View Full Version : Nitrous Oxide
  1. need to know NX 125 pills ASAP
  2. Corvette Bottle Install Animation
  3. Money Maker
  4. To flycut pistons w/ nitrous or not!!!
  5. Nitrous help PLEASE
  6. Nitrous Questions
  7. Injector Size ??
  8. Injector size ?'s
  9. Would i be able to slide by with a cast seel crank
  10. 200 shot gonna work?
  11. 402 with N2O
  12. Lets get a GP going on a standalone fuel system-Harris speed works
  13. Harris Speedworks! Can I at least get a free tshirt now?
  14. bottle in the spare tire compartment(vert's)
  15. All those who run dry post your shot size and Af
  16. Timing control for the LS1
  17. 175 shot + stock block?
  18. Spraying this weekend...NERVOUS
  19. is nitrous not the in thing?
  20. Is something wrong?
  21. FJO mini question
  22. where to set the window switch?
  23. 347 with forged pistions/rods can handle how much spray?
  24. Direct port using Edelbrock victor jr intake?
  25. !!!!!!!!!!new Open Pics.!!!!!!!!!!!!
  26. Progressive Controller BLOWOUT SALE
  27. Is anybody just doing spray + stall?
  28. Got an idea, tell me what you think....
  29. Switching to WET have Qs
  30. which heads?
  31. nx switch panel problem maybe.
  32. Finally Figured Out How To Post Some Pics..tnt Install...houston Raceway
  33. Nitrous parts
  34. Newb TPS/WOT question
  35. Dry Nitrous Jet Question
  36. stock fuel pump?
  37. BTL pressure for 2 stages?
  38. Nitrous Filling
  39. Before Posting: Look Over The Threads, Possibly Search Key?
  40. Free Airbrushed Nitrous Bottle.
  41. bottle pressure
  42. Nitrous Song
  43. Stock Bottom End or Forged?
  44. RWHP gains with a "nitrous" cam?
  45. Hey Dave! Thanks
  46. WOT switch Bracket?
  47. Would you do boost if you could?
  48. Dynotune
  49. Help for a MB
  50. Anyone in MI area help me set FPSS???
  51. Boltons + Cam + Nitrous + Stock Bottom End?!
  52. How to check fuel system? Just planning winter mods. DRY
  53. Anyone have some extra NOS jets laying around?
  54. tps wire question
  55. Just ran 100 shot.
  56. 125 dry shot w/ stock 28# injectors???
  57. jetting with direct port
  58. do i need a tune if i squueze?
  59. Jets for NX 20920 kit
  60. Nx 100 Shot Pills???
  61. which Nitrous to run???
  62. Activation switch question?
  63. NX gemini kit
  64. 2 stage wet and dry?
  65. Problems w/ NX TPS WOT switch?
  66. 250 Wet 100 Dry What Timing and Plugs?
  67. Progressive Control Question about Lean Condition...
  68. How to tell if high mileage motor/tranny is healthy enough for spray?
  69. Need help
  70. My very special 1,000th post!
  71. will a 100 shot be O.k
  72. Stock Injectors And A Dry Shot.
  73. I went to the dyno and found a problem. Help!
  74. wet or dry?
  75. Do I Have to get a tune for a 150 shot?
  76. Nitrous Install Tips and Tricks
  77. Nooby Nitrous Questions
  78. Will my stock tranny hold???
  79. Preventing Backfires
  80. Check this out! NEW Nitrous Product @ SEMA
  81. What is your favorite switch panel?
  82. !!!!!!!!GENX-2 for Christmas !!!!!!!!.
  83. Maybe done for the season
  84. NX solenoids (Maf Kit) Rebuild?
  85. NX solenoid leaking
  86. Help with nitrous activation.
  87. Corvette Tach Wire...
  88. tuning for nitrous??
  89. ?OLD style Power Ring?
  90. nitrous noid for opener
  91. 90k miles to many
  92. FJO Mini Problem
  93. What could be wrong??? z06 spray nutty!!!
  94. small shot???
  95. What gear are u guys running w/28" slicks!!
  96. bottle heater ?
  97. plate vs. nozzle
  98. Vid Of My New Best On The Spray
  99. HSW Trigger
  100. bottle bracket/mount for 20lber
  101. Video of my first ever nitrous pass!
  102. WTT: NX Bottle Opener
  103. Plate system
  104. N2O pressure guage question
  105. emissions?
  106. NX Single Nozzle 200shot Jets?
  107. My TNT Nitrous Install - Pics! 56K Beware
  108. Can I run 2 nozzles from one solonoid?
  109. Spark plugs...
  110. All Motor vs Nitrous shift points.....
  111. My first time spraying
  112. Want low 6's on the bottle
  113. Guage power supply
  114. nitrous cutting in and out
  115. Limits of the 4an main line?
  116. NOS question - jet size
  117. Re-wired some connections and now I am having problems.
  118. What size Jet for a 50 shot
  119. Compression and nitrous
  120. 1st time spraying at the track
  121. Nines Or Bust
  122. New shakedown run
  123. Problem with TNT fuel solenoid. Please help!!
  124. Direct port on ls1??
  125. Does it get too cold to run nitrous?
  126. Tuning for dry shots
  127. Nitrous Activation Question (Newbie)
  128. spray 100 shot on stock 100k tranny?
