View Full Version : Nitrous Oxide
  1. nitrous wiring issues!
  2. what should i buy?
  3. Removing Bottle Valve
  4. A Few Nitrous Questions
  5. What pistons?
  6. How much gain ?
  7. Bottle pressure 800 vs 900psi
  8. Nitrous system for sale
  9. Brand x from nitrous outlet
  10. Question about the sticky..
  11. TNT 100Shot at 900 psi hits SOFT
  12. NOS Super High Flow Valve gauge port size
  13. Zex LS1 Wet Kit
  14. N/A power loss from timing loss?
  15. Nitrous maintain ?
  16. So, nitrous bottle in frezzer...
  17. LT1 plate. Which one??
  18. ARC 120v Bottle heaters
  19. gainesville raceway wednesday, quick help please
  20. 10lb bottle in spare tire area
  21. Help with picking nitrous stuff please...
  22. Progressive controller
  23. timing ???
  24. Maintaining bottle pressure?
  25. plug and gap for a 200-250?
  26. help with dynotune ws
  27. will my nitrous guage being broke affect my heater?
  28. Serious Nitrous Junkies....What cause pinging when sprayed ?
  29. Anyone have a 12' or 14' 4AN mainline for sale???
  30. main nitrous line question
  31. 383-402-408/N2O times
  32. Anyone looking for a Nitrous set up, look no further!!!!
  33. How's this for a reliable street setup?
  34. New #'s thanks HSW
  35. What are the best spark plugs fro running nitrous?
  36. Need TNT nitrous Jets.
  37. best wot/tps/window switch?
  38. Aux. Fuel systems for N20?
  39. Bottle Pressure Safety Switch Problems
  40. Bottle Pressure
  41. Running Rich On N20
  42. Proper Jetting
  43. LT1 nitrous set up question
  44. Dynotune LCS question
  45. Spraying a 383 LT1 with N/A ring gap...how big a shot?
  46. Can't find my bag of jets... help?
  47. Ls1 nitrous kit going on Ford lightning?
  48. Nitrous Question on 408.
  49. Best way for a T56 trans
  50. nitrous rwhp question
  51. Can u see your gasket on a FAST 90??
  52. Does anyone make a Black 15lb bottle? and size?
  53. Interchangeable jets?
  54. Trick/N.O. Window Switch wires for 03 Z06
  55. NOS/ PORTED LS1 heads.... WHAT CAM???
  56. wiring question
  57. 753.3 Ftlb Tq & 607.3 Rwhp
  58. Nx Wet Kit Plate Setup?
  59. Suggestions
  60. NOS 1568 wte kit
  61. Harris dry plate kit
  62. What do you guys think
  63. fuel system mods to support 600rwhp
  64. LT-1 Plate conversion
  65. Zex bottle heater
  66. How accurate are electric nitrous pressure gauges?
  67. Timing Tuner Q's...
  68. Nitrous on an LT1
  69. will this work.
  70. Great experience with Nitro Dave's
  71. When is Methenol needed?
  72. What causes head lifting with n20?
  73. What injectors??? and fuel system?
  74. carbon fiber bottle and billet bracket
  75. I joined the ranks of head lifting
  76. Pics Of My Nx Install
  77. Looking for new nitrous plate
  78. Peep This Yo.....
  79. timing twister guys come in!
  80. Need help figuring Volumetric Flow of my system (fuel).
  81. NANO, stupid question
  82. FJO 2 Stage TPS and RPM window switch...
  83. Nitrous FPSS Question
  84. Pump Question
  85. *Need dry nitrous tuning help*
  86. gasket question
  87. What plugs for 75-100 shot?
  88. Help me figure out what bottle heater I have.
  89. Question: Big shots (200+)
  90. Wideband opinions
  91. Nitrous Works 120shot on car when I bought it.
  92. Need just one RPM pill for window switch, anyone have one?
  93. couple wiring questions
  94. How big of shot can a sbc and bbc take??
  95. good deal?
  96. Nitrous Dave!
  97. Need help with N2O numbers...
  98. need advice...just installed headers
  99. Bottle mounting/blow down tube?
  100. TA Bumber support from Burkhart Chassis
  101. denso iridium it22
  102. Jet question?
  103. NX Direct Port Setup F/S
  104. Nitrous/Meth combo
  105. Some Grounding Questions and Mounting Qs
  106. 100 shot pill sizes.....
  107. Did I forget anything?
  108. Follow along with an engine build @ Weber Racing Engines!!
  109. Why cant i get n20?!
  110. nitrous hits slow??
  111. Sticky with N2o set-up pics.
  112. timing tunner issues?
  113. Nitrous/Propane Injection.
  114. Thinking about buying this car, but need opinions from n20 people!
  115. Speed Inc Install
  116. Nitrous Gains
  117. fuel rail valve
  118. 600 Rwhp
  119. Almost Pulled A Robert
  120. problems with nitro dave WOT switch bracket and install pics
  121. Pics of the Nitrous install a question
  122. Are edelbrock systems good?
  123. nx bottle opener question
  124. IQ OR IT denso plugs?
  125. Nitrous timing retard question
  126. How reliable are nitrous cars?
  127. Got my kit installed!!
  128. Need info: Fuel noid is sticking.
  129. Nitrous Help, Dash Removal
  130. My nitrous application
  131. help with nitrous and th400
  132. Rusty Lines?
  133. nitrous tune?
