View Full Version : Nitrous Oxide
  1. What spark plug is right for me?
  2. How many passes are you getting on 100 shot??
  3. racing fuel with nos
  4. My Stock shortblock/cubic inch cam-only entry:) 56k beware
  5. stock ss wanting nitrous
  6. horrible service at NOS
  7. Ways to know you're out of spray?
  8. Newbie Wants to Spray Update Track Times
  9. 2 stage fuel setup?
  10. Nitrous valves where air pump used to be
  11. How much 110 should i mix into my tank?
  12. Dry shot tuning question
  13. Nitrous Solenoid Problem (wont open)
  14. What amp switch to use for nitrous arming switch?
  15. first timer
  16. Adding & Tuning 2nd stage?
  17. 2nd stage gains?
  18. new best stock internal spray
  19. Need some info
  20. Check for properly functioning solenoids
  21. weird problem, need help, where to start?
  22. Stock short block ls1 h/c track results
  23. Huron Speed NX TBSS Plate Kit Install
  24. Stock Long Block Nitrous Record
  25. HELP! installing MSD digital window switch problems...
  26. Bolt on/150 shot LT1 track results
  27. 427 LS3 Stroker with N2O
  28. fuel injectors/pump
  29. Is my cam ok for nitrous?
  30. Pictures of Tunnel mounted Bottles?
  31. 416 LS3 e85 Nitrous plug question
  32. bottle mounting/track rules
  33. how does this plug look to you
  34. tuning for nitrous
  35. Summit Racing Dual Window Switch?
  36. Just a vid of my Trans am last night
  37. I'm gonna go out on a limb here..
  38. Nitrous Outlet plate and DIY standalone on 5th gen
  39. How big a shot?
  40. Home made N2O Stand Alone Fuel Cell
  41. What feed line do I need?
  42. best custom grind cam
  43. NX Express Direct Port/Fuel System Need Help?
  44. track datalogs
  45. How much can I shoot..
  46. Fastest Stock CI N20 car ever!
  47. Harris Speedworks
  48. sprayed my monte on dyno tonight
  49. Will a "Nitrous Works" bottle work with another kit?
  50. Need Nitrous Installer Tonight!! SACRAMENTO/NORCAL
  51. Who is playing the stock ci game?
  52. Bye bye nitrous. Hello Boost ......
  53. Stock LS1 nitrous help
  54. Thinking of going Nano....
  55. Race fuel stored in plastic dispenser ????
  56. Bottle psi
  57. Does anybody have HSW's number???
  58. stock nitrous freak
  59. Spark Correction
  60. Nitrous setup.. ?
  61. 383 or 370 for nitous
  62. Total timing for 200 shot?? what fuel?
  63. what nitros system is best 4 my cammed ls1
  64. Harris n20 and fuel line length
  65. What to expect
  66. Nitrous activation switch
  67. Zex Nitrous Kit Wiring
  68. how to set up dual plate system on ls3 intake
  69. HUGE thanks to Whistler & Nitrous Outlet team & Mike @ WS6store
  70. 150 shot issues solved/Thanks Steve TunedbyFrost!!!
  71. Which timing box?
  72. What is the best brand of Nitrous
  73. Not to sure but chasing a idea!!!
  74. Blow down tube fitting?
  75. lt1 bogs on 100 shot
  76. fuel system upgrade
  77. DIY Remote Bottle Opener - Pics & Videos!
  78. nitrous spark plugs?
  79. 150 nitrous tune
  80. NOS kit owners in here!!!!
  81. Nitrous Routing Suggestions?
  82. Got my Flaring tool..Which Bender?
  83. E85 Nitrous Jetting HELP
  84. Nitrous wont hit?
  85. dyno n20 tunning need some suggestions and hp input
  86. Entering The Juice World
  87. Who is running NANO?
  88. Timing effect fuel?
  89. 78mm NOS plate porting
  90. N2O installer/dealer around the Charlotte NC area
  91. HOW TO: Make a Timing Retard Box for a Nitrous Oxide system...
  92. SBE 3700+ raceweight and a little nitrous
  93. 75 shot w/stock rear
  94. what RPM are you spinning your stock bottom end nitrous ls1?
  95. All plug readers in here
  96. nitrous controller? retard ?
  97. Digital or Analog N20 Gauge?
  98. Harlan Two Step relay control
  99. Vplus Volt Booster/150 wet shot
  100. 408 rebuild 300-400 shot help
  101. Questions: N20 kit for a C5Z
  102. could i hit tens on a 200 shot with bolt ons and stall?
  103. window switch wiring
  104. Dry shot questions
  105. check out this plug...
  106. Dont Get it
  107. 16 Nozzles, 4 Rails, Tons of Fun
  108. TNT Power ring
  109. Lingenfelter lnc-2000 arming light suposed to blink?
  110. Camaro 3.6L Nitrous Outlet Plate System
  111. This is probably a stupid ?...but
  112. Another satisfied N20 outlet customer!
  113. Nitrous Outlet Bottle Weight Questions???
  114. Is there something wrong here?
  115. How much timing are you running?
  116. can i shoot a 300 shot with these pistons?
  117. Help with bellow on TNT KIT.
  118. E-85 jetting for carb setup
  119. 150 wet shot jetting
  120. Liquid propane as a fuel in a nitrous wet shot set-up
  121. dyno tune plate gasket?
