- Switches in the TCS plate
- Quick question about brand...
- NPT sealer
- Nitrous setup, what gears
- We are proud to announce Outlaw Stand Alone Fuel Systems
- Might be adding nitrous later.. Need imput.
- Spraying through shifts
- leaded gas, o2's, and standalone
- Dry and wet questions
- New to nitrous with 685 questions.
- Won't activate @ WOT
- Straight shooter wet nozzles?
- Nitrous
- need some imput here please
- Last Minute Christmas Specials
- Nos P/n 05168nos
- 238/242 on116 safe to spray 150
- Looking for a 120V bottle heater.
- Nitrous Noob, need some fuel questions answered
- Advice on a nitrous system.
- Nitrous noob
- Question about a TNT F1 kit for LT1s?
- Nitrous heating
- Question: Nitrous, the whole nine yards
- broken spark plug, possible damage?
- NPB but service engine light on??
- Can you use braided line between solenoid and plate?
- Nitrous timing
- Question about...
- how much spray
- Purge setup pictures
- Troubleshooting
- 4200 stall and spray?
- Why do all you guy and gals keep filling your bottles?
- Just a little help
- 32lb injectors
- My TNT F1 Pics.
- Nitrous Gauge!
- Importance of line lengths
- Where to get a direct port Kit
- nitrous time chart???
- nx jetting help
- 5177 Dry Kit Help!
- 150 shot on all motor tune
- LT1 Edelbrock Performer EFI Nitrous Kit?
- Bottle Blankets
- H/C Ls1 RX7 Time for some Juice :) Wet or Dry?
- 200 shot!!!
- Car acting weird after 75 shot
- Nozzles and jets.
- Who makes plates?
- spraying on 115 lsa
- Compucar Nitrous kit ????
- best place for wet nozzle
- fuel pressure safety switch question
- Bottle In Between Rear Seats ?
- HSW (Matt) bottle heater question??
- FPSS Calibration
- nx kit?
- TNT F1 vs TNT F2
- Bottle warmer rig up ?
- Nitrous Question
- Newbie Nitrous Question
- nitrous wiring..
- trying to understand nitrous setup.
- Last "run" of the year with the nitrous
- DynoTune Remote bottle opener - opinions?
- Corvette guys LOOK!!!
- How much PE increase for 50 dry
- how big for race gas
- whats better wet or dry kit???
- Quick Question..!!
- Cam overlap problem?
- NX 200 shot help?
- Cheatr Cam & Spray?????????
- how much fuel psi?
- nitrous afr
- contemplating nitrous
- 06' Gto
- LS2 w/ wet kit
- Nitrous Direct Christmas Specials!!!!!!!!!!!!!!!!!!
- Need NOS
- Nitrous Tune vs. N/A Tune
- Bottle Pressure Questions
- Any non mechanics spraying?
- Anyone ever try this bottle heater idea?
- link to dedicated n2o fuel system and some n2o parts for sale!
- who installs nitrous in MA
- Nitrous Outlet Christmas Specials!!!
- Can you get away with this oops on WET?
- ? about MSD Window Switch
- tuning in a nos kit
- Cam LSA affects on Nitrous
- Oil pressure gauge as a fuel pressure gauge?
- Power Shifting
- bottle heater. how hot will it get?
- Plugs???????
- Problem with wet shot..
- Burst Panel ??
- HSW Wet Kit
- getting dynoed 2morow what should tuner mess with when tuning for nitrous??
- nitrous jetting
- ***New Best @ The Rock 8.70 @ 159***
- Is this ok for a wet 100 shot???
- n2o and shift
- Discuss AFR
- how much is "safe" to spray on 11.5 comp.
- First 8 second n20 pass
- Nitro Dave Plate System Installed PICS (56K no way)
- Timing
- plugs???
- ran 100 shot @ track yesterday
- Zex wet with MSD digital and relay wiring(NO fpss)??
- standalone question
- First Log w/ hptuner -Beer99/Robert56
- Dry shot surging...
- Nitrous????
- Nitrous on Stock Setup???
- Direct Port Question
- need nozzle help!
- how much to spray???
- And the winner is.......
- Free Lc1 With Dynotune Guage Or Lm1
- Lets congratulate ProjectCamaro!!!!
- Big thanks to Nitro Dave
- I am pleased to announce
- So I decided to do a freshen up on the shortblock and this is what I found!
- off the shelf mahle pistons?????
- Choosing nozzles for diff stages.
- spray bars in victor jr nitro dave setup
- Nitrous plate
- Install question
- Solenoid mounting?
