View Full Version : Nitrous Oxide
  1. Nitrous Safety from Dynotune at $99!!!!!! IN STOCK!!!!!
  2. Nitrous 383 shortblock
  3. Nitrous Outlet Christmas Specials
  4. L92 HEADS vs OTHER 6.0 HEADS
  5. What size injector??
  6. Best cam out there for a 408 300 shot
  7. window swith-progressive controller!
  8. nitrous parts.....list needed!
  9. nx jets diff. than nos??
  10. 100 shot
  11. n20 cam
  12. Wideband Help
  13. Got the Nitrous Trophy-Dyno Shootout
  14. main feed line
  15. money maker on typhoon?
  16. Engine Trouble, Help Please!!
  17. Complete Nitrous plate system for sale. Used once on dyno
  18. Stupid question (hidden nitrous)
  19. This might be a stupid question.........
  20. Introducing 860 Performance Products
  21. Trying to setup for big numbers low ets have ???
  22. Introducing Brand X Nitrous Systems
  23. direct port users inside please
  24. Paging Robert56
  25. Dirtect Port-Plastic lines
  26. does colder plugs take away a couple horses for nitrous
  27. Nitrous is flooding my car!!!!
  28. How much can stock Lt1 handle?
  29. throttle body plate required to spray a wet shot on an LS1?
  30. NX Stage 6 plate...
  31. fuel rail test port question
  32. dry to wet
  33. Discussion is nitrous for me?
  34. How much can i handle?
  35. Will It Take It?
  36. Solid Roller with Nitrous?
  37. FPSS/window switch
  38. New NOS controller
  39. Nitrous and Cam?
  40. HSW kit questions
  41. Dry tuning
  42. what gears with nitrous
  43. for those who spray and have a catch can
  44. E85 and nitrous?
  45. safe to spray?
  46. Happy Thanksgiving!!!
  47. Fuel solenoid question.
  48. I need help selecting Nitrous Kit
  49. Pain's new dual stage setup (pics)
  50. help a n2o noob out
  51. tnt f1 wiring instructions
  52. Am I blowing through the converter or does this dyno look normal?
  53. Possible Nitrous Leak?
  54. venom nitrous bottle
  55. Noob with a 402 to spray
  56. n.o.s. mini controller please help!!!!!
  57. 10.46@139.59 First time out......
  58. and the 10 o'clock post whore award goes to Nitro Dave's Nitrous Outlet!
  59. who makes a dual stage plate for an ls6 intake?
  60. pulling timing
  61. N/A Tune w/ spray?
  62. does anyone agree with me?????
  63. AFR goes crazy..Any ideas?
  64. little rough idle in gear. now backfire with tr6's
  65. Need advice please, trouble @ the track.
  66. Another fuel pump question
  67. 10.92@122.53 NA vs. 10.00@133.9 N20
  68. Robert or any Mod - Wiring Sticky needs attention
  69. FS: Nitrous Outlet Dual Stage Direct Port 90mm FAST intake
  70. bottle fill woes
  71. dry to wet?
  72. audible noise from bottom end of nitrous motor
  73. Nano ROCKS - 9.1 @150- x2
  74. Need help with Dynotune Bottle Warmer
  75. A little closer but no 8 second pass ...
  76. Looking for pics of the Red T/A with a plate kit.
  77. How much can I spray in a 255 hLP Pump?
  78. noob w/a surge problem
  79. Dry:can I?
  80. New 60 ft video...
  81. Post your stories/results from Detonating/Pre-Igniting on a big shot!
  82. IAT mod to pull timing? what ohm resistor does what?
  83. Question about a 300 shot on forged bottom end??
  84. How Much
  85. Nitrous Backfire I Need Help Figuring Out Why???
  86. help with wiring
  87. nitrous vs stock stall
  88. Factory Radio switches used for nitrous???
  89. CheaTR and 150 Wet
  90. Ring gap for 300 NAWS
  91. taking timing out for big shots
  92. nice nitrous kit f/s with all the goodies
  93. 402 questions??
  94. What do you think I will run?
  95. NGK B8EFS-non resistor plug question
  96. LSx to LTx kit
  97. Ngk Tr-6s
  98. Normal For Car to Backfire after Spray?
  99. 9.08 @ 148.... 3700lbs! ... Video.
  100. lets see pics of mistakes you made with N20
  101. How Many People Spray Their Daily Drivers?
  102. New Gauge/Panel Setup
  103. Pump Gas or RACE Gas???
  104. How hard is it to change a bottle valve.. ?
  105. My Freezer...
  106. qustion about my nitrous
  107. checked the fact, this wasn't in there
  108. What will it take to go 10's?
  109. does this sound right?
  110. A/F ratio (Colorado)
  111. Another new best Thanks to Kooks 2" race headers!!...and another broken oil pan
  112. nitrous guage question
  113. Recommendations for noids (300hp and up)
  114. Should I change to a Direct Port Fogger??
  115. Is Something Wrong With My Car?
  116. checking a wet kit
  117. Robert Inquiring Minds want to know?
  118. RaceTested nitrous bottle/valve
  119. cleaning nitrious out
  120. Hard start?
  121. Any thoughts on a dedicated fuel system?
  122. nos single dry kit nozzle pill
  123. Nitrous with BAP ?
  124. help with installation
  125. homemade backseat mount??
