View Full Version : Nitrous Oxide
  1. nxl kit....need help
  2. Nitrous newb, trying to clarify before purchase.
  3. nitrous newbie ?
  4. guys please help...correct answer will get 50 bucks paypaled to them
  5. Yummy-NOS
  6. NEW Bottle Heater
  7. Where to mount solenoids?
  8. new best on spray today
  9. Good idea/bad idea?
  10. where to put the bottle...
  11. Nitrous rings? Coated pistons? Ring spacing?
  12. Timing tuner installed,Feels slower now?
  13. M6 nitrous drag racers inside please!!!!!!
  14. wet shot question
  15. Can't decide where to put...
  16. Lean on nitrous run AGAIN, help please!
  17. has anyone ever mounted their switches here
  18. High Mile Cars spraying?
  19. Finally hit a decent sized shot again!!!
  20. LSA/ Lobe seperation for Nitrous
  21. Quick question!!
  22. Just recieved my HSW Standalone!
  23. "Big Shots"
  24. need help. where to mount relay????
  25. Little Wiring Help
  26. Why do we need nitrous when we have Ram Air?
  27. Have the bottle now what?
  28. how much spray on forged 347??
  29. Nitrous sponsors
  30. How much can soft plume nozzle flow?
  31. Dry kit nozzle selection?
  32. What are your favorite Nozzles, wet and dry?
  33. How can i make sure my noids are good?
  34. solenoids
  35. too much tire for the bottle?
  36. New to Nitrous...Need help
  37. opinions on burst panals?
  38. fuel cell question
  39. What plugs to use for nx
  40. What is the suggested jetting for Daves plate system??
  41. Window Switch Wiring for a 98
  42. SPAYING ON MY TUNE 36lb Lucas Injectors
  43. Dynotune WOT switch?
  44. Too much fuel? NX Dual Nozzle Kit
  45. What do guys think of this zex product?
  46. Help me decide which way to go
  47. Whoever said nitrous is cheap is an idiot...
  48. took my first step towards a sprayed LS1, now I need help!
  49. Dynotune window switch wiring...
  50. Nitrous with aftermarket fuel rails pics needed.
  51. Another Free Dynotune 10# Bottle!!!!
  52. Switch question
  53. The Winner Of A Free Dynotune Bottle Is......
  54. Quick question about the Nitrous Outlet plate kit.. -4 or -6??
  55. Where to get tach signal on 99 TA???
  56. question bout a Auto trans
  57. Need a little Feed Back VOTE!!
  58. Wet Plate
  59. 107 RWHP from 150 shot?
  60. bad window switch?
  61. where is the TPS wire?
  62. Nitrous Explosions
  63. 12lb in a 10lb bottle
  64. Let me see your dual bottles in your f body
  65. 1 10lb enough for dual stage
  66. bottle heater not working
  67. LT1 Plate System Group Purchase!!
  68. Came accross a cheap Dry kit. Use it or wait for plate :)
  69. for those with wideband
  70. Need motivation
  71. ringlands and nitrous
  72. dry kit questions
  73. Anyone accuratly explain why the TREX cam doesn accomodate big N20 doses? 3 part Q.
  74. Any big dawgs coming out this season?????
  75. Bottle opener switch input needed
  76. ?Purge through SS Hood? ??How-to??
  77. Good results w/ Nitro Dave's Plate
  78. what all needs to be done to run a 75 shot
  79. fuel systems for nos
  80. Purge Through Firehawk Nostrils
  81. some nitrous parts and other stuff for sale
  82. What compression are you running on your N20 370?
  83. Mini freezer for chilling bottles before filling?
  84. Which nitrous kit will put me in the 11's stock?
  85. Real dumb question
  86. ignition box
  87. LS7 Clutch & Nitrous
  88. 100 shot on heads and cam
  89. pic's of my rollbar, and bottle mounted
  90. HSW solenoid bracket problem
  91. nos plate above or under the spacer
  92. FPSS Adapter??
  93. spray patern
  94. Pictures of WOT Sw. on Fast/NW90
  95. Installing all the wiring?
  96. Msd Window Switch
  97. Noids + Heat
  98. fjo install , now a throttle problem
  99. pictures of my direct port
  100. Newbie....im lost
  101. solenoid pressure ?
  102. DYNOTUNE diagram!!!
  103. Nitrous and pressure gauges.
  104. Nitrous Outlet Plate Kit Pics!!!
  105. breaking 10's on juice?
  106. FPSS vs. A/F shut down switch
  107. how do i
  108. good start?
  109. TNT 150 shot Gains
  110. Rules for N20 at the track
  111. HELP egr sims avalible
  112. |Started working on the cars!!!!!
  113. Spraying fly cut pistons...
  114. Hsw Plate Kit?
  115. Can you run a FPSS and FP gauge together???
  116. nos nozzle maxes out at 150?
  117. 408 vs 418
  118. If it burns gas
  119. Octane requirements for 13.5 to 1 compression 408 and a 300 shot?
  120. Looking for a FPSS and some gauges
  121. Actual rwhp from nitrous
  122. hey guys, I'm fameous !!! Nitrous Outlet Customer cars
  123. heat and solenoids
  124. Nitrous Plate Kit for 85mm
  125. Nitrous Line question
  126. wiring question
  127. Solenoid Help??
  128. nitro dave plate kit?