  134. Colder plugs
  135. 2 STAGES and more on LS1 through LSX
  136. How much, all aluminum LS2
  137. Anyone else have trouble with their 860 spare tire mount?
  138. nitrous damage question?
  139. nozzle in throttle body
  140. Cant decide wet or dry for LT1
  141. Anyone running zex direct port on fast intake with fairly high boost 15 psi or so?
  142. Mallory 685 Ign box?
  143. Anyone running Autolite AR 94's on the street?
  144. Nitrous plate idea...
  145. 100 shot to 125 shot.. Major difference.
  146. Single stage window switch
  147. LS7 Max Nitrous Capabilities?
  148. A/F lean cut off switch question
  149. nitrous question
  150. Fuel pump
  151. Ls1 timing tuner help
  152. Tested out the nx 2 stage had a question on the hit how hard should you feel it
  153. Arming switch
  154. nitrous hookup up..along with homemade tunnel mount
  155. Gains with NANO?
  156. purge switch
  157. How much does a shorter fuel line help a lean spike?
  158. Fuel pressure safety switch question
  159. How To Pull Timing?
  160. What converter for a4 and n20?
  161. 402/NOS 90mm plate with a lean spike...
  162. Starting nitrous install today & need help ASAP
  163. Have a weird problem...
  164. anyone use the NX window switch?
  165. Pics of Sol.mounting
  166. Anything else?
  167. Some thoughts on nitrous on my vert
  168. harris speed works
  169. Need a Nitrous diagram
  170. Realistic gain on a 150 NX shot?
  171. Mounting TNT F2 in a Vert
  172. NX DP and TNT Nitrous Kit Pictures
  173. directions for timing tuner
  174. Help me build what i need!
  175. 90mm Nitrous Plate Kit ?
  176. custom painted nitrous bottle
  177. 2 questions. timing and bottle pressure
  178. Bottle Brackets and Feed line for sale
  179. Ms3 And N20 Step In
  180. nitrous = less power?
  181. length of nitrous lines
  182. 150 shot in front of throttle body ok?
  183. Those of you with Fast 9090 and Plate kit Come inside!
  184. Nitrous Help!!!
  185. Heads and Cam, spray ok?
  186. AIS Fender/Firewall Mount Water Methanol Injection Special - See Post For Detail
  187. Finishing the N2o set up
  188. pic request nx express direct port
  189. What's the formula for determining nitrous volume used per sec?
  190. Time to show off!
  191. Questions on the NXL kit.
  192. 408 L92 / L76 Nitrous combo
  193. All Nitrous Express Products on sale.
  194. hsw interface tuning help
  195. Car went bad lean on dry shot???
  196. Nitrous bottle heater
  197. Pics of Nitrous Install
  198. Ground?
  199. need help with zex dry kit!
  200. Need opinions from you guys on this....
  201. need advice
  202. LS1 78mm Blemish plate special.
  203. Nitrous Outlet Plate Special..
  204. Nitrous kit w/ 15lb bottle For Sale
  205. Anyone runinng a Burkhart Dual BottleBracket?
  206. tuner
  207. Nitrous Tuner
  208. help build a good but on a tight budget dry kit
  209. FREE DYNOTUNE Digital A/F Lean Shutdown Switch and Innovate Wideband!!!!
  210. Street Tune Vs. Track Tune
  211. msd twister or timing tuner?
  212. What else do need to cplete my kit?
  213. Do not spray a 150 shot without colder plugs and a tune, pics inside!
  214. Where to buy lt1 plate
  215. Interface or progressive controller
  216. And the winner is ......
  217. UGGG. Spun bearing = forged bottom end, which components for 200 shot
  218. Fuel system for 300+ shot?
  219. bottle heater problems
  220. nos plate is horrible for noid locations. suggestions?
  221. Where to find this nitrous hose?
  222. What's it worth, (used parts from a co-worker)
  223. A few questions before the track opens
  224. Figured I would share ....
  225. HSW kit on my 1993 rx7!
  226. Zex kit and HP
  227. Direct port on lt1????
  228. MPH Gain on nitrous
  229. lsx or ltx to build for nitrous....
  230. Urgent Help ?
  231. Trick performance window switch and zex
  232. Nitro Dave 92mm plate?
  233. Can a nitrous kit for a carb be used in fuel injected car?
  234. 125 shot dyno results
  235. 98 z, lookin to spray.
  236. fuel leak?
  237. my first try at installing nitrous
  238. is this motor good for nitrous?
  239. Selling HSW A/F interface- brand new
  240. 150 DRY shot torque numbers
  241. Looking for a fitting to connect gaues to fuel rail and bottle
  242. Those with nano.........how does it work??
  243. nitrous mainline
  244. How Do I mount the Microswitch for TNT kit!!???
  245. Dynotune Nitrous gauge problem
  246. Anyone wanna draw me up a wiring diagram?
  247. dynotune lean switch
  248. Full Throttle Speed???
  249. Which Plug on N20
  250. Braided blow down tube
