View Full Version : Nitrous Oxide
  1. Nitrous & Boost
  2. Shop for N2O Install in Little Rock, Ark
  3. FL Heat + Nitrous bottle in car =
  4. Window switch wiring question
  5. jet question
  6. NX MAF install pics - LT1
  7. will this panel fit TA's
  8. change plugs for a 100 shot?
  9. Sprayed at the Track this weekend but had problems
  10. WOT switch questions
  11. Maybe a dumb question
  12. Lets See Some Clean Nitrous Installs!!!
  13. NX Maf
  14. Found my n2o malfunc issue
  15. nitrous questions...
  16. Just ordered my wet kit from Nitro Dave...
  17. Feedback on these direct port "nozzle" systems, who has tried them?
  18. TNT Jets
  19. nitrous distributers
  20. NX Pro Flow valve
  21. greenville, sc nitrous refills
  22. Quick question
  23. Will this hold a 150 shot?
  24. max dry shot w/ injectors
  25. Nitrous help please!!!
  26. Standard Kit to Direct Port Conversion
  27. felpro Head Gaskets and Nitrous
  28. Timing on 100 shot ?
  29. nitrous
  30. Whats your trap speed.
  31. What do tr-6s do when not sprayin?
  32. No people know
  33. Nos Solenoid
  34. just ordered from Nitro Dave's..
  35. Jet question for dual nozle dry?
  36. Fpss
  37. question for Nitro Dave
  38. Nitrous Pistons?
  39. dual stage, two window switches???
  40. What kind of preventative maintenance should I keep in mind with N20???
  41. Flames out exhaust
  42. Controlling nitrous pressure/nitrous calculator
  43. Is the TR6 cold enough for 600 on spray?
  44. MS3 and Spray?
  45. TPS wire
  46. Input needed
  47. Need some help logging TPS signal please.
  48. Dumb question...What size fittings
  49. 675 HP/685 TQ HSW Brute Force Dyno Results
  50. Looking for a new product,c02 instead of heater?
  51. Run 2 warmers with 1 pressure switch
  52. Dyno Results
  53. N2o and stall question
  54. higher octane question
  55. NOS 5177 kit advice
  56. mounting for micro/WOT switch
  57. Trick Window Switch owners please come inside??? Need help programming it!!!
  58. Please Help! I need Nitrous Installation Instructions asap.
  59. I figured out what the issue was with my N20 not effecting my run. Now what?????
  60. 900 vs 1100: pressure drop
  61. Sprayed Today 100 Shot A4 C5 (hot out, ?'s)
  62. E.T. Predictions...?
  63. edge evolution nitrous controler
  64. TNT still out there?
  65. Noid not opening after hot?
  66. Nitrous pass in car video
  67. NX 1pc Maf AirFuel Ratio - Rich ?
  68. couple questions please help!!
  69. Things to check before first time spray!
  70. Need new cam, MS3 = No torque N/A
  71. Ran the N2O at the track
  72. Engine requirements for 300HP spray
  73. Nitrous didn't improve anything on my ET at the track??? WTF???
  74. First day out to the track with new combo-close but not close enough!
  75. 200 shot question
  76. Newby ? Routing the feed line ?
  77. Zex
  78. is it bad
  79. Nothing coming out of the purge but noise
  80. fuel test port
  81. safe nitrous setup...????
  82. Might be going N20, some questions...
  83. DID search & read sticky! NOS install ??
  84. NX kit on 05' chevy truck
  85. Getting stupid...
  86. How about some dyno charts of a "Tuned" dry kit
  87. what rpm to spray at?
  88. I finally got my kit up and running!!
  89. Fuel Solenoid clicks but doesn't open????
  90. Finally !!!!!
  91. dry shot and auto tranny
  92. New Job
  93. "Tune" car with jets?
  94. Need a list of what is needed for an LT or LS1...
  95. Cam ?
  96. newbe ?
  97. now I'm pissed
  98. small shot
  99. New best on almost stock A4!
  100. same mph on 50 shot as 75?
  101. Custom Airbrushed Bottles..
  102. Wetshot on old car???
  103. Nitrous Knuckle Head needs help
  104. Can High bottle pressure cause no n20!!
  105. how many blasts?
  106. Will my fuel system handle 150?
  107. Santa Rosa/Petaluma, CA Fill Station
  108. Bottle Mount special...
  109. Nitrous missing in second-third gear
  110. The fastest anyone has gone with a TNT ring kit & LSx F-body?
  111. Some help with NX MAF plate
  112. Bottle in Bag
  113. what would u recommend???
  114. What A/F for those running 150-200 dry?
  115. To prove my point nitrous does help make things worst during a fire
  116. where can i get this bottle bracket?
  117. New times on the 100 shot. Good? Bad?
  118. Fuel Test Port Location? LT1
  119. spark plugs and timing
  120. Who is using 1/2" head studs here?
  121. Has anyone ever used propane?
  122. Still no big dawgs????
  123. HELP! Low dyno numbers...kinda.
  124. TPS signal question, and activation/deactivation.
  125. Car blew up on 300 shot
  126. Stock Injectors
  127. MSD WS tach wire hook up
  128. Where has all my TQ gone??? #2
  129. Purge silinoid problems!! Need help quickly!!
  130. Relays wireing ok or wrong ?
  131. How much spray?
  132. Sprayed ......
  133. Bad fill?
  134. my nitrous works...sometimes.....?
