View Full Version : Nitrous Oxide
  1. Jetting Question...
  2. who makes sheet metal intakes ? and how much do they cost ?
  3. Is this jet 125 hp at the flywheel or the wheels?
  4. DRY Dual Tuning
  5. Nitrous Direct BEWARE
  6. how to spary a 300 shot ??dry?wet?Direct port?staged ??
  7. car wants to die after spraying
  8. Heater problems/questions
  9. Another Nitrous Noob question
  10. Little help please
  11. RPMs w/NOS vs N/A in 1/4 mile questions
  12. when to upgrade stock MAF?
  13. Daves Plate with Black lines PICS
  14. Stand alone Fuel location?
  15. Couple pics of the motor in the car.
  16. 4 an nozzle's who makes them
  17. 408 is in, and about ready to start
  18. 98 WS6 Injectors on 100 shot...
  19. nitrous stopped working
  20. Airbrush Special
  21. Fuel INJ Upgrade Needed?
  22. Quick question
  23. new to nitrous
  24. Whens the secret AF ratio product coming out for the dry kits?
  25. Max Shot on small cam
  26. Two burned plugs....
  27. was told that 98s can take a dry shot threw the maf
  28. Bottle Nut for 1/4" NPT
  29. ?????
  30. Fuel Supply?..
  31. New to nitrous......
  32. Shot on Factory Tune?
  33. Tuning opinons please
  34. Condensation on nozzle
  35. 75 Shot Wow.
  36. How much hp will a nitrous tune/setup cost a NA motor
  37. do u have a fpss and a fuel pressure gauge? show me ur rails.
  38. What Jets for 100 shot Dry on Dual NOS Nozzles?
  39. lt1 crank
  40. What RPM should i spray at?
  41. such thing as a fail safe solenoid?
  42. Timing for a 150 shot
  43. dual purge?
  44. What kind of direct port systems are you running
  45. I've been off the bottle for two weeks!
  46. Teflon Paste/ Red loctite
  47. Anyone heard of air-activated solenoids?
  48. Can I spray the 125 shot?
  49. The 2 Day Nitrous Sale!!!
  50. Dyno today at HiTech Motorsport!
  51. Need Custom Brackets for my Nitrous Selonoids
  52. Check this out
  53. quick fjo question
  54. HSW dry kit questions?
  55. Limit of Nitrous on stock Aluminum Block
  56. nitrous with stock gears and stall
  57. building a 408
  58. FAST 90/90 and nitrous
  59. Do you think this will work...
  60. 4.25 bore LSX + 200 shot = head gasket life?
  61. July Specials from HSW
  62. Is timing tuner the only option to control timing on the fly?
  63. Piston or rods for 300 shot
  64. Introducing The Hemi Nitrous Plate!!
  65. Problem with Zex and idling
  66. solid roller on the way!!!
  67. Innovate Wideband - tops for accuracy!
  68. clutch switch
  69. MS4 Cam and Nitrous
  70. high pitched flutter?
  71. Nitrous cam and some other stuff for sale.
  72. Timing ??
  73. Can A Zex Kit Handle A 150 Shot?
  74. Cam For Nos Is It Worth It?
  75. New Nitrous Motor!
  76. Sprayed 1st time and thought car should of felt faster.Is something wrong?
  77. 4l60e & 150 shot
  78. 12 volt switched location???
  79. What do I need
  80. Whats All Need To Spray 125 On 97 C5 Vette?
  81. synergy box?
  82. Can I 2 step and have a micro switch on the pedal?
  83. Dynotune two stage cam only LT1 11.002
  84. CGA-660 bottle valve
  85. 715 Rwhp Stock Bottom End Ws6
  86. I am afraid to hit the nos button
  87. Dynotune Nitrous
  88. NA results with the lsx!!!!
  89. Best Gear For Sprayed Car?
  90. where to mount the window switch?
  91. my car, 35-145mph n/a and on spray
  92. Buying a kit from my friend, will this do?
  93. Nitrous Outlet TB plate question.
  94. msd digital rpm switch
  95. Switch wire routing
  96. Too much pressure for FPSS?
  97. Building a motor
  98. **PICS** Nitro Daves 85mm plate, stand alone, and more...
  99. How much 1 bottle can flow
  100. Help. Selenoids won't fire
  101. Spraying a low compression motor
  102. Read spark plug
  103. Used Nitrous System 4 sale!!!
  104. The 2 Day Sale!!!!
  105. Blow down tube rules
  106. Hard to start after spraying
  107. Nitrous hook up(pics)
  108. DynoTune Two Stage RPM Window/TPS Switch
  109. Put 200 Jets In
  110. going to order a kit so look at this
  111. Timing tuner
  112. Nitrous Outlet has Beer Switch Panels..
  113. my set up
  114. old but new dry idea
  115. Lookie what I got today!!!
  116. running the nitrous line
  117. LSX pics and info!!
  118. NX-11107 Remote Bottle Opener for Sale
  119. Can you Mounting a 15bls. between the seats ?
  120. What Size Shot For Stock 98 LS1?
  121. Would you use this solenoid
  122. cupholder switchbox
  123. Started assembling the lsx!!!
  124. Fjo + Nxl
  125. Nitrous Outlet 90mm Kit on C6 Z06... Install PICS inside
  126. Bottle mounting locations
  127. Alittle Help.
  128. Stand alone fuel tank
  129. NOS Mini Controller ???
  130. H/C and nitrous
  131. Would 46lb Injectors be overkill?
  132. nitrous guage question
  133. will NGK TR6 cause lower AFR
  134. Harris Plate System!!!
  135. pics of my wot switch....