- what spark plugs for bolt on LS1 with 125 shot?
- most i can spray on flycut pistons
- prob with purge
- Going with the Zex 125 kit what else do I need?
- runnin nitrous on sat
- How About A Extra 220.00 For Christmas
- nooB question "fogger" and "Direct Port"
- Can I use this kit? ZEX?
- what gear to spray?
- Nitrous Dry Shot GOES LEAN!!!!
- Plugs to use with 100/125 dry shot
- Oil pressure at 130?
- Trick Window switch and Timing Tuner used together???
- Timing tuner wiring...
- Just Ordered Wet Kit
- stupid question but its killing me...
- Complete Kit, did I miss anything?
- Best nitrous cam?
- NOS Pro Race Fogger
- Instead of window switch?
- Testing carb plate tomorrow
- Blowing fuse
- jacobs nitrous mastermind on ls1????
- Will one step colder plugs hurt me when i am NA for a while
- New Generation of 860 Heated Bottle Brackets
- stupid nitrous question
- powerdyne
- NX Nitrous Filter - Anyone using one???
- TNT Jets..where can I get them??
- CAM HELP Who to have spec IT???
- Nice job Beer on my new switch panel!
- Jet size with stand alone?
- Purge Solenoid
- 100k motor + 125shot n2o + cam/heads (405hp/400tq) + stock tach + 6400rpm = NO NO
- Stealth nitrous install pics, can you find it?
- Couple nitrous-related wiring questions
- To the guys who mounted their bottle in the fender
- Dualstage fuelsystem would this be enough?
- 55 Shot on a 3.8 Engine?
- Direct Port
- NX bottle opener, or any opener, do they go bad after while
- Who's running stock M6 clutch with 100 shot or more?
- do I need a bigger fuel pump?
- Window/TPS/Fuel Shut Off safety questions!!
- what is the diffrence between.
- selinoid problem, why?
- FJO Set up
- Fuel upgrades?
- Warning!!!!! : Manufacturers recomended jetting
- 382 stroker how much can i spray?
- Tnt Lt1 F-2 Nitrous Kit For Sale!!
- Nitrous Blows Up My Motor
- What cam would be safe????
- C-5 Z06 Cam & Heads w/ NOS Runs 9.94 @ 143
- help with tnt 90 f1 kit
- Nitrous converter
- Nitrous cylinder head
- Tnt F2
- what pistons can handle mega shots?
- Enough nitrous or need more?...heh...
- No TPS??
- 402/408 nitrous users in here!!
- Witch Nitrous lt1 kit?
- Autometer Nitrous Sender (Electric)
- MSD Window Switch
- Big Thanks to Josh over at NX! They put me on the bumper (video)
- Problem after spraying for first time...
- Problems
- arming switch connection question
- Blowtorch + fille n2o bottle = bad?..right
- Dynotune vs. CFN?
- 1/4 mile gains just spraying 100 2nd gear on?
- Well hope for the best! 300 then 400 going at it! Its the end of the year "Blow out"
- nitrous stuff 4 sale
- NOS fuel solenoid sticking open please help
- max shot through -4an and -6an
- Cam only, 100 shot ?
- FJO Controller
- some easy nitrous questions
- bumb idea, but as you guys seem so nice..... :)
- ordering the final pieces... got ???'s
- Couple quick questions
- Happy Thanksgiving
- Spark plug wires advance timing?
- Teflon paste?
- Proper nozzle placement on a Z28/TA airlid ???
- stock bottom end lt1 juice?
- Should Bottle Be Closed When Parked?
- NX Ricky, Dave or Jeremy...nitrous/fuel issue.
- What's the Main Killer?
- finally a gp on hsw's stand alone
- tnt purple ring!!
- i dont know
- Can you run a 100 dry shot on a bone stock 2000 Z28?
- a few questions for the people with big nuts, lol.
- How long will 75 hp shot last?
- Different Types of N2O Kits?
- what to expect to pay for a nitrous system
- Any problems running colder plugs on daily driver
- Dry kit instalation?
- NX Automatic Bottle Heater Transducer???
- Quick n' Easy TNT Questions...
- What size fitting is the line?
- ls1 + n2o = timing??
- Window switch and WOT switch question
- new PB in the GTO!
- Threw my little dry kit back on....
- Bottle won't get over 700lbs???
- New B Question
- GURUs !!! Help, problem with DIY setup
- what type of kit? direct port, or nozzle?
- FJO Progressive Controller Settings?
- Nitrous kit im buying
- some results on the black car
- nitrous missing on top end R's
- Nitrous on stock rods
- Window switch with NX Wet kit??