  122. Injector size?
  123. Doug Getting It Done!
  124. ss owners where are u running your purge?
  125. Running your feed line close to radiator = problems?
  126. question about nitrous
  127. How many tune off
  128. Purge stuck open, coil won't come off the stem.
  129. Another plugs thread....
  130. Nitrous why you should use it!
  131. nitrous express?
  132. Timing Commander
  133. Testing system with a nos mini controler?
  134. Huron Speed now Nitrous Express Dealer!
  135. TNT F1 and NOS jets Question
  136. Newbie / advice needed please !
  137. Want to learn about methanol ??
  138. first time on spray.
  139. Nitrous fittings
  140. n/a+spray+e85???
  141. How much improvement from 150 to a 200?
  142. How much should I trap on 150 shot?
  143. aluminum block strokers and spray
  144. Selling my nitrous setup(motor&kit)
  145. HSW Microedge +
  146. spray bar vs direct port nos
  147. 100 shot.... Not satisfied
  148. Need 150hp jets for nitrous outlet kit. This right?
  149. Stock manifolds/exhaust = too high EGT?
  150. i need help on bottom end limit
  151. Hardline Kit w/ FRCs
  152. Ultra street 94' Mustang build
  153. Tuning N20 w/o Dyno or Wideband?
  154. msd digital window switch install help
  155. What should I get? Need help?
  156. No2 controler suggestions
  157. help me pick a fuel pump
  158. fuel pump choice for standalone...
  159. lets see your nitrous switch and gauge pillar set up
  160. Dallas Raceway Nitrous Outlet 150 shot
  161. First Nitrous LS to the 4.70's!
  162. which tps wire for zex kit on LT1
  163. Stall size with nitrous?
  164. Looking for an LT1 Nitrous kit
  165. How much do you backhalf?
  166. undecided not sure who to go with
  167. A/F is mysteriously fixed, lol
  168. Flow Test of Our New Restricted Nitrous Class system
  169. Project of the Week - BBF Direct Port
  170. I need a little help please
  171. Playing with Jet sizes for better AFR's?
  172. Project JUICED stock LS1 99 CAMARO
  173. My Nitrous Outlet VIC Jr spray bar intake came today
  174. How much are you spraying through your Nitrous Outlet plate?
  175. LT1 nitrous plugs
  176. Issues at the track yesterday
  177. Bottom end/valve train noise + 100 shot?
  178. Solenoid and spare tire bottle brackets?? Where to get?
  179. Nitrous for LT1 - which controller/fuel pump?
  180. 'Bout to set this car ON FIRE! Help!
  181. plug? ??
  182. A New Tech here for you guys
  183. Newbie Questions
  184. nitrous set up on a cam/bolt-ons WS6
  185. spark plug gap ? i read the sticky
  186. Nitrous outlet custom dedicated cell mount with PICs
  187. having a new tune without NOS
  188. Black Widow System on Fast 102
  189. NOS high-flow valve vs. old style
  190. Biggest Shot On Stock Long Block
  191. Plug change, nitrous soon....
  192. Fastest Stock Long/Short Block?
  193. help
  194. First Pass 1/8 mile 150 shot
  195. Homemade switch panel
  196. pulling timing choices
  197. Where is the leak?
  198. which direction going lean
  199. Critique my build
  200. LT1 Intake Max Shot
  201. trying to finish up my kit...
  202. Full nitrous build questions
  203. Did a Little Wiring on a buddy's G8..
  204. Nitrous Express direct port services
  205. Nitrous Outlet Switch Panel
  206. solenoid Maintence???
  207. Speed density tune with nitrous??
  208. how can I get 30 amp connect to au bat?
  209. spark plug heat range?
  210. Blown Intake and have some Plug Reading Question.......
  211. Help me build my engine
  212. 150 shot questions
  213. what head gaskets and CR for nitrous 4.8?
  214. Calling N2O Vendors
  215. nitrous question
  216. Will I hurt anything?
  217. Super Vic question
  218. added 100 shot
  219. Some GoPro fun from SGMSP
  220. Help please
  221. New 408. How much nos?
  222. how much gas will L92 pistons hold??
  223. NOS against RC
  224. 90mm 2 stage plate... dyno #'s
  225. cam/spray-nano/boltons 581rwhp 582rwtq
  226. Rookie question.. with purging
  227. too much???????
  228. 92mm tb bracket question
  229. Beck Sheet Metal 3 stage
  230. What fuel setup for 2 stages
  231. Did some testing on our DF-5 valve.
  232. Vic Junior guys, where are you mounting solenoids. Pics would be appreciated.
  233. Shooting for the 5,s
  234. Noob thank you
  235. Low compression and nitrous
  236. new to nitrous. quick question?
  237. Anyone want to try a DF-5 valve for free?
  238. how much can a 5.3 handle
  239. so I'm doing my head gaskets and...
  240. Difference between150 and 175 shot?
  241. stock ls1 nitrous record time and who has it?
  242. Fuel setups
  243. Zex wet kit
  244. Nozzle vs spray bar
  245. Watch out all Stock Cubic inch players... Were ready
  246. Anyone know what brand this is?
  247. Wiring diagram for LNC-002 and NOS mini controller
  248. Harris plate with nx jets?
  249. Talked to old school racer about n2o & timing,do u think he is right? Need exp. guys
  250. 5.3l vs 6.0l nitrous mustang build
