View Full Version : Nitrous Oxide
  1. New Install Pics (dial-up beware)
  2. quick question
  3. New best on spray
  4. Cutout Switch to Opener Switch?
  5. Supercharger and Nitrous-who's done it?
  6. 120volt bottle heater
  7. Would I up my jet size using methanol in standalone fuel system?
  8. The importance of heating a bottle properly
  9. nitrous line connecting
  10. nos plate kit ?????
  11. Noob N2O question - how long can a bottle be left open???
  12. Nitrous Dave's Plate users inside please
  13. Who Has The Best Kit???
  14. Bottle Heater?
  15. Zex Dry Kit
  16. nitrous motor help!!!
  17. need help
  18. Digital window switch ??'s
  19. help on repainting bottle
  20. What progressive controllers are you using??
  21. TNT F1 wiring schematic
  22. ? about Progressive Controllers
  23. NOYZEE Mobile Back in the works!!!!!!!!!
  24. Speed Density dry nitrous question
  25. How much $$ for install??
  26. Whats the biggest shot someone is running?
  27. how big of a shot to go 400whp
  28. new trickflow heads dry 75 shot 582 rwp
  29. Highflow valve guage
  30. Ls2 + cam + full exhaust (stock heads)...
  31. dyno tune nos kit
  32. new switch panel
  33. Upgrading To 90mm
  34. I hate to ask but...
  35. 200 shot on tnt's f2 kit??
  36. Directport Gurus come on in!!!
  37. Need help with why my nitrous pressure gauge doesnt work:pics inside
  38. Timing tuner question
  39. Advice please: Amps drop bad at idle when 860 bottle heater is on is this normal?
  40. stock A4
  41. nitrous piston
  42. this jetting too rich??
  43. Alittle help please.
  44. where to hide a 15lb bottle in a c5
  45. analyze my graph please
  46. One of those, "How much" questions
  47. dyno tune switch gauge & nos pressure wiring diagram NEEDED!!!!!
  48. I got gas!
  49. Are all Dry shot NOS jets the same
  50. Spraying on top of 400RWHP, how big can I go?
  51. Nitrous ring end gap, 2nd ring??
  52. Injector duty cycle?
  53. Is it safe????
  54. Rich no matter what.
  55. whats the trick to wiring msd window switch?
  56. N2O issues - detonation
  57. Duramax Deisel n2o kit in my ws6
  58. Fuel Pressure Switch Installation
  59. Timing tuner configuration ?
  60. best clutch for nitrous
  61. Dyno numbers on my C6 vette with A6 transmission
  62. just a couple questions...
  63. The Black Widow #2 !!!
  64. jets 4 175 on nos plate asap!!!
  65. Thinking of N2O
  66. WOT switch with 80mm TB
  67. Cleaning jets
  68. Dyno Tune Dual Stage Install
  69. Dry shot and 26# to 42# injectors
  70. 1998 SS: MS3 Cam Only + FAST 90/90 + TNT F1 = 555RWHP, 576RWTQ
  71. Heater & Purge 5177 kit and MORE POWER!
  72. NX Throttle Body - Any users?
  73. How much timing should I be pulling
  74. My dynotune nitrous pressure gauge came today
  75. rpm window switch question
  76. Where to mount a dry nozzle on a vette?
  77. Blow down tube
  78. Any one using an old school style plate kit?
  79. when you street race do people get mad that you use nitrous??
  80. big stall, n2o, stock tranny
  81. Finally got a tune and dyno #s
  82. Nitrous Works LS1 kit? Opinions?
  83. LS7 in a Mustang
  84. Do I need bigger injectors/higher flowing fuel pump?
  85. When one just isn't enough
  86. Speed Hut Custom Gauges!!! Anyone use these???
  87. Vette FJO wiring
  88. Nitrous problems......
  89. smooth bellow and tnt ring
  90. tnt f1 or f2 pics?
  91. pics of my Harris speed works stand alone
  92. Check out my Helmet
  93. Do I need to change the plug gap?
  94. Jetting a plate kit w/ standalone(low psi)
  95. Restrictions of a kit....
  96. Nos valve opener
  97. Tuning AFR
  98. fuel upgrade or not ???
  99. where to mount a WOT switch
  100. window switch question??
  101. Trex and 200 shot?
  102. what bottle opener
  103. For the Truck Guys..
  104. 10-Sec Daily Driven N2O Recipe
  105. Tuning a 400 shot
  106. is it the tune, the plugs or both?
  107. 75 dry plus cam
  108. bottle gauge question
  109. All questions about nitrous oxide
  110. wiring help
  111. Car won't shift
  112. What do you think..
  113. nos nitrous jetting
  114. Stand Alone Fuel Requirements
  115. ***help With Nitrous And Fuel Pump!!***
  116. Aluminum Tubing
  117. Done for the season!!!
  118. Which Set-up/Brand For 383 Stroker?
  119. 109hp gain on a 150 shot?????
  120. Tested System For 1st Time
  121. Spark plug Gurus inside please
  122. Progressive Controller
  123. Tpas
  124. BMN Wiring
  125. adjusting n2o and fuel pressure?