  129. ls1 guys an n20
  130. LS1 intake and 125 shot...Good OR Bad?!!
  131. nos soft plume jetting and thread size?
  132. Anybody running the LC-1 Wideband Air/Fuel Ratio system for Autometer
  133. do i have everything now?
  134. Nitrous ????
  135. 250 whp shot, need advice
  136. Cold Fusions Direct Port Kit???
  137. Detailed write up on heater install?
  138. Few questions from a N20 Newb...
  139. Spray on a 4000+ Converter?
  140. How much shot to beat turbo cars?
  141. how much do you pick up on a 75 shot?
  142. Using LS6 ignition box to pull timing?
  143. Installed my Nitro Dave's plate kit
  144. Options for Direct Port tubing?
  145. is my bottom end in jeopardy?
  146. New Pb,
  147. Need some install feedback please
  148. A pic of my 90mm TNT F1.
  149. MAF screen issue
  150. Need HELP with Noid Placement (pix 56k beware)
  151. New C5 Z06 Stock LongBlock Record
  152. I'm preregistered for Pinks All Out at Moroso Motorsports Park...
  153. Nos ?
  154. Date on bottle?
  155. Nitrous newb questions, Im confused!
  156. wiring tips
  157. NOS two-stage nitrous controller
  158. Is it okay to put to nozzle before the MAF??
  159. 125 shot on Heads/cam will stock tranny hold
  160. MAF kit, for an LT1..
  161. Nitrous Daves Direct Port
  162. ZEX kit just installed need help!
  163. SCE ICS Titan Gaskets...
  164. Att Noyzee !!!!!
  165. 11.0:1/N02 who's doing it
  166. NITROUS users help please...
  167. HSW Nitrous plate Whens it coming out?
  168. 2007 Nitrous ET List
  169. Broken Schrader Valve...
  170. looking for a nxl kit
  171. cheapest dry tuner shot??
  172. tach signal
  173. cost of nitrous in bulk
  174. Manual iso valve on fuel side of wet kit?
  175. Any sponsors got plate sytems for LT1 or any new stuff?
  176. Problems with ZEX
  177. fast 90 w/ zex direct port.
  178. Test suggestions
  179. Your Nitrous Horror Stories
  180. Which nitrous controller for a Turbo M6 car??
  181. how many people spray more than 150 with a tnt f1 kt
  182. Timing Tuner Questions
  183. What wide band are you using?
  184. HSW Standalone GP?Anyone interested
  185. Dynotune Air\Fuel ratio gauge install?
  186. compucar nozzle & jet size???
  187. stock injectors & fuel pump
  188. NX intake, NXL DP system, 85mm TB
  189. which intake setup would be the best for either direct port or a nozzle
  190. N2O vs HSW driver's side fuel cell
  191. Question about NO2 bottles
  192. what would be best?
  193. Jets for a 200 & 250 shot?
  194. Another "how much will it handle" thread....
  195. Hey where's the new Fast Nitrous list, I have an addition?
  196. Purge wiring
  197. Hose Sizes
  198. wet or dry on a mustang?
  199. Been hearing alot about stand alone fuel system have questions
  200. What NO2 carburetor kit
  201. Car not responding to nitrous.
  202. 2007 C-6
  203. 2007 C-6
  204. Idea for an old pill bottle
  205. 1 gallon fuel cell in engine compartment
  206. What gauges are recommended for a safe Nitrous system?
  207. F.S. NOS LS1 Plate kit....
  208. what head gasket for my LT1 383 with nitrous
  209. Nitrous Distribution
  210. how much juice can it handle
  211. zex wide open arming?
  212. Is this a fpss? (pics)
  213. Magic stick 3 with NOS
  214. How do you set a FPSS
  215. quick question about spraying with my cam
  216. 14168nos bottle opener problem
  217. torquer v2 w/ nitrous?
  218. which window switch should i get??
  219. What is the best nitrous kit??? Ls1
  220. Anyone ever see this? Is it common
  221. Tested my TNT kit
  222. any good?
  223. Help Today
  224. Ready to use NOS
  225. May have caused damage!!!!Please help
  226. 15v not good for noids?
  227. Requesting Main Nitrous Feed Line Routing Pics
  228. Nitro Dave's Dedicated Fuel System
  229. Whats the proper way to set fuel pressure when
  230. Carolina Dragway Nitrous Backfire on C5 (56K NO!)
  231. tuning for a dry spray on a cammed ls1??
  232. Where do you think I should set my window switch?
  233. thinking about nitrous, this a good kit? what about Tuning after?
  234. Accident & Bottle Location Problem...
  235. nitrous plate???
  236. Is this Dyno Tune kit a good kit for me?
  237. Nitrous Express NXL kit
  238. Nitrous Time.....
  239. N2O Newbie
  240. Will this work?
  241. Progressive controller for big noids
  242. Another nitrous question.
  243. look at this
  244. Zex Wet Kit Help
  245. calling all fjo guys
  246. nitrous gauge cheap?
  247. A little advise please on my setup.
  248. Good basic kit for my LT1...
  249. New N20 User.........need tips(HSW Wet Kit)
  250. New Dual Nozzle System!!
