View Full Version : Nitrous Oxide
  1. nitrogen push fittings..i searched!
  2. Dual Stage dry kit
  3. msd digtal window switch question
  4. nitrous cost/install shops
  5. dual stage, Can my motor take it?? need opinions
  6. Everyone read this!!!!! Get your calender!!!!
  7. whats my ZEX kit worth?
  8. 2 Stage Kit
  9. which wideband?
  10. Digital window switch...
  11. upgrading my system to dual stage?
  12. Nano!!!
  13. N/A -v- Nitrous Tune
  14. msd rpm module
  15. I have my Mod Postion Back
  16. how good would this be for dd car
  17. Nitrous GTO in the 11's!
  18. Plate kit installed now cruise cable issues
  19. what setup is this?
  20. safe shot with cam??
  21. Nitrous Fuel pump
  22. will TNT and Volant work
  23. What RPM to let off?
  24. Wheres Charlie been?
  25. 00 trans am window switch
  26. NOS Heater install
  27. Super Hi Flow Nitrous Valve question
  28. TPS signal
  29. car acted funny after being sparyed
  30. Tach signal?
  31. wot
  32. NITROUS BACKFIRE *help*
  33. what hp
  34. I think I got a crappy fill.....
  35. (Wet Kit) HSW vs. Nitro Dave's
  36. loosing coolant when spraying?
  37. Upgrading, what nozzle for a 200 shot
  38. Anybody need some bottle heaters?
  39. Suggestions/Advice Needed--- Single 300 Plate + 100 second stage
  40. who needs nitrous?
  41. would this be a good cam for spray ?
  42. 75to125 dryshot is motor going to be ok
  43. Nos Experts Advice Needed!
  44. Thanks Chris @ Nitro Daves
  45. Dynotune lean shut-down switch
  46. dry kit nozzle on lid???
  47. Straight Oxygen vs. Nitrous Oxide
  48. 300 Shot?
  49. 125 shot on stock crank
  50. wierd stuff in motor happening need help
  51. Dual bracket??
  52. Is there such thing as bad nitrous...?
  53. ngk-tr6
  54. Dynotune Support is SECOND TO NONE. THANKS AGAIN
  55. tnt install pics
  56. Noids
  57. N20 With Torquer V.2?
  58. 110lsa n2o?
  59. Fuel Additives and the Gas
  60. Valve spings and nitrous.....
  61. Dynotune Progressive Controller Users Inside Please
  62. Aluminum Tubing for purge outlets vs stainless.
  63. Completing wiring ... need two things ... please help if you can.
  64. Cam and Spray
  65. nitrous fittings
  66. deactivate nitrous when 2 step is armed?
  67. Harlan 2-step/tbrake/nitrous help needed!
  68. is it ok to do this
  69. Halo install!?
  70. Head Choice for Spraying Bigger Hits
  71. What was your gains with a 75 shot?
  72. Injector question with nozzles
  73. Jacobs ignition box and nitrous mastermind.. on a LT1??
  74. min. what oct. for 200hit?
  75. New nitrous record back at East Side Performance!
  76. window switch setting?
  77. stumbles when nitrous engaged
  78. how much you pick up on single dry kit 100 shot?
  79. Running a BMN Window switch???
  80. Common Ground for Switches & Daisy Chaining Switched Source.
  81. hot lapping?
  82. air/fuel gauge dilemma
  83. Races the 26th! Help me figure this out!
  84. how quick should i be w/my new set up?
  85. Window switch mounting
  86. jst size???
  87. hooking up nos dry kit
  88. Help with fuel trim issue.
  89. bottle mounting question
  90. how would a NX tune affect my DD or off bottle performance?
  91. Fastest nitrous times with a 4L60E?
  92. is 94 oct better to use then 93 oct gas?
  93. head gaskets?
  94. What happens if Window Sw goes bad?
  95. Custom Nitrous & Fuel lines
  96. My 408 motor is forsale
  97. Nitrous Price
  98. What kit should i get
  99. Need some help - 100shot = 30rwhp?
  100. Nitrous Mastermind, Worth it?
  101. What will this do
  102. head stud Question????
  103. Just got nitrous system need help.
  104. How much can I handle?
  105. Timing tuner Question????
  106. Show Your Nitrous Installs!
  107. track results 150 shot, right combination?
  108. do i have the right wire...tach signal
  109. LMR LS7 Project Dyno Numbers!
  110. Best place to order Innovate DB gauge
  111. do i need a window switch?
  112. 2 step wiring help please!!!!!!!!!!
  113. Help pick my converter
  114. Havent sprayed in 6-8 months ??
  115. Is there a way to toggle between maps?
  116. Ever have a bad window switch??? Dynotune
  117. bottle quantity?
  118. Green plugs and SES after spraying....
  119. engine rev when purging?
  120. Bottle PRESSURE.... What factors play in
  121. Customer Service update/ Console switch panel
  122. got a ? bout nx one pc maf kit?
  123. 375rwhp + 100 dry kit, possible w/stock injectors?
