple and bottle heater
- Solenoids under lid holder thing
- any reason wire a bottle heater wire would melt
- zex ls1 kit
- How do you like my install?
- Using A Window Switch And Hpt For Wet\dry\ Or Direct Tuneing
- 110hp from 200 shot
- Knock in 3rd
- Best way to spray a 200 shot
- the good, the bad or the ugly?
- Wet Shot necessities
- n20
- NX Wet Kit Question
- Where does everyone mount their Nitrous Gauge?
- Timing Tuner question
- Where to mount nitrous gauge sender?
- kewal guide for jetting and results
- Ponch does 10's and conquers Sealy (125 dry shot)
- propane mixed with Nitrous
- How to test kit while parked?
- Paging ChopStix or any other wiring guru
- Timing tuner and WS hook up..
- 57/31 now what fuel jet to run for 150?
- Can I wire a opener with the normal swich on a ashtray panel?
- Nitrous Stutter??? Please Read
- Do I need a dyno tune...
- Going to the track this weekend; advice appreciated
- Where to buy NX shark nozzle JET KITS?
- Wideband accuracy on only 1 bank
- tech question
- Best bang for the buck nitrous kit?
- Attn TnT users: Power ring fitment concerns?
- anyone know the stories behind these?
- Thumbs up for HSW....great product...
- Nitrous miss?
- NX Gemini Plate w/ standalone...... good for both low and high pressure fuel?
- Show me your Noids
- how many people spray through their 4l60e?
- About to gap my rings. Look good?
- 860 spare tire mount guys come in
- nitrous express kit
- Motor Flooded to Hell
- Had My First Nitrous Bang
- Anyone Running Nano With Zex Kit?
- nitrous outlet warmer new . 150 obo
- Timing correct 19-23* @ wot 150wet + cam?
- Warming bottle w/o heater
- Has anyone had any luck with the l76 l92 plastic intakes for direct port
- Leaking bad
- Not sure if my nitrous worked
- Free Shiping On HEX TO WING Adapters.
- HSW interface install question
- Spraying An LS3 Based 427
- C-5 Bottle/NANO Photo's (updated for May08)
- 15# bottle hidden in the spare?
- HSW Dry Plate Kit - 07 C6 A6
- Getting a instant hit off the line
- Help with nitrous tune (timing)...
- Where to get proper wrenches for fittings
- How much nitrous am i using?
- dynotune nitrous pressure gauge?
- 383 on a 200-250 shot?
- Check list before I spray
- Has anyone ever tried Dyno Tune Nitrous?
- What's the labor on something like this? (direct port)
- Pics of the set up .....
- jet sizes
- What to use for nitrous bottle nut washer
- Need help with dry nozzle placement?
- How to Extend the Capacity of Injectors for Dry Hits
- Spraying 150- only getting 90
- timing tuner question
- whats it going to take to go 8s
- Nitrous shooting through purge non stop HELP!
- ? about speed density tune and dry nitrous
- bottle question
- Do you leave bottle in the car all the time?
- a couple dumb questions
- My nitrous install (pics inside)
- Installed new switch.
- Thank You Beer99C5
- Nitrous Pressure Question???
- Spark plug wires cause misfire:safe to spray?
- Nitrous Plate Bellows Problem LS1
- Safe shot
- New 2 Nitrous
- fogger mounting question
- Cold Filling Nitrous bottles
- Gauge won't stay powered when car on
- Want to spray my LE2 Bird...
- Cam question
- Help with solenoid location..
- Best setup
- Nitrous Life Question
- This might be a noob qustion
- Show your Purge location!
- nitrous outlet bottle warmer 150$
- will this hurt my engine
- Need Advice
- I have a NX Wet Direct Port. How BIG a shot should I run?
- what timing for stock ls1 lt's and 125 shot
- Need some help...
- 02 LS1 with MS3. What Nitrous setup?
- (2) 10lb nitrous bottles for sale
- what size line for tnt kit
- Need a particular bracket.. where to find??
- set up
- Toggle Power Source
- What to use instead of Teflon Tape??
- NANO Group Purchase
- need misc msd window sw pill
- Pics needed for outlet of dual windshiel purge
- Dangerous to run line inside?
- New to Nitrous, little help..
- n20 safe with my cam?
- Please help newbie wants to run nitrous!!!
- Wideband+Vgauge Help!!!
- got a preasure guage need help
- Get me into the 8s
- Dynotune Winners!
- paging a wiring guru
- any sponsors sell compucar products
- Need Advice On My Gauge Setup!
- Line leangth from noids to plate F16" N24"???
- wet and dry together????
- Oxygenated Racing Fuels & nitrous
- NIB Nitrous Outlet Big Show Purge Kit
- nitrous line routing from spare tire area
- nitrous jet placement
- Quick questions here.
- need help
- Can I shorten this nitrous line?
- Using Cold Gas??
- rpms reading way off! related to msd timing controller, digital switch
- Quick bottle pressure question
- What Plugs do i need for n20?
- Nos 5168 wet kit
- video of the TTT5 car we have (true street)
- What is wrong. going lean.and wide band blanking out
- Nitrous Outlet Direct Port
- My Custom Purge
- Jon's Gettin on the JUICE! (Nitrous Install)
- Sprayed for the first time!!!!
- My stealthy setup
- Should I use a timing tuner or timing twister w/ my setup?
- where can i get this switch panel??
- NXL vs NOSzle
- Need wot switch + controller's tps switch?
- What to gap tr-6s, torquer v3 + 150 wet
- 2 stage set ups POST UP PICS
- Nitro Dave's Plate Kit Installed
- C-5 Nitrous fuse center
- Need help with nitrous plate.
- Wire Selection Chart
- Need to Settle This
- PIcked up a NOS GM EFI Nitrous System LS1 Nitrous System need hints for installing
- Wilson Billet Bank / Nitrous Outlet DP Pics!
- N2o Compression Limit?
- Dyno tune Nitrous Kit
- Any sponsors working with E-85?
- MSD digital window switch *for sale*
- Nano/pusher Jetting ?
- Hide bottle or not?
- plug swap now rough running
- Never heard of this.......
- Is a trailblazer SS window switch the same as an ls1 fbody?
- Dyno Numbers with 100 Shot (TFS 215's, Vindicator, 90/90, A4)
- What AFR to shoot for on 100 shot Stock Bottom End
- is -15cc piston to much for spray. for a 408
- LED wiring for 2stage setup
- what gear for 3a and spray
- Please assure me this won't blow up.
- Show me your DP and Stand Alone Systems
- Shout out to Nitro Dave's
- Track Numbers?
- Nitrous Outlet LT1 Plate System
- Which wire to use???
- H/C+150shot+10bolt on dyno=?
- Dummy Proof N20 Setup???
- Freezing Bottle
- Fuel system upgrade???
- Anyone running a NOS progressive controller on a 416 CI L92?
- what converter?
- Suggestions / comments wanted.
- P0103 MAF High Input
- Pics of my car with new wheelie bars etc.
- A/F ratio question
- Cutout Versus Headers
- No power gain with spray
- Vig 3600 and spray...
- Check out this stealthy setup !
- Nitrous Guys Please help need advise !!
- IAT Mod Reliability
- New setup almost done.
- What to Expect