  135. nx remote opener intsall??
  136. 300 shot last night
  137. nitrous fillers in SE michigan?
  138. Picking up relays in your area
  139. Thinking of Direct Port......
  140. Pics of dual 15lbers on the deck!
  141. Those with 250+ shot
  142. NX MAF kit - wiring location question
  143. I need help adjusting bottle heater regulator!!!
  144. A little encouragment..
  145. What is goin on????Help??
  146. nitrous selonoid isnt working!
  147. Buy timing tuner or just use HPTuners?
  148. Main feed line?
  149. Pictures (Cold Fusion Wet Kit)
  150. Zex Help
  151. Anyone run a Granatelli Nitrous Maf
  152. How much for Halo conversion?Nitro Dave
  153. nitrous works kit....need some help
  154. Dynotune Air/Fuel Ratio Nitrous shut-down switch
  155. Nitrous Converter?? (New Tranny Time is NOW)
  156. What window switch should I buy?
  157. two stage ????
  158. What kind of spark plug gap should I go with??
  159. Two Stage
  160. MAF to Direct port conversion help
  161. At What Pressure does the bottle 'burst'?
  162. opinions
  163. FPSS explained??
  164. Can I keep my stock plugs..........
  165. Quick question....
  166. Alright Guys I need Help PLEASE!!!
  167. Dry nitrous experts
  168. If you have Dave's plate system, please come inside!!!
  169. A/f
  170. 150 shot on stock fuel pump?
  171. Where to purchase autometer light bulb covers?
  172. Burst Disc Ruptured Today
  173. misunderstanding something
  174. Gauge install...sorry if its redundant
  175. few nitrous questions
  176. trans line for blow down tube?
  177. Weird hissing.
  178. wet kit or no???
  179. DOES word nawwss get your panties in a wad.!
  180. QUICK Zex question!!!
  181. interesting meet with a boost fanatic
  182. Switch question
  183. My future dry nitrous project...
  184. 1 of a kind custom bottle mount pic
  185. selling brand new zex heater and NX bottle blanket
  186. Finally got to try out the direct port 200....
  187. which jets
  188. Ready to Rumble...
  189. Introducing. BIG PAPA !!!
  190. HP Loss Through Prog. Controller.
  191. need help with dry n2o tune !!
  192. Poor small block didn't even see it comming
  193. FPSS - where to put
  194. What does spraying through converter feel like?
  195. Custom Paint & Airbrushing
  196. Purge guys come inside!
  197. How Fast?
  198. 14/16 or 18 gauge wire?
  199. How to keep a good bottle pressure!!
  200. So close to finally hitting the 200 shot(~700rwhp)...
  201. Can/Shoud I convert my 125 dry to 200 wet?
  202. TNT website?
  203. Nitrous Harley for sale
  204. nitrous newb question
  205. Nitrous being installed
  206. How many switches needed?
  207. sneaky pete?
  208. Finished my bottle mount area
  209. Going to run 2 kits, need some advice
  210. blow down tube extension
  211. NX NXL kit question.
  212. Big Power On The Way
  213. Just finished plumbing stage 3 (direct port) pics inside
  214. first time nitrous with LS6. questions
  215. Nitrous Fill Stations
  216. Before and after...
  217. Now this is a Vette Intake!!
  218. Spraying my Lt-1
  219. EVERYTHING Nitrous related!! stock bottom end, wiring, EVERYTHING!!!!
  220. Retune after nitrous?
  221. car doesn't like 100 shot
  222. Victor Jr. Dual Stage Carb Plate Setup
  223. Timing Tuner question....
  224. Possibly a leak???
  225. fpss ?
  226. In dyer need of wiring help!!! (picture inside)
  227. can i get a pic please?
  228. Is there 175 jets for TNT kit?
  229. 200 shot on a 346ci
  230. Bung for my fogger nozzle
  231. 200 Shot on stock bottom end
  232. tune for 100shot???
  233. Anyone spraying >200 on Z06 Cam?
  234. Hidden Juice?
  235. Goodbye MSD Digital W/S..Hello FJO Mini Controller
  236. Anybody spraying more than 150?
  237. Need Help on Nitrous Jet Size?
  238. finally got my car back
  239. Big shots anyone?
  240. nitrous problem!
  241. Quick question first nitrous install
  242. Halo nitrous ring
  243. SI/n20 1/8 mile times...
  244. Nitrous Pressure Gauge - Missing Parts?
  245. New fuel pump or boost a pump?
  246. Throttle cable not going to WOT
  247. Who's running the new Zex Traction Control Window Swich?
  248. Is it possible to put a gauge on NX bottle?
  249. Need Quick Help - Timing Tuner
  250. Are the bottle handles(The knob thats used to open the bottle valve)all universal?