  136. Im thinkin about sprayin the bitch
  137. Nitrous setup makeover
  138. head studs
  139. Would the Ny-Trex triple threat kit be a good beginners nitrous setup?
  140. And The Winner Is....................
  141. 100 shot....1 second slower???...WTF
  142. Leaky NX Fuel Solenoid?
  143. Changing Intake Studs To Add Nitro Dave's Plate
  144. $2000 Budget What Shoud I Buy
  145. NX Bottle Opener Problem
  146. TNT finally installed !!!!!!
  147. what kind of times are u guys getting with 150 shots?
  148. timing tuner wiring HELP
  149. 383 nitrous cam
  150. Time to head to a dyno. What afr should i shoot for?
  151. Solenoid question
  152. Digital N20 gauge?
  153. msd,and tps help
  154. help me with my NXL kit
  155. WTB Billet nitrous brackets, where to get?
  156. LS2/LS7 Timing Twister
  157. nitrous pressure gauge problem
  158. spark plug gap question
  159. Fuel pressure saftey switch
  160. finaly got off my a$$ and finished installing my kit pics inside
  161. Biggest DRY shot?
  162. NEW PRODUCTS, Black Series Display Controllers.
  163. Coolant coming out the overflow!!!
  164. R.P.M.'s Black Nitrous Car
  165. nitrous wiring
  166. Post Pics of your Carb Intake/EFI Conversion plate kits!
  167. education comes high
  168. Robert, Beer, Dave can one or all of you check this wiring for me
  169. Injector question
  170. My Nitrous Install
  171. Nitro Dave's 90mm Plate Install on LS2 TBSS?
  172. LT1 Wet Setups
  173. Questions about the NX rail system.
  174. Nitrous Jet Help?
  175. smoking on track!!
  176. And it begins....
  177. hidden nitrous systems let see them!!
  178. Anyone spray torquer 3 cam only?
  179. MSD Digital window switch help
  180. Nozzle Placement - Custom CAI
  181. LT1 Timing Adjustments
  182. How much N2O in HP can 3AN line flow?
  183. Rich Backfire?
  184. 75 shot on 86,XXX mile Z28
  185. nitrous express bottle heater??
  186. TR-6's to hot for 150 shot?
  187. Which verters are you running on spray ?
  188. Zex wet kit w/ MSD window switch 8969 wiring diagrams?
  189. What head bolts?
  190. wot switch
  191. rear cylinders running lean, why?
  192. What times should i be running know? Can i make into the 11's?
  193. Experience with Zex?
  194. NOS A/F Ratio
  195. No2
  196. Ring gap numbers for a 9 thousands over piston?
  197. Just got a 64# cylinder,want some input.
  198. running way rich question`
  199. Pulling timing with IAT resistor mod -- Did it work for you?
  200. timing pulled using a resistor
  201. This is what my stock short block and heads look like after......
  202. dry kit installed
  203. anyone heard of this?
  204. efi direct port beck sheetmetal intake!!!!!!
  205. LSXTV Video
  206. Hooking up BMN WS in conjunction w/ Mallory 685?
  207. CTSV nitrous trial runs.
  208. Thanks Nx Ricky
  209. Another how much ?
  210. what is normal bottle pressure and what is too low?
  211. ashtray switch
  212. pics of dry nozzle location on SLP lid anyone????
  213. Ideal air fuel on a 200 shot.
  214. clean tach signal for fjo controller
  215. fuel pressure safety switch question??
  216. Bone stock GTO with spray dyno numbers inside
  217. Pictures of WOT switch
  218. How much does weather affect n20 cars?
  219. Jetting question??
  220. Please Help Going To The Track Can I Spray This Much
  221. N20 wiring help?
  222. Shakedown passes with Weber Racing 403ci LS2
  223. couple questions for halo owners
  224. Nos wizards..wiring help! I read the sticky and am having difficulties....
  225. NOS Wet Kit working better
  226. Tips and help
  227. Thanks Nitro Daves!
  228. 05-06 GTO Dedicated Fuel System..
  229. cold fusion nitrous kits
  230. opinions on a product
  231. which plug for a 100 shot
  232. Some setup pics
  233. What size qauge adapter?
  234. anyone know where?
  235. Painted my noids
  236. Want an NX Banner
  237. COMBINING NITROUS & 4:10 GEARS
  238. Finally 8's
  239. is nos soft plume nozzle fwhp
  240. Can I Run A Dry Shot With My Setup?
  241. WOT switch
  242. n20/fuel line questions
  243. 120k?
  244. Help pick Progressive controler for this setup.
  245. 224/224 114 + Nitrous Question
  246. which wet kit?
  247. Question about the Blow Down tube
  248. What jets for 150rwhp Dry?
  249. You Pick The Winner
  250. Stall and zex kit: Tricky Question