  124. question
  125. cts-v recomendations
  126. New N20 GTO times
  127. Looking to replace my LS1
  128. Nitrous Tune ??
  129. New best 60' with new head design.
  130. What would happen if...
  131. Dry kit modifications and questions
  132. Backfires!
  133. How much and who can repair a progressive controller?
  134. who sells this kind of direct port set up...
  135. Anyone with a big cam + 150 shot on stock bottom?
  136. pictures please
  137. Wet kit lovers
  138. what are the nitrous jets size for a LS1
  139. Plug problem
  140. 200 shot stock bottom end, out of the hole
  141. Sprayed with no jet in the Fogger
  142. Numbers on the kit for h/c/i z06
  143. My nitrous setup
  144. 125 Dry Shot Track Results
  145. Nitrous Record Broken!
  146. Anyone have experience w/ Dyno Tune N20 kits?
  147. nitours loves compression
  148. Fuel injectors...GM White ones?
  149. bottle KNOB, How far to open it????
  150. Harris speed works still a sponser?
  151. N2o cutting out ?
  152. nitrous switch panel needed to fit cubby hole...
  153. Nitrous Newbie...
  154. need a good writeup about nitro kits
  155. Maximizer II data log output
  156. need a jet!!
  157. Who just watched that
  158. direct port jet Question
  159. 250 shot on modded 5.3L?
  160. Solenoid Mounting Help
  161. Nos/Holley are Fn liars!!
  162. Blowing nitrous through lt-1 maf?
  163. nitrous expenses
  164. Stand Alone qustion
  165. NX noids
  166. Head cracked again
  167. Can you mount your bottle under the hood?
  168. window switch under the hood
  169. mach1 nitrous install questions
  170. Heat it up!!!!
  171. backfire pics
  172. MTFO, Black Car Owns the dyno!
  173. Attn Ricky Stansick, Gerald, Nitrous Outlet gurus and all other FJO Wiring Experts:
  174. 1st step of 2 step on, nitous off, launch, nitrous on?
  175. who makes a good dry kit?
  176. need a general opinion on a set-up...
  177. Auto Tech says "Never have nozzle before maf...
  178. Made some baseline dyno runs
  179. Gym bag over bottle
  180. HSW give us some info!!
  181. Supercharger + Nitrous Advice
  182. 150 wet with Racetronix FP and SVO's
  183. Spray or no?
  184. 200 hit
  185. NX Maximizer 2 is worth every penny!
  186. Dynotune.. Omfg... Woohoo!!!!
  187. Any pics of 2 bottles mounted in a f-body?
  188. Im Back!!!
  189. direct port pics? (revisited)
  190. Installing a NX LT1, LS1 Pro Piranha Kit
  191. Link to Fuel Pressure Gauge If Interested in One.
  192. DynoTune Comments
  193. cts-v guys
  194. pics of install
  195. What's Your Experience with nitrous?
  196. can a NX 1pc maf work with there new fly by wire instead of the WOT?
  197. POST PICS OF custom painted bottles !!!
  198. how do i mount this TNT purge solenoid?????
  199. need wiring diagram
  200. Finally got on the dyno!
  201. need some help!!!
  202. problems with the engine compression .
  203. better option?
  204. Any suggestions..
  205. N20 filter, pressure sender, and heater trans location
  206. I want to run a 2 step, can I?
  207. help me with a kit.
  208. ls7 nitrous help
  209. Spray in 5th gear good or bad?
  210. #13655 NOS Nozzle flow?
  211. Spraying a mach1
  212. Bigger injectors for nitro?
  213. timing for 150 shot
  214. is taking fuel from the rail a good idea??
  215. HCI 03 z06 + how much shot
  216. Dynoed today. 427hp, 600ftlbs torque
  217. (I searched) Aggervated, lean on 50 dry shot!!???
  218. NX system
  219. before i make my payment, what comlete kit do you recomend?
  220. New pics of ARE Dry sump and NX Gemini Twin Plate system
  221. Pic of installation
  222. Possible to pull timing via resistor?
  223. How long can you run N2O, continuously?
  224. looking for good switch panel,
  225. How do I connect a Bottle heater sensor and gauge to one port???? Dynotune
  226. NEED nitrous question answered
  227. Dyno graph and nitrous...
  228. Stock v6 plus NOS
  229. How much can I spray
  230. keep cats with n20 or get ride of em?
  231. How bad would it be to...
  232. Pics of recent Wet Kit Backfire
  233. Carb intake direct port pics needed!!
  234. Got one last question on my setup.....
  235. nitrous backfire down the track?
  236. Dry Nozzle installation.. WHAT SIDE!! LS1
  237. Starting points
  238. is it save for me to use 150 shot?
  239. Msd Rpm Window Switch, Pill Style. Anyone Need It For Cheap?
  240. random question
  241. Will 1050psi + 150 Shot Be Fine On Totally Stock C5?
  242. videos of nitrous cars before/after
  243. Nitrous Cake
  244. anybody sprayin patriot heads??
  245. Opinions for new setup
  246. hi mileage Lt1.... questions
  247. Going for my first tune
  248. FJO Gauge Compatibility??
  249. solinoid placement on DP
  250. New best 5.51@128.5 with a 1.33 60ft on radials