  126. NX MAF kit
  127. -6an is it worth it!!
  128. Where Can I Get My Nitrous Bottle Filled?
  129. 5 LBS of N20 Enough to Dyno 2-3 runs??
  130. A4 window switch or not
  131. 175 shot
  132. NX filling station FS. NEW!!!!!
  133. quick question
  134. would something happen
  135. Spark plug changes?
  136. FREE Dry Kit Upgrade!
  137. what gauges
  138. How long does nitrous last?
  139. Plate question...please help.
  140. Nitrous Plate System + FJO Controller No gains :(
  141. Best way to monitor A/F on a budget?
  142. Gauge on pillar
  143. Would you spray a car your making payment on?
  144. What heads for spray??
  145. what else do i need???
  146. -------Wideband commander logging question---------
  147. Nylon tubing good or bad?
  148. Pressure Pro Nitrous Regulator
  149. Nitrous System In Michigan - Legal Or Not???
  150. TnT nitrous system for sale complete cheap!
  151. Nitrous Express Price Increase!
  152. 1/4 mile estimate
  153. Lets see your custom bottles
  154. NX Price Increase Across the Board
  155. How much can I spray?
  156. Who is using the TNT F1
  157. dynotune window switch (single stage)
  158. dynotune window switch
  159. piston melting problem with
  160. nx import efi wet kit?
  161. hypertech w/nitrous
  162. Dual Stage For sale CHEEP!!!!!!!
  163. T-rex and spray
  164. popping at high rpms
  165. Nitrous activation light
  166. Should you heat shrink all connections?
  167. Poly Line Purge
  168. Autometer Nitrous Gauge Reading Off
  169. A4 wont shift fast when N2O is on
  170. nitrous effects on tranny
  171. difference between a 250-300 shot.
  172. Saw a dave Posser!!! Vinny saw to!!
  173. Direct Port Victor Jr. For sale
  174. A few basic questions
  175. Found my wot issue finally!!!!
  176. What all do I need?
  177. largest dry shot on straight pump gas
  178. Hugger + purge + 28's PIX!!!!!!
  179. Do you guys heat wrap all connections?
  180. n2o and window switch?
  181. post up your N20 Dyno #'s
  182. Nitrous bottle in a hot car?
  183. NO2 and a 4400 stall
  184. Head gasket question
  185. what size injectors
  186. bone stock A4, how big of a wet shot?
  187. Can I use this switch?
  188. where can i buy nos spray nozzle adapter?
  189. tnt c5 wide open throttle sw.inst....
  190. Solenoid not working?
  191. Whats the best way to tell how much nitrous you have in a 10lb bottle?
  192. 90/90 and TNT power ring
  193. Nos On Stock!!
  194. what do yall think?
  195. setup opinions?
  196. shakedown finally!!!
  197. "MoneyMaker" Nitrous users
  198. What kind of fuel pressure gauge do I need??
  199. spray
  200. Should the nitro dave plate system make a noise?
  201. Are these the correct plug per application.
  202. New Sales/Tech @ Nitrous Outlet
  203. Noszles. or any other manufacturer?
  204. is anyone spraying with flycut pistons?
  205. anyone using the NOS spray barless plate?
  206. Risk of a Dual 125 shot?
  207. Tnt F1 Installed And Did Test Run...please Read!!
  208. nitrous pull on the dyno... anyone here a problem?
  209. Which cam to use?
  210. Can I order the HSW plate yet?
  211. Will the timing tuner work for my plans?
  212. Plugs for a once direct ported intake?
  213. Missing on top-end with spray!
  214. Texas: the nitrous capital!
  215. Spraying a H/C '00 with stock fuel system .. limitations?
  216. 4K stall, what RPM to set activation switch.
  217. Nitrous guys... what plugs do you run?
  218. Las Vegas N2O install & dyno tune???
  219. Suggestions needed!
  220. window switch question
  221. lt1 timing
  222. Nitrous Outlets Booorific Specials!!!
  223. Nitrous controller: Would it make sense??
  224. Nice nitrous run
  225. would it be ok to mount a 15lbs like this
  226. My TNT kit, 02 SS *PICS*
  227. Please post pics of your dry shot...
  228. What should my A/F be???
  229. Tnt twister force question??
  230. plug ?'s
  231. dynotune warmer?
  232. 11's in the GTO
  233. Blew up a plug - now what?
  234. Fuel Pump w/ TNT?
  235. WHAT is wrong with my nitrous
  236. Nitrous help
  237. *** October Nitrous Special ***
  238. Questions: dry shot for '97 Vette
  239. Fueling and Jets
  240. HPE Big Nitrous ZO6 update
  241. Are all brand jets created equal?
  242. How much timing should be pulled running a 150 shot rated at the wheels?
  243. N2O plug gap question
  244. Have complete LS1 nitrous system for sale
  245. What is the Stock CI Nitrous Record? ET?
  246. low pressure nitrous system on efi motor
  247. My Intake MUST go!!! |Make reasonable offers!!!
  248. I need help with purge line.
  249. nitrous advice 1-2-3
  250. Help Opinions needed Nitrous Mishap