  126. TNT - Cant get it to lean out
  127. Zex Direct Port & Fast Intake
  128. Nitrous likes compression...
  129. does anyone get their bottle inspected periodically?
  130. spark knock
  131. Scratch, Dent and Used Sale!!
  132. Sorry Guys, im leaving the NITROUS world!
  133. 8 second nitrous guys
  134. purge smoke effect question
  135. 150hp jets = 80rwhp?
  136. Recommended Dual Stage Shots
  137. 125 dry shot
  138. spraying thru the throttle body
  139. TR55's or TR6's; C6 cam only + 100shot
  140. Does anyone have this combination???????
  141. Entire set up, price
  142. LS1 Ignition Timing and Nitrous Controller
  143. nitrous wiring question
  144. Is my converter killing my 150 shot?
  145. How much will it take?
  146. tapping for RPM/Tach input with a DT window switch. Need WS HELP
  147. Help Quick Please, BMN Wiring...
  148. ? For C6 Guys
  149. PLUGS.. TR6.. Rusted looking color on em.
  150. Changed nozzle position on dry kit
  151. Single-Plane MPFI Plate System
  152. mahle pistons,scat rods,how much nitrous will it hold
  153. Need Wiring diagram.....
  154. HSW plate?
  155. Got Traction?
  156. how big of a shot??
  157. Basic N20 Question
  158. Is there a ring kit for typhoon intake?
  159. Dyno Graph - ?????
  160. Gear lockout options
  161. Nitrous Newbie!
  162. Introducing the NOS Launcher
  163. legit dry shot questions
  164. Ngk Tr6
  165. Eastside doing some testing this weekend (pics)
  166. Flowing fuel pressures???????
  167. Timing Tuner and a few nitrous gadgets
  168. Why are Nitrous Stalls different?
  169. Wet OR Dry???
  170. Anyone out there have a custom bottle bracket?
  171. Wiring Diagrams
  172. new to the LS1 & NOS
  173. Can you spray a 100 shot off idle?
  174. Testing Solenoids
  175. 175 Rwhp Shot + 346
  176. 402 (ls2), 427 (ls3), Or 408 And Big Shot
  177. nitro dave's window switch
  178. mounting screws.
  179. Timing Tuner ?
  180. fastest roll to spray
  181. Ring Gap for 150-200 shot
  182. Steering wheel buttons
  183. Anyone run a dynotune FP gauge??
  184. Need some adviceBottle location Z06? wet kit swap
  185. Best cam for NOS?(HELP)
  186. PICS!!C6 Dedicated fuel system!
  187. 2008 Zo-6 N2o Install Pics!!!!!
  188. FPSS after the fuel noid?
  189. how much can i spray
  190. calibrating the FPSS
  191. New best ... about time!
  192. some videos from Denton, on and off the bars
  193. 10.935 @ 124.09 ona stock lt short block/heads
  194. Melted plug...
  195. Stock timing be ok with a 100 shot?
  196. What's the result of a 300 shot w/ TR6's & 26 degrees timing? What about a 200 shot?
  197. vid of my setup on the dyno, dual nozzles in mti clear lid
  198. Nitrous Laws (NY State)
  199. H/C stock fuel system, do i need a Fuel pump, for a 150shot?
  200. Finally, 8.94 @ 150 mph.......
  201. Links to kit and other accessories.
  202. Disadvantage of the hump
  203. Texas nitrous laws
  204. When To Spray An M6?
  205. typhon intake n20 install question
  206. Blew the stang up on spray
  207. Window switch headaches
  208. NX carbonfiber nitrous sil. problem
  209. resistor timing question??
  210. HSW Plate Install!
  211. FJO window/WOT switch?
  212. LT1 needs some spray
  213. Lets see your Wet kit installs
  214. 427ci w/100 shot vs. 346ci w/200 shot
  215. Does anyone have a TNT power-ring install on....
  216. Looking to trade a..........
  217. Nitrous Questions
  218. Nitrous Line??
  219. 75 to 125 shot dry ?
  220. 50 Shot thru a Zex Wet Kit
  221. How much should I pay for Nitrous install?
  222. 04 GTO will stock fuel system hold up.
  223. Nitrous check list...do I have everything?
  224. Made a few passes with my new setup!
  225. scared to spray
  226. Launching on n2o w/ a M6
  227. What Do I Need To Spray 175 - 200 Shot With Stock Short Block
  228. Nitrous Kit - Direct Port
  229. 'Noid mounting pics
  230. purge pictures please
  231. Is this true about my nozzles
  232. Spooky Deals- Today Only
  233. Composite or Aluminum Intake for the big shot?
  234. Does Nitrous Smell?
  235. Do you need to take off the Cats?
  236. Other brands jets ???
  237. would this be something to worry about
  238. Best Nitrous/Fuel Solenoids for 250 Shot
  239. is there anything that you need to replace when getting nitrous
  240. question about nitrous nozzle thread.
  241. How much is a nozzle Capeable of??
  242. Anyone need a LS1 timing tuner?
  243. Need input on a setup!
  244. ok to spray with 70k?
  245. Black Series Display Controllers INSTOCK!
  246. A couple of N20 Passes from the LSX Shootout
  247. new to nitrious what do i need?
  248. Harley Nitrous Install..
  249. Anyone have Nitrous Outlet LT1 plate set-up ?
  250. nitrogen push fittings..i searched!