  129. new nod came in the mail today
  130. Ran 9's on stock bottom end
  131. Do I really need a tune for a 150 shot?
  132. Fuel Pressure Drop While Spraying?
  133. Nitrous?? HELP!!
  134. Give Me Ur Comments Please !!
  135. Who's hooking a 150 shot on radials?
  136. [Z06] Need some wiring help... (TPS switch and Digital MSD)
  137. Trac Cont. OFF automatically when N2O is ON. Interested?
  138. ** Hot Month Of November Specials!! **
  139. Post Pictures of your Fuel System!
  140. shift knob button
  141. Most miles on a stock motor + Spray
  142. Who has the cheapest wet kit w/o bottle?
  143. quick question??
  144. Iron 408 Nitrous Limits
  145. would you spray + heads + cam 100k motor?
  146. Can I use nitrous to cool IAT only?
  147. MSD digital window switch
  148. FJO help. Whats wrong??
  149. Progressive timing retard
  150. how much spray with forged mahle pistons?
  151. remote bottleopener ?
  152. Power wire question???
  153. Who's familiar with Ntirous Works "Power Wing"?
  154. Bottle Locations...
  155. Z06 fuel pump and nitrous
  156. who is running a TSP set up, not microswitch
  157. What all does it take to run 2 bottles?
  158. Help an ignorant man here...
  159. Free Free Free Free Free Free Free
  160. Nitrous being lugged
  161. LS7 w/200 shot = 8.90 VIDEO
  162. Anyone here use the Twisted Sanity N2O controllers?
  163. how good is nos
  164. C5 heater install question
  165. NEW ITEMS FOR 07. SOMe NEW, SOME IMPROVED;)
  166. thinking of spraying, how to get started
  167. Psi question
  168. NX Jet sizing
  169. Stock Bottom End LSx guys...
  170. n20 with 10 bolt
  171. new bottle location
  172. How many run in-line N20 solenoids on a wet shot?
  173. Where to buy Nitrous Express in Central America
  174. How The Heck Do I Change The Size Of Images To Post Pics!!!!
  175. I think I'm getting F'd!
  176. poping
  177. NX Parts List
  178. Bolt On nitrous guys...
  179. NOS install shops?
  180. Combination window switch/WOT switch
  181. Need help with nozzle location !!!
  182. I need help with a custom cam profile for nitrous
  183. Bad tuning
  184. Happy Halloween
  185. Wiring a progressive controller
  186. Flare Jet Question
  187. good inexpensie dry shot
  188. Who sells carbon fiber bottles?
  189. new engine
  190. LS7 w/200 shot = 8.90 @ 153.51
  191. N2O and Fuddle Stalls
  192. Whats the best way to tell when you need to refill your bottle?
  193. 13's on Nitrous
  194. what would you go with??
  195. New with NOS??
  196. Bottle Heater question?
  197. Harris Speed Works Nitrous (good?????)
  198. Full bottle preasure?
  199. what should the a/f be on a wet kit
  200. Airbrushed Fbody Bottles
  201. Cold Fusion Nitrous Controllers Are In!!!
  202. Can't do this with an LS1....
  203. Anyone getting rid of Nitrous equip for LT1? (wet)
  204. Big spray guys inside please...
  205. I Need Nawz!
  206. When wiring does it matter if you go from a larger wire to a smaller one?
  207. Mental note: A 10lb bottle does NOT weigh 10lb's
  208. Nitrous Pressure regulator pics from ZEX. Anyone like it?
  209. advice on tnt kit
  210. Need help. Lean spike???
  211. Newbie needs HELP!! What system to run??
  212. NOS remote bottle opener...
  213. A/F and JET sizing
  214. What is the best bottle pressure?
  215. standalone cell mounting????
  216. What do you Think
  217. Heads, cam, speed density dry nitrous = 183mph in standing mile!
  218. Kit installed. Pics inside.
  219. Nitrous parts needed
  220. gear lockout wiring diagram need
  221. Anyone mount nozzles at the air intake of a vic jr?
  222. How to inspect solenoid?
  223. Installation question
  224. NOS Window Switch (15879NOS) question
  225. Thank You LS1 Tech!!!! FREE BOTTLE HEATER AND PURGE KIT!!!!!
  226. Need Introduction To Nitrous
  227. Whats the easiest way to set a fuel pressure safety switch?
  228. progresive controler
  229. WOT switch with tnt f2
  230. Is it ok to use ARP thread sealer on NPT fittings
  231. NOS mini controller problem
  232. 2 stage nitrous questions
  233. Stacking fuel noids?
  234. NOS Jets
  235. Wideband 02
  236. Best converter for n2o
  237. What dose everyone pay to have their bottle filled?
  238. Best RPM Window Switch for my Setup
  239. Got some testing done last night with the 90/90 finally!
  240. Critique my graph
  241. Progressive Set-up - Starting Suggestions?
  242. My experience with Nitrous Direct
  243. A little more juice, A little bit quicker
  244. Is a nitrous filter recomened?
  245. leaving pressure in line
  246. Need help with Window Switch!
  247. Recommendations
  248. tnt f2, slp lid ??????? sugestions!!!
  249. what is this part?
  250. Pics** Is this an NX automatic heater?
